Ko BMC Speedo
Old 05-18-2009, 07:32 AM
  #346
g12314's Avatar
Goop,
Just wanted to say thanks for the KO setup you had given me. Took 2nd this weekend at the Hobbyplex TCS race and clearly had the fastest car on the track. Just didnt have that little bit of luck needed to put it on the top of the podium.
Time to send it in for the 1.5 update now.
Thanks,
Jimmy
g12314 is offline
Old 05-18-2009, 02:44 PM
  #347
Trader Rating: 22 (100%+)
Originally Posted by g12314 View Post
Goop,
Thanks,
Jimmy
Which one of Goop's setups did you use?
bjspinner is offline
Old 05-18-2009, 05:16 PM
  #348
he was using one of my older setups for the BMC v.1.0 so he only had 2 timing
goop is offline
Old 05-18-2009, 05:45 PM
  #349
Hey Goop have you got a setup for 10.5 with the new version speedy ver 1.5.
I have had a look at some settings where should I start as I am yet to get this on the track at this stage.
Old 05-18-2009, 06:43 PM
  #350
try this one
File Type: txt
goop is offline
Old 05-18-2009, 07:43 PM
  #351
Originally Posted by MoonTrap View Post
Hi
Where can one get a replacement fan, without having to buy the whole kit with the heatsink?. the fin part has come off my fan, and need a replacement one, or can one use the high rpm much more ones?
Thanks Ya`All
Replacement fans are available. The part number is 45523. You can also purchase them here http://www.shopatron.com/product/par...052.1057.0.0.0
KO PROPO Staff is offline
Old 05-18-2009, 07:44 PM
  #352
I thought in an earlier post ko america said it will be out in february
They have been pushed back due to the BMC v1.5. No ETA when they will be available.
Old 05-18-2009, 07:54 PM
  #353
try this one
Thanks Goop I have put that in but how do you get the figure 63 it only goes up to 52 in my programing on the pc?
I put it in as high a figure as I could will that be ok.
Could you maybe please explain it a bit more to me, and what to expect from these settings over a slower rising curve in the settings.
PM if you like.
Thanks for your help
Old 05-18-2009, 07:57 PM
  #354
PM if you like.
Open the file with the PC software.
Old 05-18-2009, 08:35 PM
  #355
I must be stupid
I don't know what you mean, Goops file is a text file am I suposed to open it with the BMC manager?
Or do I read the values from the txt file and put them in the freq boxes in the BMC manager.
I have the programs from KO America, do you have a recomended profile for10.5 from that site.
Old 05-18-2009, 09:53 PM
  #356
theisgroup's Avatar
rename the file to a .kpd file and then you can open it with the bmc manager or stock motor manager. the board will only take certain files, so for anyone that wants to post bmc profiles, they need to change the extension of the file to a txt.
theisgroup is offline
Old 05-18-2009, 10:41 PM
  #357
At the high possibility of sounding stupid HOW.
I tried to re-name the file, but not 100% sure how.Showing my age here.
I just might be getting dementure.
Old 05-18-2009, 10:51 PM
  #358
theisgroup's Avatar
so you find the file you downloaded and then right click on the file and then select rename. delete the .txt and replace with .kpd
the other thing you can do is open the bmc manager or stock motor manager and click the folder icon and then click the down arrow next to the text box for "files of type:" and then select *.*
Old 05-18-2009, 11:23 PM
  #359
Thanks Yang you have been a great help.I think I am now sorted.
This is a very helpful thread
Thanks all.
Old 05-19-2009, 08:41 AM
  #360
theisgroup's Avatar
just trying to give back. you should have seen how much time Robert put in to help me with my radio issues last year in Vegas. Even though I was a nobody. just can't beat the service.
