Ko BMC Speedo
#452
An other question(s). How much time is there between DriveFreq cyclus 1 to 32? Is that 1 sec? 3, 5 ore maybe 10 sec?
And why do you need to have lots of punch (high freq) at the end of the cyclus? And a much rpm at the beginning? I thought you always need first to have punch and then the rpm? Maybe not by carpet, but for a high traction outdoor track. It don't make since to me...
Many thanks!
PS this week i gonna test the speedo with several settings on a 1/8 scale high traction/speed track with a straight end of more then 70 mtr.
I will keep you informed.
Halewijn
#453
Automatic Brake, more commonly referred to as "drag brake", is when the car will slow down when you let off the throttle. this is done to simulate what brushed motors used to do.
on the BMC.. for Automatic brake, the higher the number, the more you have.
Brake Freq is how "hard" your brakes are. so if you set a lower brake freq, say 0.492khz (the lowest setting), the brakes are much stronger when you apply them compared to 2.44khz (the highest setting).
#454
Thanks Hebiki,
So your are saying that the BMC has a double brake function.
For the automatic brake: the higher the number how stronger he will brake and for the brakefreq: the lower the number how stronger he will brake....
Oke, an example: automaticbrake on 30 and brakefreq on 0.792khz will be the same as automaticbrake on 120 ans brakefreq on 1.70khz.....
Ore did i mis something?
Do you (ore anyone else) has an answere to my other qeustions?
Many thanks
Halewijn
Many thanks
Halewijn
#455
Thanks Hebiki,
Many thanks
Halewijn
Many thanks
Halewijn
#456
no, 2 different functions. almost all brushless speedos have 2 brake setting. one is for automatic brake or drag brake. this is to simular the drag a brush motor has. and the second is how hard the brake effect is when using push brake(brake freq). now what I am not sure of is if the brake freq affects the auto brake.
but i always thought drag brake affects your car when you let off the throttle (before you get to neutral).
so if your drag brake is maxed out.. you let off the throttle a little bit, your car will slow down faster.
"brake freq" is how hard it will stop once you start applying brakes after neutral (i.e. pushing forward on the throttle trigger).
now.. i agree with you. im not sure if brake freq ALSO affects drag brake?
#457
i am thinking that it does not because I have been playing with brake freq, but it has not affected my autobrake. but hey, maybe the changes are soo slight, I could not fell it. I should just set it from min to max and see.
#458
ahaa,
Now i'm getting it! Your both explainations making it clear to me.
The brakefreq is how hard he will brake after the neutral!
Many thanks!
Yang; do you maybe have an answere to my other questions?
Halewijn
Many thanks!
Halewijn
#460
halloween-
Changing the brake frequency will effect the automatic brake (drag brake) since you are telling the ESC at what frequency to apply brakes and drag brake. Sometimes the changes are so small that it is hard to tell the difference.
Higher drive frequency gives more punch. So sometimes having more punch doesn't help with low traction conditions, so we go to higher drive frequencies initially. Creating wheel spin doesn't make you go any faster, but slower because you are not moving forward.
#461
halloween-
#462
wooohooo! one less thing to test before vegas.
#463
So if i understood it right you can say that when you drive on a high traction circuit with a low gearing like 3.70 ore lower, you can use a lot of punch at the beginning (freq 1 to 8) and go from that to a lower (lowest) freq for the speed (ore "second gear").
Any chance you can give the aswere to my last question?
Halewijn
#464
Oke, thanks Robert!
Halewijn
Halewijn
#465
Great! Just what i thought!
Many thanks for your explaination.
And what about the time for the freq (1 to 32) cyclus? is that 1 sec? ore 3 ore 10?
I wondered about some grafics i saw. They started at a high freq, then they go to a lower and ended at the middle....
When you drive a technical circuit i can understand, but then you need the time howmuch the esc does about the freq 1 to 32...
Halewijn
Halewijn
