Old 11-30-2008, 08:16 PM   #1
artwork's Avatar
Trader Rating: 62 (100%+)
Default LRP Sphere Comp Timing
Some of us at the track today were discussing the differences between hardware and software timing of brushless motors. We were wondering if anyone has any idea how much software timing was being advanced in the different settings on the Mode 2 (ADPC) function on the LRP Sphere Competition?
There are 8 possible settings, but it is unclear how much the motor is being advanced or retarded in each of the settings? Has anyone done some research on this topic that might have an idea. I would call LRP, but my German sucks!
It is clear that timing is being advanced based on the LRP Note that says: Do not advance the mechanical timing on settings 3-6...blah blah blah. I am just not sure how much!
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 11-30-2008, 08:20 PM   #2
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey artwork,
Im not sure if Im right but I think the LRPs have what they call a automatic timing. I think its 30* but I could be wrong. I would call up Assocaited and ask about it.
I know its not much info but I hope this helps.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 12-01-2008, 01:45 AM   #3
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
I personally would like to know how software timing differs from hardware timing because I was having this debate with a friend the other day.
We really need an LRP specific thread on here like other companies have with a rep to answer all our questions. "burito" works for LRP, maybe we should all start bugging him? hehe :P
-Mark
mok is offline   Reply With Quote
Old 12-01-2008, 02:38 AM   #4
burito's Avatar
The "timing question" for our speedos is not something which we are willing to explain at this stage and therefore I can not answer the question. Sorry!
But as far as I know our system is still superior then the others...
As for an "Ask LRP" thread, I do unfortunately have only very limited time on these forums and I'm worried I'd be too slow with my replies (especially when I'm away at races) which could result in frustrated customers.
Reto Koenig
burito is offline   Reply With Quote
Old 12-01-2008, 07:47 AM   #5
artwork's Avatar
I do understand that this is something that might be proprietary to LRP, but in the quest to find the right setting on my LRP in conjunction with the motors I am running this type of information could be very helpful. Through some research I have found someone claiming that on setting 8 there is 20deg of timing, but I am just not sure that is true.
Thanks for responding!
Old 12-01-2008, 07:51 AM   #6
Interesting......
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 12-01-2008, 08:46 AM   #7
mok
mok's Avatar
Originally Posted by Gitsum View Post
Interesting......
+1
ya know i'm going to take a stab at this and guess whats going on with "timing" (still not sure thats the right word to use)
here's facts I have at hand and can remember..
LRP motors are labelled with a range from 0 to 8, increments of 1
LRP motors are set by default at a "timing" of 2 on the motor can according to the label
LRP 3.5T manual says not to change the default timing from 2 for that motor (this bit i had always wondered why, but never changed it)
LRP "stock spec" motors appear to be locked at 2 degrees timing on the motor itself
here's what i'm concluding..
the default of 2 on the motor timing could correspond with the ESC base timing figure
it is possible that the base timing figure could be 22, which with the motors base timing of 2 would give 24 degrees of "timing" (a figure we all know and love!)
the 3.5T motor may draw too much current when set at a timing higher than this theoretical 24 degree timing, other motors not so much.
and lastly, the range of timing available with an LRP motor and LRP ESC could be 22+0 to 22+8 or 22-30 degrees.
what a theory!
-Mark
Old 12-01-2008, 07:54 PM   #8
mok
mok's Avatar
understandable
Old 12-02-2008, 08:38 AM   #9
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
So for LRP Speedo's we're not supposed to adjust the timing mechanically? What is the setting we should use on or motors? 0* or what?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 12-02-2008, 09:33 AM   #10
I wouldn't say that. It depends on what works best for you. I invariably run program 3 on my LRP TC speedo and use the timing on the motor to fine tune. But then that is me running mod. For stock and possibly super stock I would probably use program 8.
As to the programs on the LRP speedo's, I can understand Reto not willing to divulge details. I am quite certain the difference between the programs is not solely timing. I can imagine variable timing settings at different throttle levels, different frequencies (also at different throttle levels) and several other parameters that may differ from program to program. Meaning with the timing on the motor you solely change that while changing program changes more than just the timing.
Tony Vredenberg
tonyv is offline   Reply With Quote
Old 12-02-2008, 02:30 PM   #11
BobbyS's Avatar
I took my LRP 13.5 apart the other day and can't get the 'end bell' part or the internal piece to move. (Screws are all removed.) How do I remove the interal piece and how does one go about setting the timing?
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Old 12-02-2008, 06:05 PM   #12
mok
mok's Avatar
Would that LRP 13.5 be a stock spec with the orange timing ring?
If so, timing appears to be locked at 2 degrees on the motor without the ability to alter them.
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
Old 12-02-2008, 08:11 PM   #13
BobbyS's Avatar
It is! Any way to remove the inside from the can?
Old 12-03-2008, 07:18 AM   #14
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
I have an original "Sphere Brushed/Brushless" ESC, and there are only 3 throttle profiles.. Sportsman, Low Traction, and Modified..
What are their equivalents to the newer Spheres with 8 modes? I have a 13.5 and 17.5.
-=≡ Tamiya TA05 · TRF415MSX · F103R · M-03R · M-04 · M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 · OFNA LD3 Pro · Fastcats · Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 12-03-2008, 05:25 PM   #15
tom235's Avatar
tom235 is offline   Reply With Quote
lrp spx stock spec chuckharrisjr Electric On-Road 1131 02-22-2017 11:58 PM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
Ask Steve "The Evicerator" Weiss TeamButter Electric On-Road 7088 07-16-2011 06:01 PM
LRP SPHERE COMP. ESC (80700) Miu Miu Electric On-Road 725 07-08-2010 04:42 PM
The One True 13.5 Thread syndr0me Electric On-Road 713 02-02-2008 02:53 PM
