Ko BMC Speedo
Old 12-28-2008, 07:53 AM
  #61
Originally Posted by kimilia View Post
first, the battery must be pluged into the ESC.
then make the connection to the USB cable.
open the BMC manger, select the corrent com port number.
then, everthing is ready.
you do not have to have a battery plugged in your usb will provide power to esc
goop is offline
Old 12-28-2008, 07:25 PM
  #62
tpczx6's Avatar
Ok thanks guys
I found that my laptop docking stations com port is not working right. I do not have a 9 pin port on my laptop (I have an older ICS no USB on mine)but my docking station does but not working so I hook it up to my work laptop. everytings working now.
tpczx6 is offline
Old 12-28-2008, 07:28 PM
  #63
thats awesome good to hear
goop is offline
Old 12-29-2008, 12:56 PM
  #64
If you are using the serial ICS plug, you will need to have a battery plugged into the ESC for power.
If you have the USB adapter and your USB port on your computer is not a USB 2.0 you will need to connect power to the ESC.
If you are using a USB 2.0 port you do not need a battery to connect the ESC. The USB 2.0 port has enough power to do setting changes to the ESC.
KO PROPO Staff is offline
Old 12-29-2008, 02:32 PM
  #65
Johnny Wishbone's Avatar
Default KO PROPO Staff?
Is there a site or link that shows the pinout for the serial ICS plug?
Johnny Wishbone is offline
Old 12-29-2008, 06:06 PM
  #66
Will this speedo fit the tub chassis on the TA05? Barely got the Sphere in there so wondering... I know the SP didn't so...
redbones is offline
Old 12-29-2008, 06:20 PM
  #67
Johnny- There's more to the serial then just hooking up the wires. There is a small PCB inside the connector as well.
redbones- I fit it into my TA05 with no problems. The lead going to the receiver just makes it to the receiver.
Old 12-29-2008, 06:32 PM
  #68
RockyMania's Avatar
Trader Rating: 17 (100%+)
Hi there, just wonder whether the BMC have drag brake settings? i know they have the motor timing settings but unsure whether it contain drake brake...cheerios!
RockyMania is offline
Old 12-29-2008, 07:00 PM
  #69
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Drag brake values are from 0-255. They are not in % values. Buggy and Touring profiles are insane with drag brakes. (IMO)
Motor timing values are 0,1,2. (not in degrees either)
DirtyDog3375 is offline
Old 01-01-2009, 02:16 PM
  #70
TFR
TFR's Avatar
Is there a default battery cut off? I'm using lipo and I don't have the setting adapter yet.
Which memory profile would you run for 10.5 lipo rubber on carpet?
TFR is offline
Old 01-01-2009, 02:45 PM
  #71
Default battery cutoff is set to 5-6 nimh, you will need to get the USB link to change it (KO61018) or wait for the setting card due out end of Jan/Feb.
Use the 'power' profile for 10.5t. (quoted from Robert - KOPROPO staff)
Old 01-01-2009, 07:48 PM
  #72
Trader Rating: 40 (100%+)
If you need more top end use the touring mode for 10.5....seems to be better than the power mode..
King of B Main is offline
Old 01-01-2009, 08:20 PM
  #73
Canyon's Avatar
Trader Rating: 8 (91%+)
Has anyone hooked up the USB and read the profiles yet? How do they differ?
Canyon is offline
Old 01-03-2009, 04:17 AM
  #74
Luke Hobson's Avatar
does anybody know where i can get the USB, and program from?
i cant find anywhere with it instock. need one before next thursday shipped to the UK......
luke
Luke Hobson is offline
Old 01-03-2009, 11:49 AM
  #75
Canyon's Avatar
luke
Look on Ebay. I saw a couple on there. Also check www.speedzoneusa.com. I'm pretty sure they have them in stock.
Canyon
Canyon is offline
