Old 01-16-2010, 09:27 AM   #916
radio_car_racer's Avatar
sick of pulling the plug from the receiver?
I trimmed an old servo/esc lead, soldered the ends, and eased them into the esc plug. Since taking the picture I've heat shrunk them together.
no more unplugging for me
should also work for other esc's that use a PC for set up.
radio_car_racer is offline   Reply With Quote
Old 01-16-2010, 04:04 PM   #917
Trader Rating: 198 (100%+)
Have you tried it? I think there may be a problem with the rec plugged in supplying power and a signal. I know this will not work with the Tekin. I use a 3 inch extension works great.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 01-19-2010, 01:55 PM   #918
Yes and it was fine.
Receiver was not powered up when tested so no issue with signal. ESC is normally unplugged when hooked up to pc so has no power to it, so I didn't even think to try with power to receiver.
I'm away to test it on my Tekin's now with Hotwire
Old 01-19-2010, 02:05 PM   #919
double post
Old 01-21-2010, 05:38 PM   #920
Trader Rating: 8 (90%+)
I am thinking of picking up an orion model of the BMC with the 1.5 update. I am wondering what kind of gearing is needed to keep up with the newer speedo's. I am currently running a SP GT 2.0 and I have to gear at a under 4.0 to even compete with the others, especially with the newer software that is out. Does this ESC have similar things like boost and timing advance as the others and if so could someone let me the scoop. I would appreciate it.
Thanks alot
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris [email protected]
Tha Skinny is offline   Reply With Quote
Old 01-21-2010, 05:59 PM   #921
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
I have one for sale if you are interested, as well as the USB setting adapter.
IIGQ4U is offline   Reply With Quote
Old 01-21-2010, 07:28 PM   #922
Thanks alot
again
Houston,Texas
Serpent 733 EVO
Old 01-21-2010, 07:47 PM   #923
Send a message via AIM to goop
again
hey skinny if you are referring to the tekin with v203, then no the ko is not at that point yet. im sure they are working on something.
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 01-21-2010, 07:54 PM   #924
dougmartin's Avatar
Trader Rating: 14 (100%+)
hey goop...on your ko profile that was posted back on page 5 or 6 what timing do you run it at? I really like the profile and just ran it in timing 6.
thanks
dougmartin is offline   Reply With Quote
Old 01-21-2010, 09:41 PM   #925
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Anyone have a suggested setting for a BMC-1.5 in 1s 1/12th scale 17.5
Got smoked this past weekend...as if I as running a single speed on the straight versus the tekins with latest software.
When using a rx pack... do you leave the speedo switch in the off position?
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 01-21-2010, 11:12 PM   #926
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Hey Goop,
I don't know you, and you don't know me, but its nice to see a clear simple honest answer from a team member about their product. Sometimes I get so sick of all the ego's replacing useful information in these product threads. I can almost smell the testosterone/BS when I mouse-over some of those threads. Thanks for keeping it real!
AWD
Old 01-21-2010, 11:27 PM   #927
Chris Adams's Avatar
Originally Posted by andrewdoherty View Post
Hey Goop,
AWD
Andrew, I think yall met a couple years ago in Omaha when I was surfing on your Shui
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 01-21-2010, 11:40 PM   #928
I agree, thanks for the input. What would be the suggested gearing and base set up for me. I run on a 75x45 carpet track with a 415 mre 2.25. With a 17.5 just to know what the gearing is compared to the others.
Houston,Texas
Serpent 733 EVO
Old 01-21-2010, 11:44 PM   #929
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Safe Assumption
when timing was only at 2..and the SPX came out.. Ko did an update that bumped up the timing to "6".
its a safe assumption i would think that they're working on an update to keep up or go faster than the Tekin/BD.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-22-2010, 02:02 AM   #930
sounds good to me It looks like it has been a long time coming.......so it could be a good thing.
Houston,Texas
Serpent 733 EVO
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
