Ko BMC Speedo
Old 12-11-2008, 08:42 AM
  #16
The USB part number is 61018.
The five pre-programmed settings are #1 Power, #2 Mild, #3 Smooth, #4 Touring Car, #5 Buggy. Each has a different drive frequency setting, brake frequency setting, timing, etc.
KO PROPO Staff is offline
Old 12-11-2008, 09:07 AM
  #17
STLNLST's Avatar
Trader Rating: 30 (100%+)
Sweet........I can't wait to get my hands on one.
STLNLST is offline
Old 12-11-2008, 10:24 AM
  #18
RC MARKET's Avatar
Orion Vortex ESC w/heatsink fan & had best price !
http://rcmarket.com.hk/index.php?cPa...a&filter_id=61
RC MARKET is offline
Old 12-11-2008, 01:21 PM
  #19
Rc market do you have a part number for the orion system?
Green Speed is offline
Old 12-18-2008, 06:28 PM
  #20
stankulas's Avatar
any new news on the speedo and how it is doing on the track
stankulas is offline
Old 12-18-2008, 07:18 PM
  #21
Trader Rating: 40 (100%+)
Guys,
I ran the new speedo last weekend and the speedo worked great. What I really liked that we had 5 options to run. I was planning on running 17.5 and 13.5 brushless so Robert from Ko recommended I use setting 1 which is power. The speedo had plenty of power, break, and it was smooth. If you ran Ko product before then you know there product is top notch.
Also you can't beat Ko service. Robert even called me the next day to make sure I had set my speedo right.
Robert Thanks again
King of B Main is offline
Old 12-18-2008, 07:20 PM
  #22
My friend bought one and said it does not use a power capacitor. I think I will get one just for that .
JHIH is offline
Old 12-19-2008, 02:41 AM
  #23
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by King of B Main View Post
Guys,
Robert Thanks again
definitely lots of balls behind this speedo.
ran it in both 13.5 and 17.5...and there's definitely a difference from my "old" BL ESC. now i just need to get my hands on a card so i can program this badboy already.
i LOVED programming the old VFS speedos. once that card comes out, the true potential of this esc will be let loose!
Hebiki is offline
Old 12-19-2008, 09:30 AM
  #24
STLNLST's Avatar
[QUOTE=Hebiki;5185383]definitely lots of balls behind this speedo. QUOTE]
NO COMMENT
STLNLST is offline
Old 12-19-2008, 10:23 AM
  #25
Ike
Ike's Avatar
You guys are more expensive than most of the US retailers I've seen plus shipping is far more expensive...
Does anyone have the exact dimensions of the ESC?
Ike is offline
Old 12-20-2008, 06:32 AM
  #26
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Just wondering if the esc has a lipo cutoff function? (if so, does it need the handheld programmer to make it work?)
Also, does the esc require a power capacitor at all? (ie. when running mod tc? 10.5t, 17.5t)
DirtyDog3375 is offline
Old 12-20-2008, 07:24 AM
  #27
According to the Japanese KO home page under the FAQ section for BMC. http://kopropo.co.jp/wp/?cat=72
They do not recommend it at all. Here is the translation from www.excite.co.jp
"Are an external capacitor and Schottky unnecessary in BMC?
Because it is likely to have the opposite result to what was intended rather in the one to sell present, it is basically unnecessary though the capacitor is effective in the control of fuel cost and generation of heat by the thing. Schottky is also useless. "
Hopefully that helps.
Alex
MobileSuit is offline
Old 12-20-2008, 07:26 AM
  #28
Yes the speedy does have 3 different cut-off setting.
- 4 cells
- 5-6cells
- lipo
Alex
Old 12-21-2008, 03:37 PM
  #29
jsfrcfrk's Avatar
Default cutoff
So what does the the speedo come set at from the factory for voltage cutoff? (Hopefully lipo, hate to spend another $70 to change it)
jsfrcfrk is offline
Old 12-21-2008, 10:50 PM
  #30
ngo8's Avatar
I was wondering the same thing , I got the orion version and i was suprised that there was no cap ,I am using this on my 12 scale with 13.5 ,17.5 ,so can someone confirm that we dont need a power cap??
ngo8 is offline
