Old 12-04-2008, 04:41 PM   #16
J_P
J_P's Avatar
Originally Posted by Rick Hohwart View Post
I am not so sure. It would be interesting to see what a 129.00 brushed stock motor could do.
LOL! I'd like to see that.
JConcepts * Associated * Reedy
J_P is offline   Reply With Quote
Old 12-04-2008, 05:06 PM   #17
Trips's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Francis M. View Post
Are you sure that the only variable was the speedo and motor settings? Did you end up finding the right gearing for the balance of temp and speed? as for the 3/10ths, most people will go 3/10ths faster if they spent the whole day putting laps in....
I'm nothing if not methodical... the change was not the result of putting laps in all day. I'd already driven hundreds of laps on this layout. I even went back to sensored only mode to be sure, and couldn't get the same lap times as hybrid mode until I got the motor running 170 degrees. Backing off the gearing or timing just slowed me down. In hybrid mode I could do the same fast lap times and come off at 131 degrees. Each test run was off a freshly topped up LiPO pack and I ran 2 minutes each time. Three laps to get the tires warmed up, then hot laps for the rest of the two minutes. Looked at the best lap times and averages.
MARSHAL!!
Trips is offline   Reply With Quote
Old 12-04-2008, 06:55 PM   #18
People have been tweaking 24 degree stock motors for years! A locked endbell just made it more difficult to crank up the timing. You could get between 5 and 8 degrees of timing on a 24 degree motor before the comm lock snaps. I know it because I experimented with it when the 24 degree motors came out (I hated to have to throw a perfectly good Tweak Bar away).
bshack is offline   Reply With Quote
Old 12-04-2008, 07:29 PM   #19
Originally Posted by Trips View Post
Why not indeed? Although I'm looking for parity, some may think that bearings would swing the balance in favor of brushed over brushless... I'd settle for just allowing timing changes, but I'll also ask about bearings.
We happen to have a regional this weekend, I'll take this up with our region 1 director and see if he thinks it might be a good idea.
I've been wondering about bearings myself for some time now...20 some odd years ago when the rules were originally written the cost difference between bushings and bearings would have greatly increased the cost of the motor...today the difference is so minor there is no reason to switch to bearings other then that is the way it has been done for so many years now.
Old 12-04-2008, 07:30 PM   #20
Originally Posted by seaball View Post
i think we'd be more likely to see brushless motors becomming locked before going the other way with the 'old standby'. why did the b/l market adopt variable timing on all motors to begin with? (admittedly, i haven't been paying much attention to any of it).
i think running b/l right now is actually a tough task, because most r/c'ers are too lazy, or unaccustomed to a methodical approach, to test all the combinations (gearing vs. timing vs. esc settings).
it's a wierd thing to hear everyone still rejoicing about not having to cut motors anymore, when they now have an entire system of variables to figure out. add to that the lipo of the month program and various firmware upgrades, and it sure seems like more work to me. (barring running modified)
i guess this turned into more of a rant, but the idea made me feel like modernizing our horsepower over the last year has actually made racing much more complicated than it was (which a majority of racers were already complaining about). you might argue that it's quite a bit more expensive as well. (motors, esc's, lipo's and the general life cycles right now) ...
Even that would be moot though as many BL ESCs have electronic timing adjustments.
Old 12-04-2008, 07:36 PM   #21
When I got my Tekini RS everyone at the track told me to run it in Sensored only mode and crank the motor's timing to full on the endbell. I spent a day playing with different settings and now run it in hybrid mode, timing at 100% ini the software, endbell timing backed off, and I'm going three tenths faster a lap and 39 degrees cooler than I could in sensor only mode.
I thought about trying that as well. Originally I ran mine in hybrid at 80% timing which was the reccomendation at the time. When people switched to sensored only mode I gave it a try and haven't gone back because of the brakes...in hybrid mode on my 1/12th pan car I pretty much had no brakes at all. Now in sensored I have the amount of brakes I want. Did you notice any loss in brakes when you went back to hybrid?
Old 12-04-2008, 09:19 PM   #22
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
We already have guys installing bearings in stockers here for club racing.Fine with me , The only real gain is the bushings dont wear out before the comm is trued down to far so it just means that they dont have to switch arms and cans around because the arm in a motor is still good , but the bushings are shot.so it saves them some $$ not having to buy new motors just for the fresh can and bushings.
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 12-04-2008, 10:47 PM   #23
Moderator
Clegg's Avatar
I just dont see many people buying those lipo of the month or all the fancy gauss meters and crap at local club races. The people who do are doing it because its a crutch to make them faster without them learning to be faster, or they are just that damn good that they can use that extra power and not put it in a wall. Which if that is the case they are in the upper 1- 5% of all R/C racers I'd say, and you shouldnt really care what they are doing... because you arent them.
For the other 95% of us... that micro second of extra power or firmware crap... really doesnt mean shit when you end up on your lid on lap 2 or pile it into the wall with your ultra fast car.
Brushed motors are very much on their way out... they are not coming back, its ancient and inefficient technology. Postponing the death is the only thing you are doing.
This thread sorta reminds me of the Trinity "OMG Brushless are scary" ad a few years ago FUD rocks.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 12-05-2008, 12:18 AM   #24
Trips's Avatar
I can't say I noticed a loss of braking in hybrid mode... Not that I'm using much brake at all... I run rubber tire 17.5 TC on carpet with the RS, and a oneway in front means I'm not braking much at all. When I do hit the brakes, the car stops pretty smartly. I don't have the brakes maxed out, and I could probably turn em down some to actually make them usable...
D
MARSHAL!!
Old 12-05-2008, 12:56 AM   #25
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Actually...if you're referring to seaball...yeah, he is.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 12-05-2008, 01:06 AM   #26
ottoman's Avatar
ottoman is offline   Reply With Quote
Old 12-05-2008, 08:34 AM   #27
Moderator
Clegg's Avatar
I was talking about the OP -'Trips'
and really if you are in that top 5% of the racers... you probably arent too concerned with the lipo of the month, or investing an amount equal to the GDP of a small country into a toy car.
Old 12-24-2008, 03:01 PM   #28
Bob-Stormer's Avatar
Not to dig up an old thread, but, "E" and I talked about this a few times. Why didn't you guys give it a go? Millions of brushed speedo's out there... nobody pursuing it...
www.stormerhobbies.com "Where the world shops for radio control."
www.facebook.com/stormerhobbies
www.twitter.com/stormerhobbies
looking for....vintage 1/10-1/12 pan, need Schumacher 1/12th cars and parts.
Bob-Stormer is offline   Reply With Quote
Old 12-24-2008, 03:07 PM   #29
Rick Hohwart's Avatar
The main reason is that it could not be ROAR legal. Normally this should not make a difference because most tracks and races don't use ROAR rules except when it is convenient.
I think most tracks and racers wouldn't allow it and choose this ROAR rule to enforce.
Rick Hohwart is offline   Reply With Quote
Old 12-24-2008, 03:18 PM   #30
Didn't stop Novak when it started with brushless did it?
Tell Traci we said "Merry Christmas". To you as well.
2003 Roar On-Road Carpet Nats at TCHR !!!! Mark O'Brien Minnesota and North/South Dakota Racing 261 09-23-2008 02:19 PM
ROAR B/L motor Rules debate thread C_O_jones Electric On-Road 1080 01-21-2008 08:00 PM
EFRA decision. 5 cells -1350gr CAi Electric On-Road 466 01-09-2007 02:55 AM
ROAR to 4 cell.... Advil Electric On-Road 1394 12-21-2006 10:50 PM
MARCH 17-20,2005 ROAR ON-ROAD CARPET NATIONALS AT HOBBY CHAMBER Hobby Chamber Racing Forum 643 04-01-2005 04:40 PM
