Old 11-26-2008, 06:05 PM   #1
Default Wheel axles on 1:12 pancars
Do all modern 1:12 pancars use the same diameter wheel axles (front and rear)?
If yes, what size are they?
If not, what different sizes to the various companies use?
GlennCauley is offline   Reply With Quote
Old 11-26-2008, 09:58 PM   #2
Trips's Avatar
Trader Rating: 16 (100%+)
1/4" is the standard rear axle size, pretty much everyone is usinig it, but Corally, Serpent and Xray may be different, also the Hot bodies may be different, don't know for sure.
1/8" is standard up front, the CRC GENX (Pro Strut front end) uses a 3/16 axle tho. Again, Corally, Serpent and XRAY may be different, but not likely in the case of the front axle.
MARSHAL!!
Trips is offline   Reply With Quote
Old 11-26-2008, 10:04 PM   #3
Ike
Ike's Avatar
Corally cars that use the Corally wheels are different up front, though can't remember exactly what size.
Ike is offline   Reply With Quote
Old 11-27-2008, 04:38 AM   #4
Joost K.'s Avatar
The Serpent S120 & the HB C12 both use the 1/4" rear axle size for sure. Corally uses metric sizes on the rear axle.
For the front end, Serpent & HB both use the standard 1/8" front axle sizes and Corally a different system exept on the WC version with the Asso/CRC front end, there is uses the 1/8" front axles like we all know.
From the pictures of the Xray car I'd say they will go with the flow and use the standard 1/4" & 1/8" rear & front axles...
Every other brand like Associated, BMI, CRC (exept pro strut) use the 1/4" rear axle and 1/8" fronts...
Joost.
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 11-27-2008, 04:58 AM   #5
protc3's Avatar
The CRC front axles on the pro strut front end are 3/16 if i remember correctly. The rest of us use 1/8th front axles and 1/4" rear axles.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
