Stock Motor Brushes
I'm looking at getting the most power out of my stock motor for a big race - and was wondering what people were using in their 27t stock motors in terms of brushes?
(I'm not concerned about wear - just power!!) Any help/experiences would be great! thanks in advance |
For the most power it is hard to beat Putnam's. I have run them for several years now and can't find anythng better. If you want to buy them in bulk, rc4less.com has them in bags of 10 pair. Only problem is that you normally run green on positive and blue on negative, so you have to buy 2 bags.
Stock Motor Brushes
TC321go;
For EPIC based Stock Motors, 'Putnams' all the way. My ATLAS (Matrix) based Motor(s) however, did not like them at all. You can run Green/Green with the Putnams, slightly more power and Com wear, than the Green/Blue combination. Good luck and go win it for us ! |
When I run Putman brushes in stock TC class, my motor runs awesome for one run. Then I have to recut the comm. The Putman brushes (even the blue ones) seem to chew up the comm pretty quickly. How often are you guys cutting the comm when you run Putman brushes?
what motor do you have in mind for the race?
reedy 767s with a slot do real nice.
Originally posted by Shiloh When I run Putman brushes in stock TC class, my motor runs awesome for one run. Then I have to recut the comm. The Putman brushes (even the blue ones) seem to chew up the comm pretty quickly. How often are you guys cutting the comm when you run Putman brushes? Ive also had good luck with reedy 767s and sureshot serrated hollows. I run the 767s with a hole, and sometimes with a vertical slot |
Originally posted by Shiloh When I run Putman brushes in stock TC class, my motor runs awesome for one run. Then I have to recut the comm. The Putman brushes (even the blue ones) seem to chew up the comm pretty quickly. How often are you guys cutting the comm when you run Putman brushes? |
Originally posted by Shiloh When I run Putman brushes in stock TC class, my motor runs awesome for one run. Then I have to recut the comm. The Putman brushes (even the blue ones) seem to chew up the comm pretty quickly. How often are you guys cutting the comm when you run Putman brushes? Mind you that this is on EPIC Stock Motors that seem to use a harder Copper for the Com than other brands. My Matrix Motors ran slower with the Putnam's and needed the Com cut after a few runs. |
thanks for the great response guys :)
Bubblestc3: The motor I'm looking to use is the Monster Pro... Any further thoughts on springs for the putnam greens?? Do Generally stiffer or weaker springs work well? (I know this is track dependant - just wondering what you've found works in touring car stock?...) again, thanks for your help! :):):) |
hi is Reedy MVP a epic based motor ?
Originally posted by TC321go thanks for the great response guys :) Any further thoughts on springs for the putnam greens?? Do Generally stiffer or weaker springs work well? (I know this is track dependant - just wondering what you've found works in touring car stock?...) again, thanks for your help! :):):) In a heavier TC, Red/Red Trinity Springs provide more Power and Torque in the Monster Stock. |
Stock Motor Brushes
Guys;
Just to add that I've spent many hours Dyno (Robitronic) and Track testing the Putnam Brushes in my Motors. Out of the most popular brands and compounds, I have not found anything that works better in EPIC Motors than 'Putnam's'. Best power with minimal Com wear and Brush life is excellent. *NOTE*: this applies to EPIC based Motors ONLY. My testing with other brands has been limited, but so far I have not seen the same positive results in other Motors. |
hey pops, do you know is the Reedy MVP stock epic based ? thanks
Originally posted by Tag hey pops, do you know is the Reedy MVP stock epic based ? thanks I think all Reedy Stock Motors are 'Yokomo' based. Only had one the 'Rage' and never got it to make decent power. The "Base" manufacturer will be Stamped and/or Molded into the Can or Endbell. |
