battery HELP on lst2 losi mini
i just purchased the mini losi lst2 it has the stock Losi 1100mA pack, my question is can i use a battery i already have its a 8.4 2600mA it doesnt fit in the truck ,it made for the mini t truck but i can retro fit it ,i need to know if it will cause any damage if i choose to use it .here are the battery stats
FEATURES: * Voltage: 8.4v * Cells: 2600mA AA NiMH * Discharge rate: 8 amps * Connector: standard Losi Mini-T * Wire: 18ga fine strand silicone * Size: 3.00" X 1.93" X .56" * Weight; 7.0oz * Voltage: 8.4v * Cells: 2600mA AA NiMH * Discharge rate: 8 amps * Connector: standard Losi Mini-T * Wire: 18ga fine strand silicone * Size: 3.00" X 1.93" X .56" * Weight; 7.0oz |
