Ko BMC Speedo
Old 05-04-2009, 12:23 PM
  #301
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Wow setting 6 on timing. I run 0 or 1 in my wheeler lol, usually 0
Hows it working out? And I dont really understand, sending in my esc to KO to get the update gets get the new timing stuff, or is it just a new version of the programmer software on my computer? I havent messed with my esc for like 3 months
BlackedOutREVO is offline
Old 05-04-2009, 01:36 PM
  #302
you have to send in the speedo to get the firmware upgraded in the speedo so you can use the new software. if you dont send it in you will not be able to use the new stock program with 6 timing. also this upgrade fixes all cogging issues.
goop is offline
Old 05-04-2009, 01:42 PM
  #303
Drew Ellis's Avatar
Originally Posted by Hebiki View Post
Drew
what motors are you running now? curious. ill be at tamiya testing the BMC with some different profile and the timing set to "6"
btw.. you going to reedy? if you are.. i'll see you there.. ill be running 13.5 and RCGT.
- Chris
Chris I have been running the EA Motorsports DUO...The timing set at 10d on the motor (middle hole)...On the speedo 6 timing I want to try 5 timing to see if I can run a more powerful profile...Yes I will be at the Reedy...See ya there ...Drew
Drew Ellis is offline
Old 05-04-2009, 02:21 PM
  #304
Hebiki's Avatar
Trader Rating: 26 (100%+)
ok cool.. ill be using the Duo at Reedy (hopefully for both classes 13.5 and RCGT).
did some testing yesterday finally. set the speedo at timing at 6, drag brake at 75 and brake freq at 0.794khz.
temps came off at 140 (at 5mins)...around 150-160 after 7-8mins of practice time with a 13.5 novak motor.
the guy who won 13.5 was using an spx at profile 8. my fast lap was off by 0.1 from his fast lap. so the BMC definitely KEEPS up with the spx AND i didnt blow up any motors.
Hebiki is offline
Old 05-04-2009, 02:42 PM
  #305
you can be faster with the BMC! I have been beating spx guys with it.
GO CHRIS!!
Hi-LowBlow is offline
Old 05-04-2009, 03:16 PM
  #306
goop is offline
Old 05-04-2009, 03:19 PM
  #307
STLNLST's Avatar
Trader Rating: 30 (100%+)
GO CHRIS!!
There will be no bragging about who you beat and with what........that's my job
Drew- If you're reading this.......I'm coming for you!!!!! I still need a heat sink and fan first
STLNLST is offline
Old 05-04-2009, 04:51 PM
  #308
Now that's some good news. Hope to get the ESC back soon.
redbones is offline
Old 05-04-2009, 05:05 PM
  #309
Administrator
Matt M.'s Avatar
if we can get guys to post up the setups they are using it would be great...
i understand the timing, the auto brake,
are you guys changing the steps???? (the stuff in the middle) or just moving thru the profiles??
for my purposes i will start with number 2 with the timing cranked...
how many teeth do you guys think you should go down, when you change timing from 2 to 5 ot 6??
Matt M. is offline
Old 05-04-2009, 07:52 PM
  #310
i put my timing to 6 and had to drop 3 teeth and wow. i tried to upload my settings but rc tech wont let me maybe i can try emailing them to you.
goop is offline
Old 05-04-2009, 07:58 PM
  #311
Drew Ellis's Avatar
Chris you can gear up the motor should be around the 170 to 180 mark after 5 min....Clint I will be looking for you on the track, but if your coming for me that means you are behind me
Drew
Old 05-04-2009, 08:00 PM
  #312
Drew Ellis's Avatar
Chris I forgot you will not want to run for more then 6 min's that way..Or there could be problems with your motor...
Drew
Old 05-04-2009, 08:02 PM
  #313
theisgroup's Avatar
rename the extension to .txt it is basically a text file anyways. that ways you can upload it to rctech. any1 that wants to use it will copy and save with the kpd extension
theisgroup is offline
Old 05-04-2009, 10:48 PM
  #314
STLNLST's Avatar
Drew
You're right....good thing we run IFMAR qualifying
STLNLST is offline
Old 05-05-2009, 12:03 AM
  #315
What cogging issues are there?, is it only for spec motors?. I am using low turn modified and the speedo is smooth as butter with no cogging, it is a v1 speedo, is it worth sending it in and being without it, if i have no issues?
Thanks Ya`All
MoonTrap is offline
