Old 04-18-2009, 10:27 PM   #361
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by ThunderPowerRC View Post
Regarding Single cell, YES we have one in the works. Will be here soon
Is the capacity likely to be higher than the SMC 4000mah single cell?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 04-23-2009, 03:21 PM   #362
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
I can't wait to try this out. Thanks Thunder Power!
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 04-23-2009, 10:10 PM   #363
Thirtybird's Avatar
Can anyone shed some light on where to actually find the TP5400-2SPRS?
I'd also like to know the dimensions of each cell as I have a vertical constraint on my old gal...
Racing a Kawada SV-10 in 2010
http://omgitsakawada.blogspot.com/
The VTA Photon! (Inactive - back to the Kawada!)
http://vtaphoton.blogspot.com/
Thirtybird is offline   Reply With Quote
Old 04-23-2009, 10:43 PM   #364
over gear's Avatar
Trader Rating: 15 (100%+)
Originally Posted by sukh View Post
who has the 5000 pack in stock, can't seem to find them anywhere.
+1
over gear is offline   Reply With Quote
Old 04-24-2009, 04:17 AM   #365
Drifting101's Avatar
Originally Posted by over gear View Post
+1
Try phoning them direct
http://thunderpowerrc.com/html/contact-us.php
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 04-24-2009, 04:19 AM   #366
Also TP your Aussie distributors "fastelectrics" are the best store I have dealt with
Schumacher
Old 04-24-2009, 05:15 AM   #367
I got on the waiting list direct from Thunder Power for my TP5400-2SPRS. For the size check this out.
http://www.rctech.net/forum/electric...ml#post5726136
Three words...
Old 04-24-2009, 09:38 AM   #368
Thirtybird's Avatar
Thanks Sprayd - I guess I'll have to see what I have to do to get that 28mm clearance or keep looking
Old 04-24-2009, 10:40 PM   #369
No problem.
Can you post a pic of the car you are trying to fit the pack in? Maybe we can come up with an idea?
Three words...
Old 04-25-2009, 12:51 AM   #370
Thirtybird's Avatar
it would involve cutting off the bottom of a carbon fiber vertical support... this thread
http://www.rctech.net/forum/electric...-comeback.html
has some pictures of the SV10 Alcyon in it (first poster and my post, #8). I currently run the aluminum vertical pieces, which would be impossible to trim down as it is two pieces on the spur gear side, and one of the screws holding the pieces together is at the bottom in area that would need to get cut off to make room for such a tall lipo.
Old 04-25-2009, 05:48 AM   #371
it would involve cutting off the bottom of a carbon fiber vertical support. I currently run the aluminum vertical pieces, which would be impossible to trim down as it is two pieces on the spur gear side, and one of the screws holding the pieces together is at the bottom in area that would need to get cut off to make room for such a tall lipo.
Well depending on how serious you are about trying the pack, you could look into getting a machine shop to modify the plates. Is it possible to re drill and tap a new hole for the screw that would be cut off? Just an idea.
Three words...
Old 04-25-2009, 08:28 PM   #372
I know this is the on road forum, and this thread is about the Thunder Power 5000 40C pack, but I had to put this out here.
http://www.rctech.net/forum/electric...ml#post5731972
I plan on picking up a 5000 40C pack for my 2wd buggy. I'm completely sold on this technology.
Three words...
Old 05-05-2009, 09:24 PM   #373
What's the balance connector used on these packs?
Lazer Speedway - Every place else is just a parking lot!
www.lazerspeedway.com
RC-DriftNewb is offline   Reply With Quote
Old 05-06-2009, 09:48 AM   #374
asw7576's Avatar
Q1. Is this 40C REAL ??
Q2. Is this 40C represent continuous or burst discharging ??
Q3. What electronic instrument use to prove "yep, it's discharging at 40C " ? ... coz 40C x 5000 = 200000/1000 = 200 Amp
Old 05-06-2009, 12:10 PM   #375
asw7576's Avatar
Neverminds with my questions above.
I read from page 1,2,3,4,5,6 ....... it was getting "serious" on page 3,4,5,6
The simple answer to this : If you like it, simply buy it, and race it.
So, this battery consist of four packs huh ? I mean 2S2P ?
2ndly, How do you store your battery for one month ? 50% full ? 100% full ?
I race electric once a month. Do I simply re-peak or discharge and recharge like ni-mh ?
Thank you people.
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
The B.S. Thread al dente Colorado Racing 630 06-21-2009 08:34 AM
