Old 07-17-2009, 12:22 AM   #556
theisgroup's Avatar
Originally Posted by minicooper View Post
Anyone??
you need to also adjust the brake frequency. if I remember the lower the freq the hard the brake feel. then you can play with the autobrake. the higher the value the harder the brake brake feel. in 17.5 I am running almost no autobrake.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 07-17-2009, 12:04 PM   #557
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
theisgroup - thanks for the response. I'll keep adjusting the frequency until I get something.
Royal Rumble Racing
minicooper is offline   Reply With Quote
Old 07-20-2009, 10:18 AM   #558
jonest's Avatar
Guys I need some help here,
I'm running KO BMB 1.0 + Orion 6.5t (retard timing) using profiles #1 & #2 from Reedy Race of Champions 2009 Modified Settings; (timing: 2, brake adjusted to 2.44khz) and the problem is that my lipo swells by 1mm (4000mah x 35c, 5000mah x 35c).
What should I change? timing back to 0 or brake freq too high? Btw, my brake epa on radio is set ard 65-75%.
And I must say that my car was really fast, it's just that most my lipos swell.
Please help. Thanks
jonest is offline   Reply With Quote
Old 07-20-2009, 02:54 PM   #559
fly_wheel's Avatar
what is the voltage cut off (lipo) default set in BMC v1.5? i haven't connected mine to the computer yet (i don't have the cable). been only trying with the default 5 profiles n drag brakes setting.
There are more in racing than winning.
fly_wheel is offline   Reply With Quote
Old 07-20-2009, 08:27 PM   #560
Please help. Thanks
have you changed the cut-off voltage mode to lipo? it seems your lipo was pushed below the minimum voltage.
krat is offline   Reply With Quote
Old 07-21-2009, 12:20 AM   #561
jonest's Avatar
It's set to Lipo and I don't run more than 7mins during practice. Our race is only 5 mins duration. So I don't think it's the cut-off issue here... Thou the lipo swells, the punch is there. But I hope it will not happen to the new lipos I'm planning to get.
Old 07-21-2009, 12:44 AM   #562
now i'm afraid that will happen to me also. my BMC hasn't arrived yet, but i'll use 3.5T motor.
at our local track, many people run the Vortex version with 3.5T motor, they use standard profile (#2 i think) and nothing happen to their lipo.
so maybe the timing is too high.
Old 07-21-2009, 04:08 AM   #563
jonest's Avatar
I think the ESC if fine as long as we understand what the settings are meant for. Can't simply fiddle it now.... Wondering whether the timing or brake freq adjustment were the cause for the lipos to swell. Will be testing it over the weekend.
Old 07-21-2009, 09:48 AM   #564
Hebiki's Avatar
Trader Rating: 26 (100%+)
what brand lipo are you using?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-21-2009, 12:19 PM   #565
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
From what it sounds like you have a bad battery. I have never seen a lipo swell, and mine barely ever get hot. Has the pack taken a major impact?
Someone correct me if im wrong, but the speddo settings probably wouldnt hurt the battery, I would think something would go wrong with the motor before the battery.
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 07-21-2009, 12:25 PM   #566
Hebiki's Avatar
you beat me to it.. sounds like a very low quality battery. ive blown up speedos and motors, but never a lipo.
Hebiki Design Works
Old 07-21-2009, 09:18 PM   #567
Gig
Gig's Avatar
I just picked up the 1.5V BMC. I want to know when should I use the heatsink? 10.5 or higher? Or should I just install the heatsink wo/fan until it temps higher than 100 degrees F.
Gig is offline   Reply With Quote
Old 07-21-2009, 09:37 PM   #568
jonest's Avatar
It's Orca (HongKong) and Power Track. A friend of mine is using same Lipo (Orca) + LRP X11 6.5t + LRP TC Spec. He doesn't have this problem.
Btw, the swell is not alot, 1-2 mm in the centre when it was supposed to be flat.
The motor perhaps?
Old 07-21-2009, 10:06 PM   #569
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
The motor perhaps?
what C rating is your lipo ?? 25c,30c,35,40c ?
Give the best while u can !
kschu is offline   Reply With Quote
Old 07-21-2009, 10:16 PM   #570
BP SHADOW's Avatar
The motor perhaps?
It may not be that bad, but its not supposed to swell at all. I would go through the car top to bottom and check everything, bearings , belts, gears, motor and make sure that nothing is bound up and causing excessive ampdraw on the battery. It is possible that you got a defective pack, that happens from time to time. Or the pack got damaged unbeknownst to you. I run the Orion Lipos and have not had a single issue with them. Is this a hardcase lipo?
http://f1rclab.com
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
