Ko BMC Speedo
Old 01-02-2010, 06:28 PM
  #886
Zdiddy's Avatar
I cant figure out whats wrong. The usb driver isnt installing
Zdiddy is offline
Old 01-02-2010, 07:12 PM
  #887
ds400's Avatar
Default Brake Frequency
Hey guys I am trying to figure out the correct brake frequency for my 12th scale. I use 2.44 kHz as it is on the 12th profile on the ko website, but dont get enough brakes, then I tried some random frequency like 1.48 kHz I need to bring my transmitter brakes to 20% .. otherwise I spin out...
So when choosing a brake frequency should we choose one than allow us to keep 100% brake on our thansmitter or what?
How does that work.
Didier
ds400 is offline
Old 01-02-2010, 11:28 PM
  #888
Racer Z's Avatar
How does that work.
Didier
In 1/12th I personally like turning up the frequency to smooth out the braking and then adjust my epa to control the locking up!
Racer Z is offline
Old 01-03-2010, 11:31 AM
  #889
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
guys hows it going
i have been running this speedo for over a year, when i got it i ran primarily onroad, so i just used the setup that drew ellis used at nats....that setup in my tc was dialed...never changed it....motor ran cool, plenty of spped to keep up with the tekin and lrp...
i have since swiched to running a sc 10 on a indoor carpet track, we are running on a small 60x 40 track, that has jumps and what not....we are also running 17.5 motors...(mine is a duo 2)
i tried drews setup, it was too soft, couldnt make the jumps,
i tried the goop setup, didnt work well either, motor got hot, even on low timing....
i went to the #5 stock 1.5 setup and it works well, i am on timing 3, motor set to 20 deg....motor runs at 170 ish after a 6 min race.....
the truck still seems to lack punch, compared to the others at my track, (mostly novak havok systems...)
i have geared all over the board, andget the same result....
is there anyplace to tell me how to set up the spedo??
i know about the timing, the drag brake, and the brake freq...
i am not clear on what type of curve would work on the drive freqs...
any help would be great...i have 2 of these speedos, i am seriously thinking of going to tekin simply because there is no info out there for this speedo..
thanskfor the help
Matt M. is offline
Old 01-03-2010, 11:42 AM
  #890
Johnny Wishbone's Avatar
Originally Posted by mr. losi View Post
guys hows it going
thanskfor the help
If you want more punch just raise the entire curve up on the bar graph. The closer to the top of the graph you have your bars set the more punch you get.
Johnny Wishbone is offline
Old 01-03-2010, 11:49 AM
  #891
Vicko's Avatar
Trader Rating: 14 (100%+)
is there an new sofewear or well is it goin come out to make this speedo as fast at the Tekin with the new sofewear or the BD?
Vicko is offline
Old 01-03-2010, 12:17 PM
  #892
Its already in there.
Old 01-03-2010, 01:17 PM
  #893
Administrator
Matt M.'s Avatar
and to refresh my memory, more timing is more top end and less torque
Matt M. is offline
Old 01-03-2010, 02:16 PM
  #894
Yes, BUT, don't get fooled into only thinking of it as timing via the sc only as its actually combined timing of your motor and sc. With that, sometimes 6 is beyond a workable timing application, so, it may be a matter of retarting motor timing, advancing sc timing and totally re-gearing the car. For example if your on a tight twisty track and you want more torque, retart the motor timing (before 0) drop 5 teeth on your motor and increase your sc timing, doing all this, but keeping the same profile (curve) will give the same trigger feel but will torquing out of the cars more. You may not "feel" it, but the lap times should reflect it.
If you where to break down all the adjustments that the KO has and compare it to the Tekin, everything is there, the hard part is making the application work the same or better.
Old 01-03-2010, 03:50 PM
  #895
Administrator
Matt M.'s Avatar
i agree, however someone needs to tell the end user what each change does...
i thank you for your insight.....and assistance....
Matt M. is offline
Old 01-03-2010, 04:57 PM
  #896
Vicko's Avatar
well where can I get the sofewear for it then J. Wishbone?
I have 2 bmc with the 1.5 in it aready and its no where as fast as the
New Tekin sofewear that came out this week
Vicko is offline
Old 01-03-2010, 05:23 PM
  #897
Administrator
Matt M.'s Avatar
the software is on the ko america website....
Matt M. is offline
Old 01-03-2010, 07:09 PM
  #898
Racer Z's Avatar
+1
Racer Z is offline
Old 01-03-2010, 07:19 PM
  #899
Racer Z's Avatar
Are you talking about the BMC Stock Motor Manager? If so its not as fast as the Tekin even on the highest timing setting! I got blown away by the Tekins yesterday and today! I heard the Black Diamond is even faster!
Racer Z is offline
Old 01-03-2010, 08:21 PM
  #900
Administrator
Matt M.'s Avatar
that is the program...
for sedan i simply use the profile drew ellis used for rubber sedan.....it has always kept up with the others for me....on a 65X40 track i geared my 009 at 7.8 ish.....
my problems are with my sct.....
Matt M. is offline
