Ko BMC Speedo
Old 05-05-2009, 01:39 AM
  #316
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Drew Ellis View Post
Chris I forgot you will not want to run for more then 6 min's that way..Or there could be problems with your motor...
Drew
RCGT runs for 7 mins down here. but i only ran it in expert stock (13.5) which is only 5 mins. ill post the profile shortly...
Hebiki is offline
Old 05-05-2009, 01:45 AM
  #317
Hebiki's Avatar
Default Profile
this is the Touring5,6 cell profile. all i did was take the slider and moved it up until step #32 was all the way to the top.
enjoy!
also..i dropped 5teeth on my pinion. (typo on the graphic.. i set the cutoff to LIPO)
Hebiki is offline
Old 05-05-2009, 03:06 AM
  #318
Originally Posted by MoonTrap View Post
What cogging issues are there?, is it only for spec motors?. I am using low turn modified and the speedo is smooth as butter with no cogging, it is a v1 speedo, is it worth sending it in and being without it, if i have no issues?
Thanks Ya`All
not necessary if your running mod. the cogging only happens with 13.5 and higher turn motors. although i did see one instance with 4 cell mod where it did have an issue and the update fixed it. me personally i would do the update just to make sure that i wouldnt have any issues at a big event.
goop is offline
Old 05-05-2009, 03:11 AM
  #319
bmc settings the first one is the one i ran at the nats and the second one is one i have been playing with it seems to have more bottom end.
File Type: txt
File Type: txt
goop is offline
Old 05-05-2009, 07:38 AM
  #320
Administrator
Matt M.'s Avatar
thanks guys...the auto brake is drag brake, so what is the brake frequency??
Matt M. is offline
Old 05-05-2009, 07:40 AM
  #321
Yeah, its just i would be without the speedo for a while, and would have to ship it half way across the globe. Is one able to use the v1.5 profiles that is listed on the ko propo america site? on a v1 speedo, i am looking for a profile that is like profiles 3 and 4 on a lrp tc spec.
Thanks Ya`All
MoonTrap is offline
Old 05-05-2009, 07:46 AM
  #322
Drew Ellis's Avatar
Thanks Ya`All
No you can not use the new software without the update...If you like the profiles just copy them and then load it into your speedo..
Drew
Drew Ellis is offline
Old 05-05-2009, 12:22 PM
  #323
jonest's Avatar
Guys,
If I'm running v1.0, what profile should I be using? The old or new (if there's a new one).
jonest is offline
Old 05-05-2009, 04:27 PM
  #324
v1.0 = bmc 1.52 only
v1.5 = bmc stock or bmc 1.52
hope this helps
Drew try the second setting i put on the last post and tell me what you think
goop is offline
Old 05-06-2009, 02:49 AM
  #325
Hebiki's Avatar
hope this helps
Goop (sorry i dont know your real name)... whats the second profile for? 13.5 or 17.5? curious what it was designed for.....
- Chris
Hebiki is offline
Old 05-06-2009, 06:49 AM
  #326
theisgroup's Avatar
just to be clear, I believe that you can use any of the profiles in any of the versions of the bmc. I beleive the difference is that the stock motor manager has extended setting for the timing that only takes effect on the ver 1.5.
the only thing I have not played with is what would happen if you ran the stock motor manager on a v1.0 of the speedo.
my suggestion is to run the motor manager for the version of speedo you have.
theisgroup is offline
Old 05-06-2009, 03:49 PM
  #327
STLNLST's Avatar
Trader Rating: 30 (100%+)
- Chris
Where's my email sucka????
STLNLST is offline
Old 05-06-2009, 04:20 PM
  #328
- Chris
both but works real good with 17.5
goop is offline
Old 05-06-2009, 04:49 PM
  #329
Hebiki's Avatar
busy trying to get a job. ill get it to you dont worry.
Goop. thanks ill try it this sat in RCGT.
Hebiki is offline
Old 05-06-2009, 06:17 PM
  #330
Goop. thanks ill try it this sat in RCGT. [/QUOTE]
cool let me know what you think
goop is offline
