Old 10-14-2003, 11:28 AM   #16
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
thanks pops
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 10-14-2003, 11:29 AM   #17
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
Tag sorry the MVP is NOT epic or trinity based.
The MVP is yokomo based for Reedy in the US.
Here's some info for you.
Yokomo builds for Reedy In america
Atlas builds for Integy in america
Epic builds for Trinity in America
Corally is Corally just imported.
Top Builds for Orion/Peak.
Top,Corally,yokomo and atlas are from the same factory.They use different parts but built by the same company.
Epic is made elsewhere.
For a monster stock and onroad try putnams.For offroad I like the Reedy's Better.
For a MVP use 766's with the brush face narrowed like a standup.
Hope this info helps.
If you wanna reduce wear when using Putnam Brushes.Try Tribo lubricant.It wont hurt power and extends comm and brush wear.Good on bearings and bushings as well.
*****Look me up on Ebay. I will have alot of stuff going up as 7/7/2016. User name is Dalracer.**** This is going to be a BIG ONE!!!!!!
Just wanted to say Thanks to RcTech for all these years of Great Information.
TexRacer is offline   Reply With Quote
Old 10-14-2003, 02:02 PM   #18
I use reedy 767's on my monster stocks, p2ks, chameleon 19t, and my element 19t. I have no problem getting good power out of them and you can get quite a few runs on them, especially in stock.
racerdx6 is offline   Reply With Quote
Old 10-14-2003, 04:26 PM   #19
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Originally posted by TC321go
thanks for the great response guys
Bubblestc3:
The motor I'm looking to use is the Monster Pro...
Any further thoughts on springs for the putnam greens?? Do Generally stiffer or weaker springs work well? (I know this is track dependant - just wondering what you've found works in touring car stock?...)
again, thanks for your help!
ok, what i have fund in some testing, and from what racers have told me is that the stiffer the spring the more torque.
the softer the spring the more rpm
same with the brushes, the more surface that is in contact with the comm, the more torque
the less surface that is in contact with the comm, the more rpm
from what i have heard about the putnams, is that they are good, but i have never tried them. I usually run orion, trinity, or reedy in my monster.
i have found that when you are running the orion's you would need to run a little softer springs to get the performance out of them.
with the reedys and the trinitys, i use the same springs for each brush, on fast open tracks i run maybe red/black. on medium tracks, i might run red/green, on tight and twisty tracks where punch is despratley needed, i like to run purple/red
but it is all about gearing, more than the brushes, to make sure that the motor does not get over heated, and keeps it's cool
orion: sprints
reedy: 767s
trinity: 4505s
Bubblestc3 is offline   Reply With Quote
Old 10-14-2003, 04:39 PM   #20
where can i get these Putnam brushes?
lukewilson is offline   Reply With Quote
Old 10-14-2003, 05:16 PM   #21
pro3racer's Avatar
thats exactly what i've been thinking.
pro3racer is offline   Reply With Quote
Old 10-14-2003, 05:59 PM   #22
Ty
Ty's Avatar
Trader Rating: 29 (100%+)
www.rc4less.com has the Putnam brushes.
Ty is offline   Reply With Quote
Old 10-14-2003, 07:05 PM   #23
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Another brush to try is the "Gold" brush from Hurricane Motorsports. Out of all the brushes that I have run in stock motors these are the best IMHO. You can check them out at www.TeamHurricane.net
They also have some of the best com drops for stock motors too.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Old 10-14-2003, 08:26 PM   #24
TC3Racer67's Avatar
Send a message via AIM to TC3Racer67
when you guys say runs, do you mean like one heat? would that be conisdered one run? thanks, just wondering when to replace brushes/cut comm, i'm looking into getting a lathe. thanks for the help.
TC3Racer67 is offline   Reply With Quote
Old 10-14-2003, 08:43 PM   #25
fatdoggy's Avatar
R/C Tech Charter Subscriber
TC3Racer67 - Yer generally just a 5 minute heat.
fatdoggy is offline   Reply With Quote
Old 10-14-2003, 08:49 PM   #26
TC3Racer67's Avatar
thanks
Old 10-15-2003, 12:09 PM   #27
I generally will cut a stock motor after about 7-10 runs. If you wait too long than there will be a lot of wear on the comm and you will have to cut off quite a bit so the comm is nice and smooth again.
Old 10-15-2003, 12:51 PM   #28
gcooper's Avatar
Originally posted by popsracer
I'm getting about 12 runs between Com cuts, and re-serrate in between.
Pops,
What kind of serrater do you use and what is your Technique. Are there any diagonal serrators out there yet?
Coop
gcooper is offline   Reply With Quote
Old 10-15-2003, 04:29 PM   #29
popsracer's Avatar
gcooper;
I am using the serrator by Pro-Match availible from KT Hobbies
I reserrate between race days and can usually get up to 24 runs out of a Pair of Putnam's before they are noticably shorter (1/16" ?)., so about 2 rebuilds worth. Just follow the serrator instructions for the technique. It usually only take a few seconds for each Brush and they don't even need to removed from the Hoods.
popsracer is offline   Reply With Quote
Old 10-15-2003, 04:36 PM   #30
popsracer's Avatar
Default Diagonal Serraters?
Guys;
Good point, but after thinking about it, I don't thing traditional serrating methods (spinning cutter) can be used to achieve diagonal serrations.
Any modern day Machinist's out there care to comment ?
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 11:22 PM
19 TURN MOTORS, STOCK MOTORS, 767 BRUSHES, F BRUSHES, 2 MOTOR CASES LOSIMANJRXS R/C Items: For Sale/Trade 47 10-21-2006 06:06 AM
Stock motor brushes impdog Electric On-Road 29 06-09-2005 12:53 PM
Stock Motor Brushes gporta77 Electric On-Road 1 11-04-2003 05:56 PM
Stock Motor Brushes Carbon_Fibre3 Electric On-Road 10 05-25-2003 12:55 PM
