Old 11-30-2008, 05:45 PM   #1
dvu
Default Gearing Question
Hello,
Had a gearing question. I'm putting together a Kyosho TF-5 Stallion. The spur gear t comes with is a SPUR GEAR(64P-106T/TF-5 STALLION). Can someone help me fgiure out which pinion gear I need to buy. I went to www.gearchart.com, but am not sure how it works. I know I need a 64 pitch pinion gear, but also not sure what brand and where I should buy froim.
Thanks, Duc
dvu is offline   Reply With Quote
Old 11-30-2008, 06:15 PM   #2
revo523's Avatar
What motor you running? are you bashing or racing?
revo523 is offline   Reply With Quote
Old 11-30-2008, 07:23 PM   #3
dvu
I'm using the Novak Velocity 5.5R brushless motor. Not really bashing or racing, just messing around.
Old 11-30-2008, 07:43 PM   #4
revo523's Avatar
well if its not racing its bashing! lol!
http://www.teamnovak.com/tech_info/b...r_gearing.html
check out the recommended gear ratio you should be running.
Old 11-30-2008, 07:46 PM   #5
MaxSp97's Avatar
Hello,
Thanks, Duc
Duc,
Novak is rec. FRD 8.5 for your motor. The pinion you need it 31T.
Robinson Racing 64 Pitch 31 Tooth Black Aluminum Pro Pinion
Part Number: RRP4331
Check with your LH.
Cal,
MaxSp97 is offline   Reply With Quote
Old 11-30-2008, 07:49 PM   #6
dvu
What am I doing wrong. When I go to gearchart and calculate to get a FRD close to 8.5, the pinion I come up with is 23T. I've never done this before, so I'm sure I'm missing something. Any thoughts?
Old 11-30-2008, 07:54 PM   #7
revo523's Avatar
It says you should be running a fdr of 8.5 so divide your spur and pinion and multiple that by your car internal drive ratio so.
106/22=*1.83=8.81
Thats the closes you can get it with that spur gear.
Old 11-30-2008, 07:58 PM   #8
revo523's Avatar
Originally Posted by MaxSp97 View Post
Duc,
Check with your LH.
Cal,
Im i doing something wrong here? When you go to the gear chart and do it with that 31 pinion it give a gear ratio of 6.26. im lost!
Old 11-30-2008, 07:59 PM   #9
dvu
Thanks!!!
Tamiya TB-Evolution IV gtypecanare Electric On-Road 3600 11-03-2017 01:06 PM
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 11:20 PM
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-06-2012 12:35 AM
Ask Steve "The Evicerator" Weiss TeamButter Electric On-Road 7088 07-16-2011 06:01 PM
Simple Orion V2 Question Cain Electric On-Road 38 08-06-2004 08:12 AM
How to make the EP touring racing scene hot (if it ever was considered hot) again?? Kenneth Tan Singapore R/C Racers 212 04-25-2004 09:04 PM
Another gearing question Elk666 Electric On-Road 6 05-02-2003 09:50 AM
