Advice on traction rolling?
How about tightening your front suspension.
Your car is traction rolling because obviously you have too much bite.
What tires are you using and on what surface?
decrease your droop and/or triger finger...
Trader Rating: 32 (100%+)
Lay the shock down on the tower and add more front camber....stiffen the front sway bar.
Limiting droop is the way to go ! It's very effective when it comes to traction rolling.
Just about everything mentioned sounds good. You might want to add harder tire inserts (if you're not using pre-mounts) to the list...
It's a much easier problem to solve then too little traction! All the above are good suggestions, th only other thing I can suggest is slow down round the corners
Ok we bombarded you... Just try one thing at a time... Don't do them all at once...
Guys;
TOO MUCH traction and you're advicing him to SLOW down!!
STIFFEN the suspension up.
LOWER the chassis to the minimum that is allowed/acceptable.
REDUCE Droop at both ends.
LESS Rear Toe-in to loosen the Car up.
CHANGE to Harder Tire compounds (do this last).
BTW, you didn't state what kind of Car we are talking about.
LASTLY, slow down only as a last resort.
You can only take a corner so fast... No matter how much traction you have you can only go so quick...
? Traction rolling ?
Is this when a car has so much lateral grip, that it actually flips over?
correct
