Ko BMC Speedo
Old 07-21-2009, 11:05 PM
  #571
Johnny Wishbone's Avatar
Did you make sure that your speed control is setup for a Lipo cutoff, as I think the default is still set to NiMH, and if thats the case you could have discharged your Lipo too far. I've seen Lipos swell when they get over discharged.
Sorry I now see it was suggested already, but I'd triple check for Lipo cutoff. Or check the pack voltage when your coming off just to make sure the cutoff is working. Just because you only ran for 7 minutes doesn't mean you could be at the bottom of the curve. Maybe the pack didn't get fully charged too. Just throwing some ideas out there.
Johnny Wishbone is offline
Old 07-22-2009, 06:53 AM
  #572
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Good point
BP SHADOW is offline
Old 07-22-2009, 10:32 AM
  #573
jonest's Avatar
Originally Posted by BP SHADOW View Post
It may not be that bad, but its not supposed to swell at all. I would go through the car top to bottom and check everything, bearings , belts, gears, motor and make sure that nothing is bound up and causing excessive ampdraw on the battery. It is possible that you got a defective pack, that happens from time to time. Or the pack got damaged unbeknownst to you. I run the Orion Lipos and have not had a single issue with them. Is this a hardcase lipo?
the car was super smooth so there's nothing binds. defective pack? The problem started when I starts to use Orion 6.5t and I don't think it's caused by the motor, coz it's slower than LRP X12 6.5t! Hardcase lipo it is.
Set to lipo cut-off, can't play play with this setting. Mostly 7+v after run. Checked lipo after charged ard 8.38 - 8.4v.
Originally Posted by kschu View Post
what C rating is your lipo ?? 25c,30c,35,40c ?
4000mah x 35c, 5000 x 35c, 4900 x 35c all hard case
The problem stated when I starts to use the Orion 6.5t and profile changed to the Reedy Race mod settings.
So I'm just wondering whether the timing advance on the esc which is #2 or the high braking freq could have caused this or a faulty motor? Normally a Lipo would swell becoz of overly high discharge rate, in this case I don't think so.
jonest is offline
Old 07-22-2009, 12:18 PM
  #574
BP SHADOW's Avatar
By defective pack, I mean something was wrong with the battery right from the factory, mismanufacturered or out of spec.
Old 07-22-2009, 01:06 PM
  #575
Okay, hate to sound like a broken record, but the profile you mentioned is pre set to Nimh, so unless you specifically set it to Lipo after you did your write you might still be defaulting to the Nimh instead of Lipo setting. You also say 7+volts, but what is it, as I think the Lipo safe cut off is 3.6 volts which should make your pack at at least 7.2 volts. Can you snapshot a pic of your profile coming off the SC and post it in a pic? Might be something to look at.
Also it doesn't have to be a overly high discharge rate to swell the pack, it can be caused by going to deep voltage wise into the pack too.
Old 07-23-2009, 04:58 AM
  #576
has Orion released the new v1.5 BMC? is there any news about this?
krat is offline
Old 07-23-2009, 11:07 AM
  #577
jonest's Avatar
Will post it up in the morning. And don't think it's a defective lipo.
Btw, how do u guys keep ur lipos? I normally charge it full after race and will recharge it before using it. That's the practice right?
jonest is offline
Old 07-23-2009, 11:14 AM
  #578
Hebiki's Avatar
Trader Rating: 26 (100%+)
nope.. its not good to store lipos fully charged. you should keep them at 80% charge or lower. i dont remember the exact number.
im sure someone will chime in with the correct number.
Hebiki is offline
Old 07-23-2009, 11:17 AM
  #579
they say if you are going to store them for a long time (months) to store them at 3.8 to 3.9 volts per cell, for just weekly racing i usually just leave it where it comes off the track (running stock only takes out about 2000mah) so thats almost 1/2
HenBeav is offline
Old 07-23-2009, 11:28 AM
  #580
jonest's Avatar
What's the repercussion? Will it swell up or just deplete in terms of capacity? I normally store them fully charged up but I've been running them on weekly basis.
jonest is offline
Old 07-23-2009, 03:17 PM
  #581
weekly fully charged probably not too much a problem, i think the fully charged storage main loses capacity, your swelling is probably due to running mod in heat (malaysia pretty hot isn't it?), if the minor swelling of a mm or two goes back down after the pack cools back down i really wouldn't worry about it
HenBeav is offline
Old 07-23-2009, 10:15 PM
  #582
jonest's Avatar
Guys, I were using this profile + Orion 6.5t. Now I've changed autobrake = 50 & timing = 0, rests the same.
jonest is offline
Old 07-27-2009, 07:28 PM
  #583
#88driver's Avatar
Can someone point me in the direction as to who is the head honcho on this thread as in who knows the most about these speedos?
#88driver is offline
Old 07-27-2009, 08:02 PM
  #584
that would be the guy that has KOPROPO for a name. but maybe i can help i have played alot with this speedo.
goop is offline
Old 07-27-2009, 08:05 PM
  #585
#88driver's Avatar
Sorry didnt see him but you sir will have a pm in about 3 minutes
