Ko BMC Speedo
Old 12-08-2009, 02:04 PM
  #841
MelvinLee's Avatar
Default New
Originally Posted by radio_car_racer View Post
Cheers
I now have a setting to work from from Melvin
If you have the settings from me, go to timing 4 and gear down 3 teeth Max timing on Duo 2
MelvinLee is offline
Old 12-08-2009, 05:41 PM
  #842
Originally Posted by redbones View Post
Getting better, but I'm looking for a tekin and is killer profile for 17.5.
On another note, I am running fanless for the esc, but wondered if heat will gradually make the speedo slower during the race. I also heard that the esc fan is mandatory for boosted applications. Is this true?
in 17.5 you do not need the fan i run mostly 13.5 and feel no fade unless im overgeared and the motor comes off at 180+ this is the profile i run in 10.5-13.5-17.5 i used this profile to win 17.5 at the indoor champs 08 and the IIC 09 also finished 4th in 13.5. just play with the drag brake. use model 1
File Type: txt
goop is offline
Old 12-08-2009, 05:47 PM
  #843
Hebiki's Avatar
Trader Rating: 26 (100%+)
goop.. what 17.5 motor did you use with this? Duo? (if its the duo... which timing hole?)
thanks! I'll be testing the X-12 17.5s this weekend at the Ko Propo Grand Prix.
Hebiki is offline
Old 12-08-2009, 07:28 PM
  #844
Racecrafter's Avatar
Trader Rating: 25 (96%+)
GOOP! Whata-ya-doin!?!?!!
You're givin' away my speed secrets!
Racecrafter is offline
Old 12-08-2009, 10:23 PM
  #845
thanks guys. Having fun chasing after those t2, photons, and Mi4 with my tub car Need to prove a point with the KO you know.
redbones is offline
Old 12-09-2009, 06:18 AM
  #846
lol you like that one its the best profile yet.
i do run a duo in 17.5 in middle timing hole do the math 84 spur 45 pinion 2.73 internal with 2.2 inch foam tires
goop is offline
Old 12-09-2009, 06:20 AM
  #847
i ran the x12 10.5 at the halloween classic run my profile and change the timing to 4 and take out a lot of drag brake use the #2 timing adjuster for the motor this is the gearing i ran with a 10.5
102spur 35 pinion 2.0 internal and 2.2 inch tires
goop is offline
Old 12-09-2009, 08:58 AM
  #848
Hmmmm... 5.1FDR Thats a bit lower geared than what we run in RCGT
I ran your profile right after IIC and liked it. I found that it's suited to a smooth trigger finger and a car that has good corner speed.
I had created my own profile and when I saw yours tried it and liked it as well.
So I programmed a new profile using aspects of both that I liked and ran that for the remainder of the RCGT Showdown.
I however don't run any timing in the motor.
Old 12-09-2009, 10:12 PM
  #849
radio_car_racer's Avatar
wish I'd know this for the weekend gone as I had severe cogging on the bottom end. cured by pulling the the 1st 8 or 9 sliders down.
will try the profile agian this weekend but geared down
radio_car_racer is offline
Old 12-10-2009, 06:16 AM
  #850
is your speedo version 1.0 or 1.5
goop is offline
Old 12-10-2009, 09:31 AM
  #851
If it is ORI65006/ORI65007, then it is V1
If it is ORI65008/ORI65009, then it is V1.5
I have 2 ORI65007 but one was sold to me as a 1.5 as it had proof of being to the US for the upgrade and that's in the GT10 car
When I hook up the BMS Stock Motor Manager program it shows timing adjustment for both esc's. Does this not work for the v1.0 even though you can make an adjustment?
Old 12-10-2009, 10:06 AM
  #852
version 1.0 will studder off the line but v1.5 will not thats why i asked
goop is offline
Old 12-10-2009, 12:24 PM
  #853
motesracing's Avatar
How does this esc compared to mamba or tekin?
motesracing is offline
Old 12-10-2009, 06:29 PM
  #854
rcko's Avatar
Trader Rating: 15 (100%+)
I just picked up another one of these 1.5 units from Nexus after experiencing the first one running 12th scale 13.5. The smoothness of the throttle convinced me to get one for my sedan as well. It is soo cool to change the behavior of the car by just having to move the little slides around. It truly remarkable that we can now taylor map motor characteristics just like we can on full size engines using MegaSquirts or VTEC programmer minus the fuel/air ratio curves.
Incredible little gem of a speedo. Looking fwd to running 17.5 TA with it.
rcko is offline
Old 12-13-2009, 08:01 PM
  #855
rcscoot25's Avatar
Is there upgrades in the works to go up againts the BD????
rcscoot25 is offline
