Brakes
Old 10-08-2003, 06:38 AM
Default Brakes
As far as I know, drag brakes, coast brakes and automatic brakes are the same thing. That is, a degree of braking is activated when the throttle is at the neutral position. It is supposed to help with steering because it facilitates weight transfer to the front. Secondly you can keep the gas for longer before you coast neutral into a bend.
I am currently a Quatum Competition. The default automatic brakes are set at ZERO. I'm very interested in experimenting with this parameter. But for starters, does anyone actually use this function on their ESC's?
jenny is offline
Old 10-08-2003, 06:50 AM
ark
auto brakes as it says in the instruction manual for the nosram is exellent.I use it in max(#5value).It makes the car have more off throttle steer so much so that i hardly ever brake for a corner!
ark is offline
Old 10-08-2003, 10:55 AM
Cole Trickle's Avatar
I use it on my LRP v7.1. However, I've set it at zero, because I'm running a one-way.
Cole Trickle is offline
Old 10-08-2003, 06:33 PM
JoshR 85's Avatar
HeY!!!
Hey why do you use brakes i never used brakes and i just have some forward roll and then i won't slow down as much because w/out the forward roll and have it at sero i think i slow down to much and i just can't drive like that.
JoshR 85 is offline
Old 10-08-2003, 11:41 PM
It's about driving style. And advantage of slight braking before the corners, is that weight transfers to the front, thus gaining extra front-traction, means more steering. Personally, I find just loosing the throttle a little, gains enough steering.
