Old 12-08-2008, 08:58 PM   #1
CCH1978's Avatar
Trader Rating: 27 (100%+)
Default how to wire a trinity dou motor
Hi guys I just bought an 12th scale associated 12r5 car and it has a trinity duo brushless motor and novak gtv 4cell speed control, but being that im new to this I have no idea of how to wire the esc to the motor, any help would be much appreciated.
thanks in advance
MINI REVO Mamba Max Pro NEU POWERED
THE BEATINGS WILL CONTINUE UNTIL THE MORALE IMPROVES
BEAST MODE (ON) OFF
CCH1978 is offline   Reply With Quote
Old 12-08-2008, 09:03 PM   #2
Trader Rating: 23 (100%+)
have the end of the motor facing you. blue yellow orange. it's like this on your speedo too
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 12-08-2008, 09:21 PM   #3
CCH1978's Avatar
thats weird because i have like that but cant get it to do anything....does the sensor cable need to be hooked up also because I thought on the duo u could use it with or without the sensor
BEAST MODE (ON) OFF
Old 12-08-2008, 10:13 PM   #4
Yeti35's Avatar
If it is a sensored speedo you need the wire for it to work.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 12-08-2008, 10:24 PM   #5
CCH1978's Avatar
thanks guys
BEAST MODE (ON) OFF
Old 12-09-2008, 01:38 AM   #6
Does 12 gauge wire fit easily into the terminals holes? Is that the preferred way to wire it up or some other better way?
stocker is offline   Reply With Quote
