Old 11-25-2008, 12:57 PM   #1
SoCalMitch's Avatar
Default Asphalt vs Carpet
Which surface do you think would draw the most and keep the most racers for a local indoor track?
Carpet: easy on rubber tires, 12th scale friendly, cheaper and less work to install, more big races on carpet now, etc..
Asphalt: feels more like real racing, better image toward new drivers, better grip for rubber tires, etc..
SoCalMitch is offline   Reply With Quote
Old 11-25-2008, 01:06 PM   #2
94eg!'s Avatar
Trader Rating: 17 (100%+)
Oooh, that's gonna be a touch call. I've only race asphalt (parking lot) so i'm not gonna be much help...
94eg! is offline   Reply With Quote
Old 11-25-2008, 01:14 PM   #3
I12PonU's Avatar
Trader Rating: 10 (92%+)
Carpet is much easier to tires than asphalt. Easy on the cars and keeps the chassis plate clean. Not always, but in my experiene, carpet would have less rocks or debris to mess up your drive train and gears. Most importantly, carpet generally has better traction than asphalt. Carpet doesnt give tire squeals like asphalt, so some may be turned off by that. Some may not like carpet becasue of the need for tire traction compound.
I12PonU is offline   Reply With Quote
Old 11-25-2008, 01:17 PM   #4
Foxxrocket's Avatar
+1
But I enjoy the unprodictable irregularity asphalt has on the outcome of a race.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 11-25-2008, 01:22 PM   #5
Francis M.'s Avatar
IMO, indoor asphalt would draw more people in the Socal area....
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 11-25-2008, 01:24 PM   #6
SWTour's Avatar
Years ago I visited an indoor flat track that was just the concrete floor that had something similar to a tennis court topping texture painted on to it.
It had great traction, didn't have the expense of ASPHALT, nor carpet. The owner said it was easy maintenance too....
Maybe an option?
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 11-25-2008, 01:42 PM   #7
Go check out the 360 RC Speedway thread in the racing forum. They opened a year ago. They have an asphalt base and run carpet over it. They run on carpet in the winter, and on the asphalt in the summer.
So many racers whined about the lack of grip on the asphalt they put the carpet down early.
jiml is offline   Reply With Quote
Old 11-25-2008, 03:09 PM   #8
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Not all carpet type work...if you don't have the good ozite carpet, it will not work as good.
Carpet hairs get wound up all over the drivetrain- the carpet fuss/hairs get in the axles, diffs, pulleys, etc, and its a pain to take out. Cant just blow it off.
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 11-25-2008, 03:30 PM   #9
Tubaboy's Avatar
Eh that happens to Ozzite from CRC as well though. I've pulled out enough carpet from race days to make my own little 1x1 foot track it seems.
Just kidding... but seriously, ozzite fuzzes pretty bad too. maybe not so bad on the newer stuff with the thicker backing though.
Paul
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 11-25-2008, 03:43 PM   #10
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
get ya facts straight!!! carpet went down early so people can prep for the Vegas race....
gees this information comes from someone who resembles Santa clause..... comes around once a year to race !!!!!! LOLOLOLOLOL
ALBERTO is offline   Reply With Quote
Old 11-25-2008, 03:47 PM   #11
RCSteve93's Avatar
I was going to say something.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 11-25-2008, 04:18 PM   #12
Me too.
giantbill is offline   Reply With Quote
Old 11-25-2008, 05:03 PM   #13
I race both. Carpet is much more predictable since parking lots have lots of surface irregularity. Plus carpet can be used year round and for 1/12 scale like you mentioned. Even minis can race on carpet. Key is not to cheap out on carpet and get good stuff like the stuff CRC sells. Carpet is expensive and you only want to put it down once.
Like others said, carpet is much more gentle on the cars. Note that cars are way faster on carpet too. Lots of traction. With rubber outside you have to worry about temps and having lots of different tires to match the temps. Inside the temp is controlled and it is easier to dial in the car.
Tony
under200 is offline   Reply With Quote
Old 11-25-2008, 05:12 PM   #14
What about wood? Some guys convert indoor basketball gyms into tracks
Adis is offline   Reply With Quote
Old 11-25-2008, 06:08 PM   #15
Hebiki's Avatar
Originally Posted by Foxxrocket View Post
+1
me too. plus with carpet.. traction compound eventually builds up.. then you have CRAZY traction. asphalt has the option of being washed down to remove traction.
+1
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46180 Today 12:18 AM
Atlas YM34 Thread AE_Racer Electric On-Road 704 01-17-2010 10:18 AM
Sorex Vs Takeoff snoopy Electric On-Road 38 06-27-2002 09:39 PM
Tires Foam vs. Rubber you decide! FoamDonuts Electric On-Road 81 03-10-2002 07:59 PM
TC3 vs. Losi XXX-S R_Andersen Electric On-Road 27 03-04-2002 06:29 AM
Setting: Droop VS Camber link position Alvin Electric On-Road 55 01-13-2002 10:21 PM
