Novak GT7 info..... >
Novak GT7 info.....
Novak GT7 info.....
Old 10-09-2003, 04:01 PM
gcooper's Avatar
Default Novak GT7 info.....
I just got a GT7 as a gift. Instead of selling it or re-gifting it, I decided to give it a go. I have been running Cyclones as well as other speedos.
Probably what I am looking for is some good tips or setups on the GT7 for 19t and 27T carpet/pavement racing?
Thanks,
Coop
gcooper is offline
Old 10-09-2003, 04:02 PM
Moderator
StephenSobottka's Avatar
run the recommended profiles.
StephenSobottka is offline
Old 10-09-2003, 05:21 PM
black-knight's Avatar
i would run the GT7 on profile 4 or 6 for either 19t or 27t.
black-knight is offline
Old 10-09-2003, 08:06 PM
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
if you will be running one-way i suggest you run profile 7 and disable the drag brake..
Tag is offline
Old 10-09-2003, 10:15 PM
Korey Harbke's Avatar
I'm in the market for a new ESC. What do you guys think of the GT-7?
-Sushi Boy
Korey Harbke is offline
Old 10-09-2003, 10:32 PM
gcooper's Avatar
So for carpet do you suggest profile 7 minus drag brake... I am running an shaft with a 1-way, usually I use very little drag-brake.
Coop
gcooper is offline
Old 10-09-2003, 11:47 PM
Tag
Tag's Avatar
it is agreed that GT-7 is a much improvement then its predecessor cyclone, very smooth power band and profiles can be selected without a external device. not to mention thier top notch customer service. I own one and love it !
Tag is offline
Old 10-09-2003, 11:50 PM
Tag
Tag's Avatar
it's all personal preference i guess, for me, i do not use any brake or drag brake with one-way. i usually let go the throttle and let the car roll through the corners
Coop
Tag is offline
Old 10-11-2003, 06:21 AM
gcooper's Avatar
I usually do the same. I use very little drag and usually mess with the brake curve on my radio to fine tune it. Although with my current car I am debating on going back to a front ball diff. Not that I cannot control the 1-way but with the efficiency of a shaft wondering if I could be faster without it.
I guess my PTS will show me if I am right.
Coop
gcooper is offline
Old 10-11-2003, 07:08 AM
Corey Bernardo's Avatar
For stock you should run profile six and for modified I would run profile 4.
Corey Bernardo is offline
Old 10-11-2003, 10:30 PM
gcooper's Avatar
Do you think 6 would be too much for a carpet/rubber/chameleon setup?
Coop
gcooper is offline
Old 10-12-2003, 07:34 PM
adrian's Avatar
imho the gt7 is the best out there
adrian is offline
Old 10-12-2003, 09:00 PM
I agree Corey, 6 is a good profile for stock, I've also tried 7/1 for stock but it seemed like I was missing a little top end.
ZER01 is offline
Old 10-27-2003, 03:32 PM
Peter Busch's Avatar
Is there anything special about the Schottty diode on the new wire harness? I would prefer to solder on my own Schotty because it makes for a cleaner wire job.
Peter Busch is offline
Old 10-27-2003, 03:47 PM
SlobbaTech's Avatar
The schotty that is prewired and shrink wrapped is different, can't remember how strong it is (like 2-4 normal schotty) but Novak sells them seperately if need be.
SlobbaTech is offline
