Old 10-01-2009, 09:32 AM   #751
bl4
bl4's Avatar
Thks for all the info and help
bl4 is offline   Reply With Quote
Old 10-04-2009, 04:40 PM   #752
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Guy's Question,
I have a question about the KO speed controller. I just picked one up Ver 1.5 I plan on using this for 1/12th.
On a carpet track 100x45 how would gear a Duo 13.5 with a 1c 3.7 thunder power lipo pack.
I downloaded one of the profiles for stock 1/12th from the KO site
Im running Model 3 and #6 on the timing using the KO BMS Stock manager program. And on the DUO im in the middle hole for timing.What pinion should I use with a 76 spur and a 1.72" tire?
Im not sure how I should setup the motor and timing but any help would be greatly appreciated.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 10-04-2009, 05:32 PM   #753
kidsid99's Avatar
Trader Rating: 53 (100%+)
Originally Posted by mike ivy View Post
Hey Guy's Question,
If no one else answers this for you, call Robert at KO. He is really helpful and I haven't been able to come up with a question that he could not answer.
XRAY, RC America, Boca Bearings,
www.msra-racing.com
kidsid99 is offline   Reply With Quote
Old 10-04-2009, 05:59 PM   #754
Alex C's Avatar
Hey Guy's Question,
Hey Mike,
Just tested a few profiles this past weekend with a few Team Members running 1/12 13.5-BS, our findings had found gearing for a similar track had been at a final rollout around 3.19, With a 76 Spur and 45 Pinion.
Attached below is a excel chart I had made for a quick reference, I would recommend to temp your motor accordingly to determine if you need to gear up or down dependant on your track layout.
I hope the attached spreadsheet helps ........................ Should you have any questions, please feel free to e-mail me.
Alex
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 10-04-2009, 07:52 PM   #755
bl4
bl4's Avatar
Hi guys need some help! I have just purchase a used Orion Vortex ESc. After soldering, once I turn on the esc(TX on too) the motor will auto run. Check on the wireing correct. Is this faulty or do I need the Ko Propo ICS USB adapter to program it? Thks!
Old 10-04-2009, 08:50 PM   #756
Scottrik's Avatar
Trader Rating: 245 (100%+)
Nope--you need to set your esc to your transmitter. Or double-check that your neutral (throttle) isn't set to something. I'm not sure what transmitter you've got but you should be able to adjust your neutral band or move the throttle setting and make the motor stop. Recommendation would be to set everything to zero/neutral/default and then perform the setup routine. You won't need the USB, just the button on the esc switch.
Scottrik is offline   Reply With Quote
Old 10-04-2009, 09:24 PM   #757
bl4
bl4's Avatar
Originally Posted by Scottrik View Post
Nope--you need to set your esc to your transmitter. Or double-check that your neutral (throttle) isn't set to something. I'm not sure what transmitter you've got but you should be able to adjust your neutral band or move the throttle setting and make the motor stop. Recommendation would be to set everything to zero/neutral/default and then perform the setup routing. You won't need the USB, just the button on the esc switch.
I am using a Futaba 3PK. I might have over look at that, will try it out again. By the way where is the button located? ORI65007 Vortex Race with Cooling Set (Limit 2.5T)
Thks!
Old 10-04-2009, 10:36 PM   #758
Scottrik's Avatar
Thks!
Little button right on the side of the switch housing.
Old 10-04-2009, 10:56 PM   #759
bl4
bl4's Avatar
Got it thks!
Old 10-08-2009, 10:44 AM   #760
CFR
CFR's Avatar
Orion Vortex Race ESC with v1 sofware
anyone got suitable settings they can share for nimh with 10.5BL?
I have the PC software available to me
CFR is offline   Reply With Quote
Old 10-14-2009, 08:05 PM   #761
Jørgensen's Avatar
Hi
I have a little problem maybe??
I have get me a VFS-1 BMC V1.5
And i also bought the usb adapter(ko61018)
I have download the VFS-1 BMC Manager from the Kopropo site.
So when everything is ready,i should try to connect the esc to pc.
But i only get message with "no connection"
For sure,i had turn the power on the esc
Hope someone can help me..;-)
www.jorgensen-motorsport.com
Xray T4 - Team Orion - Serpent 811 Cobra 2.2 - OS Speed - Hitec Lynx 4S - Kopropo Servos
Jørgensen is offline   Reply With Quote
Old 10-14-2009, 08:41 PM   #762
Trader Rating: 22 (100%+)
Originally Posted by Jørgensen View Post
Hi
In the bottom right corner there is a comm port setting you need to know and remember which port it is set to so as to connect to the program.
Mine is port 7 but I would assume that most would be different.
If you use Vista plug in the ICS usb adapter and then go into device manager and it will tell you the comm port number if you left click the + symbol next to where it shows ports(COM & LPT) Mine shows ICS USB ADAPTER( COM 7)
bjspinner is offline   Reply With Quote
Old 10-16-2009, 09:24 AM   #763
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
Quick question:
On a BMC v1.5, what's the max timing you can run with either a 13.5 or 17.5 motor in a 2-wheel buggy?
Thanks.
Rich Panganiban is offline   Reply With Quote
Old 10-16-2009, 11:17 AM   #764
Send a message via AIM to goop
Originally Posted by Rich Panganiban View Post
Quick question:
Thanks.
the more timing you put in the less torque you will have. i would use timing 3-4
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 10-17-2009, 02:18 PM   #765
I have the VFS-1 speed control, and racing tourers, I use a team orion 10.5 motor, the speed control is great except for the braking, the braking is very poor, the speed control can hardly stop the car at all.
I have the programmer and have tried different frequency settings but the braking is still poor... any ideas...
Tekin - The ultimate trophy hunters choice!!!
FactoryTeam08 is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
