Ko BMC Speedo
#76
Same Orion Vortex Race ESC New price now !
#77
Look on Ebay. I saw a couple on there. Also check www.speedzoneusa.com. I'm pretty sure they have them in stock.
Canyon
Canyon
Does anyone know if this is the same software etc for the Orion spec speedie?
Regards
Kyle
#78
#79
Ta no probs, I would have thought it would have been identical as well. Will give the KO one a crack and go forward from there.
From what I have seen so far its a great speedie, the additonal programming tools should make it even better.
Regards
Kyle
Regards
Kyle
#80
Has anyone had any cogging issues with this speedo? I have recently put on in my 10th GT pan car and on pull off on all settings it cog's any ideas on how to resolve this?
Cheers
Cheers
#81
You know, mine does the same thing. Haven't had a chance to play with it and try to figure it out. But I will say THIS THING IS FASSSST!!
#83
I don't think it's a "problem". I believe it's just due to the fact that this speedo has so much timing built into it. By no means does it come off the line slow! It still runs perfectly fine and is very, very fast! It just makes a cogging noise occasionally when starting from a dead stop. I'm running Hacker motors with mine.
#84
I ried the speedo and it is fast, but it cogged with 2 13.5 Orions and an LRP 13.5 I want to purchase the SC, but dont want it to cogg no matter how fast it is. That noise gets in my head and starts to mess with me. IMO.
#85
#86
you may have to get the settings adapter and set the speedo. i believe that the default config is 5-6 cell. in wgt you are running 4 cell. that may solve your coging issues
#87
In fact today we detonated a motor from advancing the timing too far.
When I say to far, i mean we advanced it like we did with the LRP Sphere TC.
My guess is the speedie is reasonably adavanced in its default profiles.
Impressed with the speedie so far, hopefully when the usb setting stuff arrives this week it can be improved on again.
Regards
Kyle
#88
#89
#90
I am running the KOBMC with a Fantom 10.5 in my 1/12th scale. Any suggestion on timing the motor for this speedo motor combo. Seems like I could use a little more bottom end. Increasing the timing at the motor...will it help or do I need to get the interface cable and make changes in the speedo? I thought when you increase the timing it adds RPM. Can someone shed some light on this issue!! My setting in the speedo is profile #1.. Track size is 40 by 25 with lots of turns. My tire diameter is 44.5 front and 47.0 rear with a 92spur 35 pinion. Thanks in advance!!
