Old 12-22-2008, 12:43 AM   #31
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Thanks for the replies so far. Just wondering if Robert or Hebeki can confirm this from a company viewpoint.
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 12-22-2008, 12:54 AM   #32
Hebiki's Avatar
Trader Rating: 26 (100%+)
no need for a cap guys.
im not a company representative.. just a loyal supporter and user of their products Robert will chime in and give you guys the low down on the remaining questions.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-22-2008, 01:06 AM   #33
Also for got to ask earlier....
Does the original ICS USB adaptor kit (KO61018) work with the BMC esc?
Old 12-22-2008, 01:59 AM   #34
Unfortunately the factory setting for the Team Orion's version is all preset with 5-6cells cut-off.
The ICS USB adaptor kit (KO61018) will work for both version: Team Orion and KO.
MobileSuit is offline   Reply With Quote
Old 12-22-2008, 06:26 AM   #35
Kenneth Tan's Avatar
Has anyone got success in running the BMC with 3.5T motor with 5 cell or 4.5T motor with 6 cells? Thanks
Kenneth Tan is offline   Reply With Quote
Old 12-22-2008, 06:46 AM   #36
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
if i'm nt mistaken, shin adachi from Kyosho is using 6 cell on 4.5t during Ifmar last month. someone can clarify this ?
Give the best while u can !
kschu is offline   Reply With Quote
Old 12-22-2008, 06:58 AM   #37
We need to see normal people use this.
Old 12-22-2008, 07:30 AM   #38
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
I've seen alot guys Testing the speedo for KO and Orion and they were running mod. They were using lipo and nimh batteries.
King of B Main is offline   Reply With Quote
Old 12-22-2008, 07:38 AM   #39
Thanks. There wasn't much postings from these guys on this thread... Did you see them working well with mod?
Old 12-22-2008, 09:50 AM   #40
The factory default setting is set for 5-6 cells. You will need to program it if you want to use LiPo.
Any of our ICS communication adapters ( USB or serial) can program the ESC. You will need to download the software from our site here http://www.kopropo.com/america/index...d=21&Itemid=59
KO PROPO Staff is offline   Reply With Quote
Old 12-22-2008, 09:55 AM   #41
Send a message via AIM to HenBeav
on the timing adjust function what does 0,1,2 correspond to in degrees?
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
Old 12-22-2008, 10:30 AM   #42
Ya, very good....I saw Josh Numan and Randy Caster win with the speedo and Im pretty sure Josh Cyrul is running one in his car because he runs for KO.
Old 12-22-2008, 10:55 AM   #43
minimusprime's Avatar
Trader Rating: 19 (100%+)
i've been smoked by drivers using this esc enough times already that I know i want one.... cant' wait to get it.
"I personally do not believe in luck. I believe luck is just an excuse for people that have failed in their mission to accomplish something." Allen McNish
minimusprime is offline   Reply With Quote
Old 12-24-2008, 10:48 PM   #44
dear all
I just got the BMC ESC and USB ICS programmer.
but I don't know how to prepare the ESC ready for comunicate with the BMC manager...
do I have to plug the car battery to the speed controller?
turn the speed controller off or on? or in the setting mode?
I am confused....
please help
kimilia is offline   Reply With Quote
Old 12-25-2008, 08:59 AM   #45
Send a message via AIM to goop
Originally Posted by kimilia View Post
dear all
I am confused....
please help
unplug your escc from your reciever. plug in your usb cable to your esc. at this point everything should be connected. are you using a laptop? if so you have to figure out which comm port your usb cable is in. just go to control panel then dbl click the system icon, then you will see a series of tabs open the one that says hardware then click on device manager find the one that says ports and comms and dbl click on it look for where it says usb ko propo and thats where it will tell you what comm port its in. open the bmc program and in the bottom right you can change the port put in the port it said your usb was in. it should say comm ok now to pull the info off your speedo you just look to the lower left and find the icon that says read all click that and it will read all 5 profiles on your speedo so when you make any changes you go to the lower left and find the icon that says write all click that and when its done writing then your done and can unplug everything. hope i got this all right lol pm me if you have any more questions
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
