Old 11-27-2008, 04:20 PM   #1
nexxus's Avatar
Trader Rating: 302 (100%+)
Default TA-05 Ball Diff problem
Hey all I got one which has me stumped.
My TA-05 has a Ball diff that keeps coming loose!
It's a 12 ball set up from the IFS-R so it has the TRF416 plates, and I have alloy outdrives and Jaad Ceramic Diff Balls.
Tightens up and feels fine after rebuild but always seems to come loose usually mid-race which is never a good thing.
I have tried replacing the spring, diff plates, screw, lock nut and the little plastic thing the lock nut goes into and I have even checked and re-lubed the 2 * 850 bearings in there, still does it! I have built this the way I was told to which is gradually tighten and work the diff until it's fully tight then back out 1/2 to 3/4 which should be a good setting. The diff never slips initially, but after a run, when you go to tighten it, nothing!
Any ideas? I'm don't think my method of building is off as the other diff in the car has been rock solid.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 11-27-2008, 05:46 PM   #2
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
I'm not sure if it was an oversight or not, but you've mentioned replacing everything other than the thrust bearing?
After replacing what you've done and it still comes loose, sounds to me like the thrust bearing isnt doing its job properly. If it sticks or has a cracked ball inside then it wont be able to spin properly and hence can loosen up the bolt/nut.
It only takes a grain of sand to stick in there for that to happen.
Also, overtightening the diff nut/bolt can put pressure on the thrust bearing and squashing it out of action.
Just a thought anyways?
-Mark
mok is offline   Reply With Quote
Old 11-27-2008, 06:12 PM   #3
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
place a drop of threadlock in your diff nut.....but it's only work if your thrust bearing is in good shape otherwise it's still will come loose out...
Give the best while u can !
kschu is offline   Reply With Quote
Old 11-27-2008, 06:30 PM   #4
nexxus's Avatar
Yeah that was my next thing to check, got some thrust bearings coming in as noone locally seems to have them
Old 11-28-2008, 04:52 AM   #5
tc3team's Avatar
Be careful what threadlock you use on the nut if you go down that route, i've heard some bad stories of the nyloc in the nut getting melted
If it is a nyloc nut in the diff (I think most tamiya diff nuts are) they don't usually need threadlock on them.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 11-28-2008, 05:47 AM   #6
I've been using thread lock on tamiya diff so far without any problems. The tiny bit will do.
By the way, did you run in your diff after rebuilts? It does go loose after the 1st few runs and have to be retighten.
Ben.C is offline   Reply With Quote
Old 11-28-2008, 05:53 AM   #7
tc3team's Avatar
Must admit, ive not had any issues either with the Tamiya stuff, but cant say which brands might give issues.
Old 01-06-2009, 04:30 AM   #8
Suspended
I always use thread locking compound on any metal-to-metal fasteners that are exposed to high stress and/ or vibration. I'm not all that worried if it's a nyloc nut or not; theres still a portion of the nut that has metal threads.
I usually check my work when building things like diffs; I'll check for proper fit, cleanliness, smell for smoke or weird chemical burns, correct funtion of moving parts, etc.
Even if the brand of thread locking compound does eat the nylon insert, no problem. I would clean out the affected area, and let the loctite dry, and then simply backfill the empty area with a small dab of shoo goo. And of course I'd keep that sub-assy out of the car until that shoo goo is dry too; in this case w/ a diff. Otherwise I might as well pour liquid latex on the thing and throw it in and run it - doh!!!!!
dragnse7en is offline   Reply With Quote
Old 01-06-2009, 06:04 AM   #9
nexxus's Avatar
Sorted this a while back, thrust bearing was buggered
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Ta04r... IMPACTPLAYR Electric On-Road 2036 06-13-2017 08:09 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Tamiya mini thread MiniMaster Australian Racing 329 11-21-2010 09:53 PM
MINI COPPER,TRF SHOCKS,ACER BEARINGS, PICS RED-LINE M03 R/C Items: For Sale/Trade 15 11-02-2005 02:36 PM
should i get a tl01? rcnewbie Electric On-Road 23 12-03-2003 08:54 AM
Tamiya Ball Differentials taybelZ Electric On-Road 9 11-12-2002 09:28 PM
