Old 06-30-2009, 03:49 PM   #511
Halloween's Avatar
Originally Posted by theisgroup View Post
i would think you would want steps 25-32 to be as close to 52 a possible. my understandind is that 1 is high torque and 52 is high rpm. so that at step 32 you have the throttle at full so you would not need the torque and you would want more rpm.
Here is something writen about the drive freq. It 's a download from the KO site. It is a manual from a other esc, but the basic is the same. It stood somewhere right above the middle of the first page. "What is drive freq?
http://s195302033.onlinehome.us/CX/Misc/KOMisc2.pdf
The model of Hebiki is almost the same as mine ( he posted this one earlier) and i tried this on my track with rubber wheels. When i started the profile at this level my wheels are spinning, the diff is upsad and the outdrive cups are broke in a notime because of the power of the speedo. That's the reason that i choice for a cunning in the first sector from 1 till x. I'll test this one thursday
@ DS400 Thanks pal. Your much of a help!
Halewijn
Halloween is offline   Reply With Quote
Old 07-02-2009, 06:02 AM   #512
B4james's Avatar
I just loaded the the Drew Ellis software profile.....all I can say is whooaahhh mumma.
That is one balls and all profile curve, the thing just rips and makes a 17.5 come alive
I cant wait to do some timed laps as I am getting the feeling that this thing is going to rock . The ICS USB controller is so easy to use and love how you can configure the different model profiles.
If I program the different models say to be 1 notch difference in timing e.g. 4, 5, 6. Will this allow me to test different timing without the need for the software controller at the track ???
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 07-02-2009, 08:48 AM   #513
Yes you can. If you want to copy profiles from one model to the next, just click and drag on the model profile tabs. Then you will get a window asking if you want to copy model X -> model Y and you can make your timing adjustments to each model number.
KO PROPO Staff is offline   Reply With Quote
Old 07-02-2009, 09:40 AM   #514
Hebiki's Avatar
Trader Rating: 26 (100%+)
edit
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-02-2009, 09:41 AM   #515
Halloween's Avatar
Which one is the Drew Ellis profile?
Halewijn
Old 07-02-2009, 09:43 AM   #516
Hebiki's Avatar
Halewijn
its on the Ko site.
http://www.kopropo.com/america/index...113&Itemid=162
Hebiki Design Works
Old 07-02-2009, 09:43 AM   #517
It's under the BMC help Center page "ROAR Carpet Nats 09"
Old 07-02-2009, 10:24 AM   #518
fly_wheel's Avatar
i should have bought my own ICS USB adapter...
There are more in racing than winning.
fly_wheel is offline   Reply With Quote
Old 07-02-2009, 11:11 AM   #519
jonest's Avatar
Guys,
It mentioned "Only to be used with version 1.5 of the BMC and the Stock Motor Manager".... what if I'm still using v1.0? Could I still use it on a 10.5t?
jonest is offline   Reply With Quote
Old 07-02-2009, 11:13 AM   #520
Nope.
Old 07-02-2009, 11:13 AM   #521
Hebiki's Avatar
Originally Posted by jonest View Post
Guys,
the biggest difference is with V1.5 you have timing up to "6". v1.0 only has timing up to "2".
Hebiki Design Works
Old 07-02-2009, 12:44 PM   #522
Halloween's Avatar
Oke, thanks. That's the profile that Hebiki posted earlier.
That one is the best so far. The profile which i posted is't that good. I think that the cunning at the end is too sharp.
@ Robert. Is it (not) possible that you can open the profile's which stands on the KO site in a text file? Then you can chance it to a .kpd file and the software can read it. Otherwise you must type it in the software.
Now you can see what i meant in post 491. For example: i think that the freq30 till 32 is't position 12 but 1. Ore not?
Halewijn
Old 07-02-2009, 12:58 PM   #523
You have to right click the link for the profile and select "save as" when saving.
Then start the BMC software and select the open file icon. When this window opens, you can change the file type to all "*.*" and select the file or you can change the suffix to the file (.KPD) when you save it.
I don't look at the text file because it is too confusing. I only open them with the software.
Old 07-02-2009, 01:42 PM   #524
jonest's Avatar
So I could use the same profile except the timing is set at "2", right?
Old 07-04-2009, 12:04 AM   #525
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
Hi all. Need some help with brakes. I've been messing around with the settings on my radio (M8) and on the esc but I can't seem to get enough autobrake when I go to neutral. It coasts no matter what I do. If I set the radio for more brake it affects the top speed. I must be missing something. When I was using the novak esc, I used profile #4 and that was just right. Can't seem to mimick that on this esc. motor is a 17.5 novak Thanks
Royal Rumble Racing
minicooper is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
