Old 12-08-2008, 07:17 AM   #1
sosidge's Avatar
Default Setup - what do YOU work on first?
Just thought I'd start a little topic on setup routines.
First time on a track with a new car or new tyres - what handling trait you focus on first? And what are your favoured settings to change?
Personally speaking (assuming tyres are controlled), I tend to work on the off-power turn-in of the car. I like to get it to do a nice smooth arc into the apex, with the car "squared off" and ready to put the power down for the exit - to my mind, everything else follows from there.
Normally I will start off by adjusting front spring rate. Then damping. Then I might change some roll centre shims. Finally I might add a bar if the track is smooth. I almost never change shock mounting position or ackerman or ride height.
When I'm happy with that, I will take a look at corner exit, trying to keep everything on the car balanced (no extreme differences in geometry or shock settings between the front and rear).
Over to you...
Old 12-08-2008, 07:58 AM   #2
I12PonU's Avatar
Trader Rating: 10 (92%+)
Balance and tweak for me.
I12PonU is offline   Reply With Quote
Old 12-08-2008, 08:07 AM   #3
Andy63's Avatar
I start with checking the strack. if it similar to the track i was racing at before i will keep the setup i have on the car.
If the setup doesnt fit for this track i will begin with checking ride height and softness and hardness rear and front. If i want to fine tune i will change springs, oil or someting like camber, caster etc. Depends how the track feels and then i know what to change.
But Tweaking is what i do after every run.
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 12-08-2008, 08:16 AM   #4
PartTime's Avatar
My car is balanced and tweak set before I get to the track.
First up is expo and d/r. Then I look at the high speed/on thorttle sections to get the car to work. Then fine tune the infield. Could be somthing simple like adjusting the wing or getting dirty and redoing shocks.
Mostly what ever jumps up first gets tuned. But allmost always on-power is what Im looking for.
DK
PartTime is offline   Reply With Quote
Old 12-08-2008, 08:30 AM   #5
minimusprime's Avatar
Trader Rating: 19 (100%+)
tweak
tires
springs
sway bars
roll centers
camber/caster adjustments
dampening if necessary
typically by that time i've got a setup that is close enough where all i need to do is throw some spacers in a few key places and i'm g2g.
of course i always show up to the track with a guestimated setup... typically i find that i only mess with roll centers and camber etc from that initial point.
"I personally do not believe in luck. I believe luck is just an excuse for people that have failed in their mission to accomplish something." Allen McNish
minimusprime is offline   Reply With Quote
Old 12-08-2008, 09:35 AM   #6
chicagokenji's Avatar
Tweak.
Specifically how do you guys check for tweak?
chicagokenji is offline   Reply With Quote
Old 12-08-2008, 10:30 AM   #7
PartTime's Avatar
Originally Posted by chicagokenji View Post
Tweak.
I get my car balanced left/right. Then i set ride height all the way around the car. Drop it on the tweak board and finish it off. Done.
DK
Old 12-08-2008, 10:44 AM   #8
joe of loath's Avatar
I just drive a few laps and see what does and doesn't work. I then correct those problems in the order they arise. It's not very scientific but it works
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
KARZ Calgary xrayroooahhhh Canadian R/C Scene 19114 12-01-2017 01:26 PM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 09:13 PM
Spektrum DX3R Discussion Thread MadRacer Radio and Electronics 2015 05-10-2017 01:45 PM
Four Seasons R/C Racing Hackatack Northwest Racers 6862 09-09-2015 04:46 AM
Brushed / Brushless setups deRRo Electric Off-Road 46 02-23-2008 05:48 PM
Moorebank Michael_T Australian Racing 1255 02-19-2005 05:12 AM
