Old 06-05-2009, 10:04 PM   #406
Send a message via AIM to goop
Originally Posted by Halloween View Post
I will, have the DX3s with telemetry. So i can check the temp anytime. i even can let an alarmsignale sound off if the temp is reaching the 80 deg c.
Doe you recommen a high torque ore a high rpm brushless motor with this setup?
i have tried a lot of motors i have found that the trinity or(epic) duo motors are the best. if you need any call brad johnson at hurricane motorsports
www.teamhurricane.net
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 06-07-2009, 06:34 PM   #407
I was wondering if anybody has tried to run the software on a 64 bit version of vista and get it to work. I have tried but can not get it to run, if anyone has got it to run could you post it here. Thanks
Steve P.
srp67 is offline   Reply With Quote
Old 06-09-2009, 05:56 PM   #408
tdu verney's Avatar
Default Great customer service
Hey Robert,
Thanks for your help this afternoon on RX pack questions and radio tips. Hope to meet you in Vegas.
tdu verney is offline   Reply With Quote
Old 06-09-2009, 08:31 PM   #409
Trader Rating: 198 (100%+)
Steve P.
I believe that came up earlier in this thread and vista 64 is a no go.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 06-10-2009, 12:49 AM   #410
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Profiles
here's the profile i ran at Reedy. Trinity Duo 17.5, Middle hole timing, i dont remember my FDR ThunderPower 40C 5000 lipo.
here's the profile i ran last Saturday at our Carpet Track - Round 1 of RCGT Showdown..... Trinity Duo 17.5, Middle hole timing, FDR of 4.1. ThunderPower 40C 5000 lipo.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-10-2009, 07:21 AM   #411
Administrator
Matt M.'s Avatar
i guess i am totally lost, those curves are completly backward from what t thought they would be...
the setup must hava a hair trigger, then soften? i am sure i am not understanding how the drive freq works...
can anyone explain??
Team Losi Racing-Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 06-10-2009, 07:40 AM   #412
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Im not the absolute expert on this, but I will tell you the way it was explained to me.
The higher the number(freq) the smoother the response
So if you start the curve at the top, it will be the most progressive.
How long you want it to stay smooth determines when you want to start lowering the frequency.
The only thing I dont understand is why the Reedy setup started at a lower frequency on an outdoor track, unless there was insane amounts of grip.
At the same time, the carpet setup is using a high freq, when usually there is almost unlimited bite on carpet and you wouldnt need to baby it.
Now saying that, we need to keep in mind that you operate in the first part of the curve only a small percentage of the time, so maybe the middle portion of the curve is more critical to get right.
Any further definition from KO would be helpful
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 06-10-2009, 08:37 AM   #413
B4james's Avatar
How does the new software versions of this speedy compare to the SPX and RS speedies on the market ?
Is the V1.5 software coming in current models or do you have to send it off to get this put in. Also what do you need to tune the speedy and change settings for Spec classes such as 17.5 and 10.5 ?
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 06-10-2009, 09:28 AM   #414
Administrator
Matt M.'s Avatar
thanks and yes any more info would be great...
we should get a chart high tracktion is this, low is that....type of thing
Old 06-10-2009, 09:36 AM   #415
Hebiki's Avatar
yes speedworld had a ton of traction.
lower freq = more punch, higher frequency = more rpm, more efficiency. the profile for speedworld (i'm guessing and this is what it felt like on the track) ends in the higher freq to get that "second gear" effect off the very long straight away. this was needed for 17.5.. and even more visible with 13.5.
for carpet, i wanted more rip since i pretty much drive on/off. but the set up was really good when i stayed smooth on the throttle.
Hebiki Design Works
Old 06-10-2009, 09:42 AM   #416
Hebiki's Avatar
for those viewing the images above....
on the left side.. it says.. "52 and goes down to "1".
52 = 2.04khz
1 = 12.146khz
when people say "lower frequency" it actually means a bigger number on that left side... and higher frequency means closer to "1".
Hebiki Design Works
Old 06-10-2009, 09:54 AM   #417
Hebiki's Avatar
B4James.. you can download the software from Ko Propo website: http://www.kopropo.com/america/index...d=21&Itemid=59
scroll to the bottom and get the StockManager. to have your computer communicate with the esc, you will need to purchase the ICS USB adapter.
Hebiki Design Works
Old 06-10-2009, 01:02 PM   #418
BP SHADOW's Avatar
52 = 2.04khz
1 = 12.146khz
you learn something new everyday, no wonder my cars are so squirrely, ive been setting up the curves backwards
thanks for the clarification
http://f1rclab.com
Old 06-10-2009, 01:18 PM   #419
Hebiki's Avatar
have you tried leaving the profile as is... and adjusting the drag brake (auto brake) and the brake frequency? i usually have my brakes set at 0.792khz... for carpet i "softened" it a tad... try it out.. you might like it
Hebiki Design Works
Old 06-10-2009, 01:47 PM   #420
BP SHADOW's Avatar
its more about the way the car takes off,and im really talking about my F1 car with the brushed motor and the c2 speedo,but i am going to assume the software is set up fairly similar
http://f1rclab.com
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
