Old 10-29-2009, 01:56 PM   #781
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
how does this speedo stack up against the sxx? also do you have to install a power cap/voltage booster etc..thanx
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 10-29-2009, 02:04 PM   #782
Trader Rating: 22 (100%+)
My feel is that it is smooother (with the reedy mod settings) than the sxx tc spec.
No need for a capacitor,needs a voltage booster for 1 cell lipo or a receiver pack(most do).
The smoothest speedy I have used but can also be set very aggresive if you need to.Must get the ICS adaptor to change the settings however the speedy is awesome.
bjspinner is offline   Reply With Quote
Old 10-29-2009, 03:25 PM   #783
you cant change the profile settings without that adaptor, how much is adaptor,and do you just go on pc to do this? assuming theres preset profiles online somewhere?
Old 10-29-2009, 04:05 PM   #784
Ther are 5 preset in the speedy that you can change to without the ICS.
The ICS does connect to the computer it is about $50 I think, well worth it as you can store different profiles on your PC.
Old 10-29-2009, 04:13 PM   #785
kidsid99's Avatar
Trader Rating: 53 (100%+)
It has 5 preset profiles without buying the adapter. The adapter is about $65 (I think) and it will allow you to go on the KO website and download settings like Drew Ellis' TQ and win in Vegas. It also has one from Ralph Burch. The adapter has the driver disc and the cords to hook to your pc and then you can modify the settings to suit you. You have to have this if you want to use #6 timing. Hope this helps.
XRAY, RC America, Boca Bearings,
www.msra-racing.com
kidsid99 is offline   Reply With Quote
Old 11-01-2009, 11:06 PM   #786
Scottrik's Avatar
Trader Rating: 245 (100%+)
Here's a fwiw...
I FINALLY got my BMCs installed in the 1s 1/12 cars I'm taking with me to the big TimeZone Gran Prix next weekend. I was thinking I'd have to do some "workaround" wiring to make the booster work. WRONG!! Plugged one of my cheap Chinese boosters directly in-line in the ESC's receiver lead between the esc and the receiver and VOILA!!
Then my only concern was that there could be a low-voltage situation so I used my GFX to drain battery to cutoff (3volts) and then hooked up the esc, etc to it. It seemed to work fine.
Add this esc to the VERY short list of easily plug-n-play booster opportunities. The only other esc we've had work truly plug-n-play for these boosters is the Novak GBB 4-cell.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 11-02-2009, 06:10 PM   #787
bluephi1914's Avatar
Trader Rating: 34 (100%+)
$65 and worth every penny
http://www.nexusracing.com/product_i...oducts_id=2610
Mr. 17.5 's Rides ----> T3 EU / T2 008 EU (Vintage)
** NEXUSRACING.COM **
** Team Xray - Team Novak - Proline - Sorex - KO Propo - Team Trinity **
bluephi1914 is offline   Reply With Quote
Old 11-02-2009, 06:17 PM   #788
The software alows you to manipulate the speed control in every way; Adjust all aspects of the powerband.... adjust timing, brake, dragbrake, etc.
Also everyone seems to forget that if you have the KO servos.... you can also use the software to adjust speed, expo and sensitivity of your Servos. Actually you can download the servo sftware from KO site and the USB adapter that comes with the KO software allows you to hook it too your sevo.
Old 11-04-2009, 07:23 AM   #789
radio_car_racer's Avatar
Originally Posted by radio_car_racer View Post
Wanted
4 cell & lipo setups for 12th & GT10
if you could email the files that'd be great emails in my user profile
thanks
nobody got any setups to share
it's getting closer to my next race
radio_car_racer is offline   Reply With Quote
Old 11-04-2009, 09:03 AM   #790
dawgmeat's Avatar
Contact melvin at nexusracing.com his profile is the SPX killa
dawgmeat is offline   Reply With Quote
Old 11-12-2009, 10:14 AM   #791
Send a message via AIM to Bastos
Originally Posted by Jørgensen View Post
Hi
I have a little problem maybe??
I have get me a VFS-1 BMC V1.5
And i also bought the usb adapter(ko61018)
I have download the VFS-1 BMC Manager from the Kopropo site.
So when everything is ready,i should try to connect the esc to pc.
But i only get message with "no connection"
For sure,i had turn the power on the esc
Hope someone can help me..;-)
Have you resolve your problem ?
I've got the same problem.
Each time is "Connection failed" !!! and I've try every "comm port" proposed.
With a Lipo Battery, when you plug the USB adapter and the speedo, is it normal that the red light is still lighting when the speedo is power off ?
Thank you
Bastos is offline   Reply With Quote
Old 11-12-2009, 11:23 AM   #792
Trader Rating: 198 (100%+)
Keep trying the com ports. You need to make sure your driver for the usb dongle is installed. If it is not you will never get a com connection. This is not the same as the BMC manager for stocl motors.
You do not need to power up the esc. It will get the power it needs from the pc conection.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 11-12-2009, 11:47 AM   #793
Ooops...forgot to install the driver...
Old 11-12-2009, 01:34 PM   #794
Sam-E's Avatar
The usb dongle will not work with windows 7 64 bit :-(
TMORC - Official Club for the 1/10th Offroad Electric Worlds, 2012!!
Sam-E is offline   Reply With Quote
Old 11-13-2009, 12:14 AM   #795
Can someone give me a ballpark gearing or fdr for 13.5 rubber tc on a 90ft straight? thanks!
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
