KO Precious EX 1 !!HELP!!
Hey guys i was just wondering if you could help me out, i have a friend who bought a KO Precious EX1 not the Mars. Anywayz it didnt come with the manual. I was wondering if someone can teach me how to reverse the servos because i cant seem to find a menu that will enable it to be reversed. Any help would be appreciated.
Dont know that model, but on the EX-11 Presto, you do it like this:
Press and hold the "Select" button. Simoultaneous, press the "Func" button.
Now the radio is in "System mode/menu"
Each time the "Func" button is pressed, there's a new feature. On the EX-11, Reverse is the first.
To leave the "System mode/menu", press and hold the "Select" button. Simoultaneous, press the "Func" button.
Hope this help.
Hope this help.
With the radio off, hold down the two middle buttons while switching the transmitter on, that should open the SYSTEM MENU, scroll untill you see ST REV/NOR( I'm pretty sure that's what it says), that should be steering servo reverse throttle is labled TH REV/NOR. Hope this helps, but it's been along time since I used a Precious.
Common guys i really need a hand here. KO Guru's
Turn radio on
press and hold bottom 2 buttons on
at same time press top right button....now scroll through using up or down button until you find this screen.
REV. SW
ST:NORM
if it has TH instead of ST press the select key and it will change to ST
now using the +/- key you can change back and forth NORM/REVERSE
hope this helps
REV. SW
ST:NORM
hope this helps
Originally posted by Schukomo
Turn radio on
REV. SW
ST:NORM
hope this helps
Turn radio on
REV. SW
ST:NORM
hope this helps
Thanks very much for your help.
And for everyone who contributed on helping thanks very much
