Thunder Power Rc 40C 5000 Lipo >
Old 01-01-2009, 05:02 PM
  #226
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Originally Posted by Travis Wait View Post
can anyone tell me if they got this battery to fit in a Losi JRXS type R? I have ordered a couple of these batteries in the hopes that they do fit in the car. I relize I may have to do the pulley mod and grind alittle on the bulk head and lipo tray but just wanted to see if thats about all i need to do.
Thank you in advance!!
Cant wait to give these Beast's a try. Should be a huge change for me. Im still running a orion 4800 20c so should be a big kick in the pants for the ole 13.5 rubber car.
With the plastic tray they drop right in. With the steel tray you have to make a little room for them by grinding on the bulkheads.
Ron Goetter is offline
Old 01-01-2009, 05:14 PM
  #227
Travis Wait's Avatar
Drop right in with out spacing the pulleys farther apart? I am using the lipo tray so guess i will be busting out the dremel. Do the packs fit down in the lipo tray its self or does the tray need to be ground on alittle bit to get to fit down in it.. Thank you again for the fast respond!!!
Travis Wait is offline
Old 01-01-2009, 05:20 PM
  #228
I know the pulleys don't have to be widened. Not sure bout the tray cause mine is already widened for the smc pack
Old 01-01-2009, 05:28 PM
  #229
ok, excellent cant wait to give them a try.
Thank you!!!
Old 01-01-2009, 05:52 PM
  #230
Skiddins's Avatar
Do Thunder Power have a UK distributor?
Skiddins
Skiddins is offline
Old 01-05-2009, 12:00 AM
  #231
Adam?'s Avatar
Hey guys, any word on when more of these packs will go out to the online stores?
Adam? is offline
Old 01-05-2009, 05:52 AM
  #232
quantum's Avatar
which balance connector do the thunder power batteries use?
thnx in advance
quantum is offline
Old 01-05-2009, 09:00 AM
  #233
wstuart's Avatar
Trader Rating: 112 (98%+)
+1, I just bough a 4200 on backorder from ultraline hobbies and am wondering when they might get it
wstuart is offline
Old 01-05-2009, 09:04 AM
  #234
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
thnx in advance
They use the thunder power 4 wire balance connector. 2.0mm spacing.
ChristopherKee is offline
Old 01-06-2009, 11:12 AM
  #235
Skiddins's Avatar
Does anyone have slightly better info on the baance plug?
I know that Core uses a JST-XH for example (or is it EH...can't remember but you get the idea )
Skiddins
Skiddins is offline
Old 01-06-2009, 11:15 AM
  #236
Adam?'s Avatar
Skiddins
http://www.allerc.com/product_info.p...oducts_id=3162
That's the adapter I'm using for my Hyperion chargers. They list a few other brands that seem to use the "TP" style plug.
Adam? is offline
Old 01-06-2009, 01:43 PM
  #237
Skiddins's Avatar
Cheers.
Does anyone know how the 4 wires in the connector relate to the cells in the pack.
Am I right in thinking it's a 2s2p?
How do you balance that configuration?
Skiddins
Skiddins is offline
Old 01-06-2009, 03:45 PM
  #238
EVS
I just talked to a rep. at thunder power and he told me that the 40c soft pack prodject has been scrapped. I am just looking for a 40c pack that can fit in my Losi Type R with the metal tray and no mods. Thanks
EVS is offline
Old 01-06-2009, 04:03 PM
  #239
if you want a 40c pack that fits with no mods... I've yet to find one... I can say this much this pack fits with the least amount of work of all the packs. All you have to do is widen the tray a little and take a little off the bulkheads.. pretty much every lipo on the market thats worth a crap you have to widen the tray for......
Old 01-06-2009, 05:00 PM
  #240
ThunderPowerRC's Avatar
Cheers.
Skiddins
The balance wire config is as follows:
Black - connected to the black neg wire
White - connected to one set cells positive
Blue - connected to the red pos wire
Orange - not use
This is a 2S2P and balances the same as a 2S1P
Hope this helps
ThunderPowerRC is offline
