Old 11-21-2008, 02:06 PM   #16
Tech Legend
Wild Cherry's Avatar
If C don`t matter how come I can feel a big difference between a 20C & 25C ?
Either you guys are all wrong about C or I don`t really feel the extra power...
Wild Cherry is offline   Reply With Quote
Old 11-21-2008, 02:15 PM   #17
minimusprime's Avatar
Trader Rating: 19 (100%+)
If your motor setup will consume more then the 20c pack's amp drain capacity can allow then you will feel a difference.
other then that it's amazing what your mind will convince you of when your wallet is 100 bux lighter and your psyche wants to feel validated for the money you spent.
"I personally do not believe in luck. I believe luck is just an excuse for people that have failed in their mission to accomplish something." Allen McNish
minimusprime is offline   Reply With Quote
Old 11-21-2008, 02:22 PM   #18
sheetmetal2's Avatar
Originally Posted by minimusprime View Post
yes it does but it means more then that when you are racing and not just bashing.
IF all things are constant except batteries. (Car, Driver, Motor, Heat length, gearing, track etc etc etc)
Lets set up a hypothetical with those constants and a 3200 mah battery and a 4800mah battery.
The higher the mah of the battery... the more voltage it will have left when the heat is over. Meaning that both lipo's are going to start with the same relative punch/top speed (as long as your c rating is such that the battery is not the limiting factor) as they are both starting out with 8.4 volts. However, as the heat moves forward the 4800 will have more capacity left and should have more voltage at the 5 minute mark. So... for racing stock having more mah is a good thing for this reason.
Make any sense?
What you are saying makes perfect sense to me but, I was told that the power a lipo delivers stays very static through out the run. I have also been told that you can take a 5000mah battery charge it once in a stock class and run the entire day (2 heats and a main all 5 min). Was I informed wrong?
www.rcxracing.com
Rc10 Gt EDM
M&M Racing Klien Sprint Car
Losi Mini T
sheetmetal2 is offline   Reply With Quote
Old 11-21-2008, 02:23 PM   #19
Krio's Avatar
Trader Rating: 150 (99%+)
I've said it elsewere and I'll say it again. Having a higher C rating is MORE important in the stock classes since they hold a higher voltage under ANY load even if they aren't approaching their claimed current limit. That being said, you can't trust half the C ratings that are being claimed out there so it doesn't really matter...
www.kriostasis.com
Krio is offline   Reply With Quote
Old 11-21-2008, 02:32 PM   #20
WIITA's Avatar
Trader Rating: 42 (100%+)
Just remember one crash during a 5 min race will cost you + -10 seconds. Thats way more that 10c can get you.
WIITA is offline   Reply With Quote
Old 11-21-2008, 02:39 PM   #21
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Originally Posted by MACHFIVE View Post
I'm tired of buying new lipos every two months because of the C ratings going up every month or so. Is there some maximum C rating rule anywhere? When will it end?
Like other have said, no need at all to be buying new lipos every 2 months...just make sure you make a wise choice in which pack you choose for your class. Get packs from a manufacturer with a good reputation in the racing world, and look for the pack that best suits your need and budget and HAVE FUN
C rating is not everything or the most important factors. It's only part of the picture, and most people cant even tell the difference between a 20C and 25C pack performance wise.
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 11-21-2008, 02:44 PM   #22
yyhayyim's Avatar
At least SMC has been upfront about their packs and they are doing a great job on posting their packs numbers to we know what we're getting into...it's much better than what others have not been doing
Old 11-21-2008, 04:28 PM   #23
TwoTone's Avatar
Also remember, a lot of companies are lying about the numbers just to sell more batteries at a higher price.
Large thread already on this.
TwoTone is offline   Reply With Quote
Old 11-21-2008, 04:30 PM   #24
Company Representative
Danny/SMC's Avatar
RC racers are always complaining about batteries. For years we have heard when will the sub-c cell makers stop increasing the capacity or stop releasing new cells but the fact is technology improves over time and battery manufacturers will always try to make better batteries.
With Lipo it's not any different as there are better materials being developed and used. A true 35C pack wasn't available 4 months ago but now it's possible and we will see 40 , 45 , 50 and so on as technology improves.
Although higher C rates should help performance I don't think it's a big difference in RC cars as were putting allot of loads on the packs. If you take our 24C pack against our 28C pack you will not see a difference on the track in limited motor classes. If a pack has a higher C rate it should typically help it's cycle life as well.
So when you have a pack that gives you good performance it doesn't mean you need to go buy the latest and greatest as you probably won't notice a bog difference. After all driving and car setup is way more important than the latest and greatest pack.
Danny/SMC is offline   Reply With Quote
Old 11-21-2008, 04:34 PM   #25
94eg!'s Avatar
Trader Rating: 17 (100%+)
This is true, but I don't think you would want to do that. Lipo voltage will still drops throughout the run, so not charging it between runs means it will get a little slower each time...
94eg! is offline   Reply With Quote
Old 11-21-2008, 04:38 PM   #26
Mason's Avatar
Depending on what you race this might actually help many people
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 11-21-2008, 05:04 PM   #27
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Don't buy them. It is just a great way to sell batteries to the consumer. Look every business has a way to promote and sell things and for lipo it is the C rating. Your average racer won't notice a difference from 25C from 30C anyways.
ST Racing Concepts (STRC)
Old 11-21-2008, 06:04 PM   #28
94eg!'s Avatar
Well SMC defines C rate as the discharge current limit a pack can sustain while maintaining at least 90% of it's capacity. This means their 4000mah 28C pack will put out 3600mah at a constant discharge rate of 112amps. The problem is that this is not a "standard", so every manufacturer uses a different set of rules & measures. Some use 80%, and other just list their C rating as the max load before the pack explodes...
BTW: Punch is still a function of internal resistance and average votlage just as it was with Nimh. Until packs have this info printed on them, we have no real way of comparing them...
Old 11-21-2008, 06:26 PM   #29
Danny/SMC's Avatar
Our 4000/28C can retain 90% of it's capacity at a 112 amp continous which is 28C. See graph below.
There are some standards for Lipo manufacturers but some will use different methods to achieve different results that normally will give there packs a better C rate as this is important for marketing. Most Lipo manufacturers use 1C to determine capacity but I have seen some that use .5C but they do print it on there website. Maybe the consumer should ask the company selling the Lipos how the calculate there C rate to see if they are using a good method. I think why some seem to inflate the C rate or chose a method that isn't as stringy is because they know that equipment to test C rate is pretty expensive as it requires allot of power dissipation to pull 100-175 amps. So if the consumer can't test the C rate they feel they can claim whatever they want.
As far as printing the IR , Voltage and Capacity on the packs that could help compare packs but the problem with this is that you need to use a GFX and where you decide to attach the voltage sensing leads will impact the numbers. Here are some examples with the same pack.
Voltage leads attached to the balance connector: 5.5 - 7.42
Voltage leads attached to the end of the power leads: 6.5 - 7.39
Voltage leadse attached to the power connector on the charger side: 8.0 - 7.35
Pack and room temp will also have an impact on the numbers and so will the charge rate.
There are also other things such as overcharging or using a charger that tends to charge a bit past 8.40 will also make the numbers look better.
So comparing numbers would only work when comparing packs from the same company.
Old 11-22-2008, 03:12 AM   #30
DJ
Hi what is 2s stand for in lipo's label.
is it better to charge a lipo in 1s although its written 2s
or use 2s?
I know its out of topic, but dont know where can i post this question, please advice
DJ is offline   Reply With Quote
