Old 11-19-2009, 11:06 AM   #811
Send a message via AIM to jeff whiting
We have two of these speed controls I just purchased for our B44's. I am impressed how smooth they are. So smooth in fact I have a question.
Of the 5 presets, which will be the most aggressive? I have tested 1 and 3 and really can't tell much difference. Our off-road track is high bite clay and we we are running 6.5 Novak Ballistic motors. After a run the motors are coming off the track at 125.
I donít have the USB interface or the software yet but does anyone know what the brake settings are with the standard profiles. I am curious about drag brake in particular.
JEFF
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 11-19-2009, 04:01 PM   #812
Johnny Wishbone's Avatar
JEFF
You don't have to have the interface to see what the profile settings are at, just go to the website and download them and open them up. That part of the software is right off the KO website and your going to need it anyways for when you do get the rest.
Old 11-19-2009, 06:24 PM   #813
Thanks for the info.
Jeff
Old 11-19-2009, 08:43 PM   #814
Send a message via AIM to goop
JEFF
hey jeff i would try gearing up about 3-4 teeth
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 11-19-2009, 10:52 PM   #815
I will give that a try also.Thank you.
Jeff
Old 11-22-2009, 07:49 PM   #816
Default Can you roll wires
Just trying to clean up some wiring and wondering if anyone has or knows what would happen if you rolled the "A" and "C" wires on a motor? Would it spin backwards or not at all? Anyone do it by mistake and what was the outcome? I'd love to get rid of the lump that the crossover makes with the flip of those 2 wires.
For those that where curious about this as well, I did some checking with a voltmeter and couldn't see a voltage issue that would cause problems so I tried to switch but I guess there must be sensor wires that would have to be changed as well to fire in the right order, so no such luck in getting rid of the crossover.
Old 11-22-2009, 08:40 PM   #817
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Just wondering if the V1 and V1.5 have the same timing when both versions are set to timing value 1 or 2?
Thanks in advance.
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 11-24-2009, 05:59 AM   #818
Default Orion
Hello,
how do you recognize if it is the version 1.0 or 1.5?
I have the orion version and i bought it in late august
thank you!
Mankalas is offline   Reply With Quote
Old 11-24-2009, 06:42 AM   #819
Default orion bmc
Do you still have the original casing? It would have its part number on the label.
If it is ORI65006/ORI65007, then it is V1
If it is ORI65008/ORI65009, then it is V1.5
changss is offline   Reply With Quote
Old 11-27-2009, 01:30 AM   #820
Canyon's Avatar
Trader Rating: 8 (91%+)
Originally Posted by Gitsum View Post
Sounds that way...not good if so. Anyone have a ballpark for gearing with a 13.5 for tc on a 90ft str8t.
Hacker 13.5 geared at 4.5, timing maxed on motor. Here's my speedo profile. I'm running Model 2. Motor comes off at 160 and is very fast.
Canyon is offline   Reply With Quote
Old 11-29-2009, 10:26 PM   #821
Running 17.5 DUO2 (no timing) and geared at 3.5. Motor is temping at 145 so I guess I can try the 3.2 FDR that someone recommended. My question is, how come I can gear the car with the BMC to ~3.5 when others (Tekin, LRP) are way above 4.0 using the same motors? The speeds are about the same.
Also, how come timing 5 feels faster than 6?
redbones is offline   Reply With Quote
Old 11-29-2009, 11:42 PM   #822
can someone explain to all of us, how does the esc timing work?
is it working at full throttle only?
what is the difference with the motor timing?
krat is offline   Reply With Quote
Old 12-01-2009, 07:36 AM   #823
I'll try to explain, although I'm very far from a expert but I did stay at a Holiday Inn Express last night.
You have to divide your track into 4 sections, and then convert that over to the graph. The start of the graph is the bottom end or the initial punch, the next 2 parts of the graph are the mid section of the track, like the tight sections into and out of the corners and the final part of the graph is the straight or top end, or when you want the boost to kick in. Now the key part is determining how long or how soon you want the events to happen, so the flatter you make the graph in sections is the length of time that that "feel" will happen. You also have to remember that not only the length but where the graph actually is, higher or lower, will also determine the strength of the punch, and since, if you move the AVG bar up or down and don't change the curve, you can make the car feel softer or harder but still drive the same. The trailing end of the graph is where the boost kicks in and to make it come on sooner or later on the straight can be adjusted by the flatter you make the end of the line, so if you want the boost to come on sooner in the straight you would make the last 5 bars all the same freq opposed to if you want the boost on later, you would have the last to bars the same.
I've read this a couple of times and hopes it kind of makes more sense to you as I don't know if it came out in words the way it should.
And if I'm wrong or please feel free to post as I am far from a expert on this item and if I'm missing something I would love to know.
Old 12-01-2009, 07:41 AM   #824
You are probably over timed when you run on 6 thats why 5 feels faster. You could try to back the mechanical timing of the motor back and advance the SC timing to get the same or better feel. Or if the motor is fixed timing it probably has so much advance build in that, again your over timed.
Old 12-02-2009, 10:57 PM   #825
radio_car_racer's Avatar
Originally Posted by dawgmeat View Post
Contact melvin at nexusracing.com his profile is the SPX killa
Cheers
I now have a setting to work from from Melvin
radio_car_racer is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
