Old 12-09-2008, 06:38 PM   #166
lil_man72's Avatar
Trader Rating: 29 (100%+)
Default not true
Originally Posted by RLMW VQ View Post
even if some how they really do have 40c, the only way you will notice it is if you are running 2 or 3 turn mod. in a stock 17.5 or 13.5 you will never be able to use all that power. but who knows i could be wrong.
the higher the c rating the better for stock/spec classes. the higher c rating batteries make all motors go faster. in stock/spec classes this is greater since you'll be going faster than your buddy with a 20c pack. in mod classes you can just switch to a faster motor if you need more speed.
lil_man72 is offline   Reply With Quote
Old 12-09-2008, 06:45 PM   #167
MustGoFaster's Avatar
I can't wait until the TP5000-4SPR (5000mAh 4-Cell/4S 14.8V) is released so I can try 40c in my 8th scale buggy!!!
ThunderPower, will it be released before the spring of 2009?
MustGoFaster is offline   Reply With Quote
Old 12-09-2008, 09:07 PM   #168
Doug T's Avatar
Trader Rating: 83 (100%+)
MustGoFaster- I totally agree on the TP5000-4SPR 14.8v ..for my E-1/8.
Jason/TPRC- Are you guys planning on making a 14.8v version of the 40c 5000?
Speedzone USA- VSR Racing- M2C Racing- HRP-
Speed RC- The Badlands Supercross- King RC- Phatbottom raceway- S&B raceway
Team Associated
Doug T is offline   Reply With Quote
Old 12-09-2008, 11:20 PM   #169
SWTour's Avatar
use 2 of the 7.4's with a Y "Series" cable
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 12-10-2008, 12:15 AM   #170
Tech Legend
Wild Cherry's Avatar
Originally Posted by JayBee View Post
Nevermind.....
Yeah "turtle" , Too bad you can`t see who`s the best , and who`s jacking C Rating numbers ....
Wild Cherry is offline   Reply With Quote
Old 12-10-2008, 12:58 AM   #171
JayBee's Avatar
Trader Rating: 31 (100%+)
Come and get some Cherry
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-10-2008, 07:32 AM   #172
TonysScrews's Avatar
WOW, this is a great thread!
I have been running the 1/8th electric conversions the past year and welcome 40C packs! Some of the motors we are using are rated at 2500 watts and lower 20C or 25C packs just don't cut it. I also hear you guys on 12AWG and Dean's Ultra-Plugs with high amp draws. In our 1/8th electric conversions we are seeing amp draws of 125A plus. I already melted the solder on my ESC using 12AWG wire and Dean's Ultra Plugs. I have now switched everything out to 10AWG (6mm) wire and 6.5mm Bullet Connectors. One of the 30C Enerland packs I received from RC Lipos actually had the 8AWG (8mm thick) wire on it but I dis-assembled the pack and replaced the 8AWG wire with 10AWG. The 8AWG wire is just too thick and heavy (I knocked off 42 grams changing just the wire....LOL ).
Since Danny and Jason are on this thread maybe you can help me with some numbers off your packs. I started a list of all available hard-cased LiPo packs in the Electric Off-Road thread. If you guys can verify the numbers, part numbers, specs and fill in some of the blanks I'd appreciated it! (like the 30C and 40C TP packs have the same part number in my list. I got these specs off various sites so my apologies if anything is incorrect)
Best regards,
FORMAT
MFG: (sort Mfg alphabetically, start with lowest C and mah then go up)
XsXp XXc XXXXmah (LxWxH) Weight Plug/BalanceTap Part # - $price$ (R/A = ROAR Approved)
note: Plugs (B=Bare,D=Deans,EC3,EC5,N=None,TAM=Tamiya,TRX=Trax xas)
Balance Tap (A=Align,HYP=Hyperion,NUE=Neutronics,TP=ThunderPow er)
I've noted the MSRP next to the price if from the MFG. Otherwise the price posted is off online shops.
SMC Racing:
2S2P 24C 4100mah (?mm x ?mm x ?mm) ?grams D/? 4124LD - $95.00(MSRP)
2S2P 24C 4100mah (?mm x ?mm x ?mm) ?grams TRX/? 4124LT - $95.00(MSRP)
2S2P 24C 5200mah (?mm x ?mm x ?mm) ?grams D/? 5224LD - $125.00(MSRP)
2S2P 24C 5200mah (?mm x ?mm x ?mm) ?grams TRX/? 5224LT - $125.00(MSRP)
2S2P 28C 3200mah (136mm x 46.5mm x 24.5mm) ?grams D/? 3228LD - $135.00(MSRP)/$89.99
2S2P 28C 3200mah (136mm x 46.5mm x 24.5mm) ?grams TRX/? 3228LT - $135.00(MSRP)/$89.99
2S2P 28C 4000mah (136mm x 46.5mm x 20.5mm) 240grams D/? 4028LD - $160.00(MSRP)
2S2P 28C 4000mah (136mm x 46.5mm x 20.5mm) 240grams TRX/? 4028LT - $160.00(MSRP)
2S2P 28C 5000mah (136mm x 46.5mm x 24.5mm) 290grams D/? 5028LD - $195.00(MSRP)/$129.99
2S2P 28C 5000mah (136mm x 46.5mm x 24.5mm) 290grams TRX/? 5028LT - $195.00(MSRP)/$129.99
Thunder Power:
2S1P 20C 5400mah (137mm x 47mm x 24mm) 278grams TRX/TP TP5400-2SSRT - $109.99 (R/A)
3S1P 20C 5400mah (137mm x 47mm x 33mm) 395grams TRX/TP TP5400-3SSRT - $159.99
2S1P 25C 3300mah (137mm x 47mm x 24mm) 199grams D/TP TP3300-2SXRD - $74.99 (R/A)
2S1P 25C 5100mah (137mm x 47mm x 24mm) 290grams D/TP TP5100-2SXRD - $119.99 (R/A)
2S1P 30C 3900mah (137mm x 47mm x 24mm) 238grams D/TP TP3900-2SPRD - $99.99 (R/A)
2S1P 30C 5000mah (137mm x 47mm x 24mm) 295grams D/TP TP5000-2SPRD - $129.99
2S2P 40C 5000mah (138mm x 46.4mm x 24mm) ?grams D/TP TP5000-2SPRD - $124.99(MSRP)
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 12-10-2008, 10:59 AM   #173
Tech Legend
Sorry, quit racing the beginner class years ago...
Old 12-10-2008, 12:17 PM   #174
Jeel's Avatar
Trader Rating: 16 (100%+)
Can this 40C be charged at 2c?
Jeel is offline   Reply With Quote
Old 12-10-2008, 12:27 PM   #175
reenmachine's Avatar
Trader Rating: 26 (100%+)
Originally Posted by TonysScrews View Post
Thunder Power:
Mine weighs in at 298g. I don't know how accurate my scale is at these light weights, but that's at least a ballpark.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 12-10-2008, 12:33 PM   #176
Yes and no. Their instructions say the following:
"NORMAL CHARGING: The charge rate should not exceed 1C*
* To charge at greater than 1C (no more than 3C): You must use a Thunder Power 1010C charger in conjunction with a Thunder Power Balancer (205 or 210) and data cable. Only ProLite 910, 1320, 2000 and 2100 cells qualify for charging up to 3C."
Pete Waydo
Old 12-10-2008, 03:18 PM   #177
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Higher C doesn't matter until your electronics exceed the batteries capability to supply current. Just because its there, doesn't mean it makes you faster. What you will see in the lower classes is longer run times with little or no fall off of performance through your run. Lap 1 could potentially be as fast as lap 50.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is online now   Reply With Quote
Old 12-10-2008, 07:13 PM   #178
adamge's Avatar
Here's a tip: Going to more voltage will lower your amp draw, lessening the demand for huge wire and special connectors.
-Adam
Best regards,
FORMAT
SMC Racing:
Thunder Power:
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 12-10-2008, 09:54 PM   #179
Less wires the better. Also you add unneeded weight(2 hard cases instead of 1) and height(taller battery then needed) to the buggy. Makes it harder to get the battery under the body.
Us 1/8th electric guys really need a hard case 4s lipo with 10 to 12 gauge wires.
Please help us E-1/8th scale guys out.
Joe Maxey is offline   Reply With Quote
Old 12-11-2008, 12:17 PM   #180
ThunderPowerRC's Avatar
Joe and all you other 1/8 scale racers. Santa is listening and has the elfs working overtime.
ThunderPowerRC is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
The B.S. Thread al dente Colorado Racing 630 06-21-2009 08:34 AM
