Considering getting into electric, need some advice on chargers >
Old 10-18-2003, 10:32 PM
  #76
Originally posted by sausage_link
If i were you AE racer i would buy an external power supply as well. The reason being because the external power supplies are powerfuller and can handle the spikes and will filter the power that gets to your charger.
Notice how all the people who say there charger false peaks when it runs off the internal supply.
I use a modded 250watt power supply and i have successfully run a car amplifier, and 2 chargers at the same time off it.
Intergy says "It has an internal 14 Amp switching power supply (18A peak output), 16X9v9's internal 14A power supply is powerful enough to operate the INDI Dyno, together with the INDI Dyno, you can check motor rpm, break-in motors and drive lathe motor." It sounds to me like this charger has their 14A SHE powersupply built into it and thats the power supply I was planning on getting anyway. I would perfer to go seperate, but I can only afford to if I buy it from hk (it will actually be cheaper) but I dont want to be stuck with no warrenty.
AE Racer is offline
Old 10-18-2003, 10:33 PM
  #77
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
On another note and someone please correct me if I am wrong...
If you buy a cheap power supply as opposed to a descent "clean" power supply (a supply with good filters used for ham radios, etc etc) your batteries don't get a very good/clean charge or so I have heard... Popsracer have you any info on this?
minicooper is offline
Old 10-18-2003, 10:38 PM
  #78
I dunno the 14A SHE power supply dosnt look cheap to me, intergy sells it for $138 but I can get it for $80 if I order from HK.
AE Racer is offline
Old 10-18-2003, 10:43 PM
  #79
minicooper's Avatar
Well, putting price aside.... by cheap I meant not providing a clean supply of power
Old 10-18-2003, 11:00 PM
  #80
Im thinking I should probably get a seperate charger and power supply the two of the would be easier to carry than the 16x9v6, I saw a picture comparing it with the 16x5v6 and the thing is huge atleast if I had two seperate units they would be able to fit in a toolbox. I sent Intergy an e-mail asking if they support Eagle products, I hoping they do because I cant find the 16x5v6 for a decent price in the US.
heres the comparison pic:
AE Racer is offline
Old 10-18-2003, 11:51 PM
  #81
forty6's Avatar
Well if you are really serious about getting into electrics, I suggest buy the best stuff you can afford with your budget. Buy cheap now, then you will end up upgrading later, thus spending more. People here have given you very good options, the 16x5v6 for one. I think most of the reputable companies sell it for $189.
forty6 is offline
Old 10-19-2003, 01:53 AM
  #82
cHckbOY5's Avatar
do u recommend the yokomo bcs-s compact? or indi 16x5v6? or indi 16x7v6?
cHckbOY5 is offline
Old 10-19-2003, 05:45 AM
  #83
sausage_link's Avatar
Yeah i just saw the BCS-s
It looks alrite. But i think i'm going to get a CDC v6.
Shyt how big is that 16x9v6...
sausage_link is offline
Old 10-19-2003, 10:03 AM
  #84
holycow's Avatar
Originally posted by Evoracer
Hey !!! somebody give us some help and answer my last question.
You dont need a power source to discharge something, it is simply a huge resistor.
I have an integy 16x7 which does 6amps up and 30amps down, and I run it on a 10amp power supply, and I discharge all day.
holycow is offline
Old 10-19-2003, 10:20 AM
  #85
cHckbOY5's Avatar
wats a cdcv6?
cHckbOY5 is offline
Old 10-19-2003, 12:45 PM
  #86
forty6's Avatar
Integy 16x5v6
forty6 is offline
Old 10-19-2003, 01:01 PM
  #87
TFR
TFR's Avatar
I wanted to try the CDC V6.0 as well, but my CE Pitbull have been flawless so far, no problem what so ever...
TFR is offline
Old 10-19-2003, 01:06 PM
  #88
Power supply supplying a set rate of power now if the rate flexuates while you are using it your equipment may experience problems(False peaks,overload,ect)so a power supply that is said to be clean delivers a solid rate of out put no mater what the imput voiltage
the shoe is offline
Old 10-19-2003, 01:16 PM
  #89
So AE racer, what do you have in mind after all these post?
ZER01 is offline
Old 10-20-2003, 12:25 AM
  #90
Most chargers say what voltage ranges they use... like 11.5 - 15
