Old 11-29-2008, 01:26 AM   #1
05forfun's Avatar
Trader Rating: 81 (100%+)
Default How tight the ball diff and belt should be?
Can any one share how you adjust your ball diff and belt. How tight/loose is appropriate?
05forfun is offline   Reply With Quote
Old 11-29-2008, 01:33 AM   #2
stiltskin's Avatar
Trader Rating: 102 (100%+)
What kind of vehicle? 1/10, 1/12 ? For 1/10 scale I tighten it until is doesn't slip after the initial build or rebuild. I'll tighten the front a little more if I want more pull through the corners and leave the rear as is. As long as it doesn't slip and spins freely, I'm usually happy. Are you racing at Debbies?
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 11-29-2008, 01:36 AM   #3
05forfun's Avatar
My car is Tamiya TA05R
Old 11-29-2008, 01:48 AM   #4
tc3team's Avatar
I have the front belt on my 05 set quite loose, its probably got that way from the spool up front, the rear belt is a bit tighter. Providing the belts dont skip their teeth, the looser the better usually, it's a bit like the spur and pinion gear mesh, as it never pays to have them set overly tight.
Diff's, well as long as they dont slip you're pretty much good to go. hold the diff and one wheel whilst trying to turn the other wheel on the same end, if it turns with little resistance, its too loose. It should take a "reasonable" amount force to turn the other wheel, I can't really describe it over a forum.
hth
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 11-29-2008, 01:50 AM   #5
05forfun's Avatar
How about the belts. I used to install them tight but not very which you can press down and feel the tension. But my friend runs his 416 with very loose belts, so loose that I feel that they might come off the pulley, but he is a good racer and won some races. So according to his experience, a little loose is good?
Old 11-29-2008, 02:10 AM   #6
tc3team's Avatar
The tighter the belt, the more resistance there is usually. If you dont tap the boards or in general crash much, you shouldn't have any issues by having it set a bit looser
Old 11-29-2008, 03:31 AM   #7
stiltskin's Avatar
Sorry, forgot about the belts. Mine are pretty loose. I run them tight enough to prevent skipping but as loose as possible. Loose belts will free up the drivetrain and allow more top end, while tighter belts will provide a little more torque while giving away some speed. If you're running at Debbies, the current layout should allow you to tighten them up a little since there isn't a long straight. Talk to Dave if you get the chance. He's the Philipino that looks Mexican. Tell him I said that too.
Tony Rumple
Old 11-29-2008, 06:42 AM   #8
chicagokenji's Avatar
HA! You throw Asian jokes around in VA?
I thought we only did that in the Chicago area.
chicagokenji is offline   Reply With Quote
Team Magic E4 Thread gansei Electric On-Road 4124 02-07-2017 02:09 PM
XX-4 Forum knucklebusta Electric Off-Road 4036 06-10-2016 06:15 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Team Magic G4RS 2009 gtrmx Nitro On-Road 1712 03-31-2014 07:39 PM
New to electric touring ... TC4 + brushless ... tips ? Tabushi Electric On-Road 9 07-22-2008 09:22 PM
How to make a Ta04 more free Aidz Australian Racing 16 03-25-2004 04:41 AM
