Old 02-06-2009, 11:43 AM   #271
reenmachine's Avatar
Trader Rating: 26 (100%+)
Originally Posted by reenmachine View Post
Yes and no. Their instructions say the following:
"NORMAL CHARGING: The charge rate should not exceed 1C*
* To charge at greater than 1C (no more than 3C): You must use a Thunder Power 1010C charger in conjunction with a Thunder Power Balancer (205 or 210) and data cable. Only ProLite 910, 1320, 2000 and 2100 cells qualify for charging up to 3C."
OK, I basically cut and pasted this from my TP 5000/40C/7.4 instructions a couple of months ago.
ThunderPowerRC -- what's the whole story? Can I interpret this as that it's OK to charge at 2C with any charger as long as I have a balancer hooked up? Can I use a Hyperion EOS1210i with balancer to charge at 2C and be SAFE?
Can I at least charge at 6A with my Hyperion EOS0606i and balancer and be SAFE?
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 02-06-2009, 03:51 PM   #272
Originally Posted by ThunderPowerRC View Post
Touring 17.5 Rubber A Main Qual 2nd / Finish 2nd
Touring 17.5 Foam A Main Qual 2nd / Finish 1st
Vintage Trans Am Qual 1st / Finish 1st
Touring 13.5 Foam A Main Qual 1st / Finish 3rd -4th
Oval Lipo 21.5 A Main Qual 1st / Finish 1st -2nd 4th- 7th
Oval Lipo 17.5 A Main Qual 1st / Finish 1st- 2nd-6th- 9th
Oval Lipo 10.5 A main Qual 1st /Finish 1st-3rd-4th-5th-8th
Was curious how Touring Mod went for Thunderpower? I don't see it listed.
lmiracing is offline   Reply With Quote
Old 02-06-2009, 04:42 PM   #273
ThunderPowerRC's Avatar
We recommend you charge at 1C with a cell balancer. However you can charge safely at 2C with no performance advantage. You will however decrease over cycle life depending on how often you charge at 2C.
Josh finished 4th in mod TC with Dave Ehrlich finishing 6th.
ThunderPowerRC is offline   Reply With Quote
Old 02-06-2009, 05:08 PM   #274
Thanks. I'm not looking for a performance advantage, just a time savings between heats.
Pete Waydo
Old 02-10-2009, 08:52 AM   #275
Dragula426's Avatar
Any reason the 2C decreases the life of the battery?
Dragula426 is offline   Reply With Quote
Old 02-10-2009, 10:22 AM   #276
Grenade10's Avatar
Trader Rating: 37 (100%+)
Any decrease in life doing 1.5C? This makes the charge rate at 6amps for 4,000's and 5 amps for 3200's?
I'm doing this to speed up the charge time.
Thanks in Advance
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 02-12-2009, 05:47 PM   #277
Warren Weaver's Avatar
Trader Rating: 47 (100%+)
Originally Posted by mrrcguy View Post
I too am looking for info about these connectors. I would like to balance my thunder power packs with a CORE charger.
Anyone know how to do this?
anyone else connect it to a core?
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 02-12-2009, 06:46 PM   #278
Skiddins's Avatar
Quote from a previous post of mine, I've made up a balance cable;
Would someone from Thunderpower like to confirm exactly what the make and model is of the balance connector on their packs.
I think I may have found one that does the job, but I accidently ordered the 'socket' which is what is on the pack, I have the 'header' on order.
Just in case someone has access to them and can check now;
JST B04B-PASK-1 (LF)(SN)
4way header
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-14-2009, 11:37 PM   #279
Dragula426's Avatar
I would also like to know. Others I have used have a 3-wire balance plug on a 2S lipo, these are 4-wire. Where can an adapter be purchased, and what are the 4-wires? I am assuming, cell 1 + and Cell 1 - and the others are for cell 2, but need a little more info here.
Team Tekin
Jeffery Racing Concepts
Little 'O' Speedway
Extreme Graffix
Old 02-15-2009, 09:35 AM   #280
Scott B's Avatar
Trader Rating: 43 (100%+)
Thunder Power already posted in this thread what the balancing wires are, so if you do alittle searching you'll find your answer.
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 02-15-2009, 11:30 AM   #281
Doug T's Avatar
Trader Rating: 83 (100%+)
Any word on the 14.8v 4s 40C packs yet ? Just wondering how close they were to releasing them? TP? Thanks .
Speedzone USA- VSR Racing- M2C Racing- HRP-
Speed RC- The Badlands Supercross- King RC- Phatbottom raceway- S&B raceway
Team Associated
Doug T is offline   Reply With Quote
Old 02-15-2009, 11:35 AM   #282
has anyone tried the 3200 40c pack.Just bought one and wanted to know if they will keep up in the 13.5 class.
bigdog is offline   Reply With Quote
Old 02-15-2009, 02:55 PM   #283
Skiddins's Avatar
You only need to use 3 of the wires, the 4th isn't used;
The balance wire config is as follows:
Black - connected to the black neg wire
White - connected to one set cells positive
Blue - connected to the red pos wire
Orange - not use
This is a 2S2P and balances the same as a 2S1P
Hope this helps
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 02-15-2009, 06:14 PM   #284
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
will this work with the core charger/balance?
Old 02-15-2009, 07:38 PM   #285
Mike Haynes's Avatar
Yea but you will need an adapter from the tp tap to the eflight style on the charger.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
The B.S. Thread al dente Colorado Racing 630 06-21-2009 08:34 AM
