Old 11-22-2008, 10:57 AM   #1
ohmygahitscoby's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to ohmygahitscoby
Default FT TC4 Questions.
Hey guys,
I traded my TT01 for a FT TC4, but figured out that it was incomplete. I need the following things:
Top Deck
Stand-offs
Spline
Camber Link Mounts
1 CVD
Driveshaft
Spool
Edit: Turns out I have the FT chassis. Can I use the ITF top plate on the FT chassis?
-Coby
ohmygahitscoby is offline   Reply With Quote
Old 11-22-2008, 12:43 PM   #2
TTT
Old 11-22-2008, 01:13 PM   #3
cla5675's Avatar
Trader Rating: 49 (100%+)
I ran a FT TC4 all summer in our "Sportsman" class. I used an ITF top deck along with the FT bottom chassis. The car is decent for stock or VTA racing, but I expreinced a lot of wear and tear on my CVD's and diff outdrives. You may want to look into some Irrgang Racing Systems "Big Dawg" CVD axles with the "pin cushions". Hope that helps!!!
Troy.
cla5675 is offline   Reply With Quote
Old 11-22-2008, 01:31 PM   #4
Ah okay. That takes some stuff off of my list . Thanks!
BTW: Is there a difference between the Big Dawgs and the ones that already come with the FT (Blue aluminum)?
http://www.carttonic.com/catalog/ind...2&pi_id=136104
Old 11-22-2008, 07:03 PM   #5
RCSteve93's Avatar
They increase the life of the outdrives...
http://teamirsrc.com/tc3.html
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 11-23-2008, 01:16 AM   #6
I don't really understand how they do increase the life of the outdrives, but if they do I guess I'll be buying them.
Old 11-23-2008, 08:56 AM   #7
RCSteve93's Avatar
The have a foam around the pins...
rm -rf /windows
Old 11-23-2008, 12:13 PM   #8
Ohh okay. Thanks!
Also, if I run the FT chassis with the ITF top plate, can I use the ITF spline or do I have to use the FT spine?
Old 11-23-2008, 12:51 PM   #9
cla5675's Avatar
You can use either spine. I ran the FT spine.
Old 11-23-2008, 01:05 PM   #10
RCSteve93's Avatar
Ohh okay. Thanks!
The ITF is only milled out for more flex. They are all interchangeable.
rm -rf /windows
Old 11-23-2008, 04:13 PM   #11
Ohh okay. Thanks!
Old 11-23-2008, 05:44 PM   #12
crookdaddy's Avatar
Trader Rating: 23 (96%+)
does anyone know about steel or aluminum diff gears and where i can get some at
crookdaddy is offline   Reply With Quote
Old 11-23-2008, 05:47 PM   #13
crookdaddy's Avatar
is it good to have 1 way in the front or two way on the tc4
Old 11-23-2008, 05:56 PM   #14
As long as you have the perfect mesh on your TC4, you won't need a steel spur gear. They don't make steel spurs anyways.
Using a one-way helps a lot. You should use it for both, because it's pointless to have a one-way in the front and none in the back.
Old 11-23-2008, 05:59 PM   #15
crookdaddy's Avatar
im running on-road tracks will that mess with my sterring in front and spin out my rear
Team Associated TC4 Kenshin Electric On-Road 15355 Yesterday 09:23 AM
General Discussion Modena AL MSRA (Memphis, TN) 7895 05-05-2014 05:50 AM
tc3 RTR jrr102486 R/C Items: For Sale/Trade 26 12-01-2007 08:47 PM
Touring car questions mo92 Electric On-Road 11 03-07-2006 01:35 AM
FS: Xray FK'05, TC4, 3PM Afro Puff R/C Items: For Sale/Trade 15 02-04-2006 10:06 AM
