Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree96Likes
Old 02-17-2019, 03:03 AM
  #9631
!Mad Max!'s Avatar
Originally Posted by vivo quevas View Post
Guys i need a A700L front diff assembly mount AM10-1 if you have one pm me .
thanks
If you mean the AM10-1 Steering Plate:
AM10-1 Steering Plate ? AWESOMATIX
Or later version AM10-2 which was more strong:
AM10-2 Steering Plate ? AWESOMATIX
!Mad Max! is offline
Old 02-17-2019, 01:03 PM
  #9632
Trader Rating: 22 (100%+)
Brian mistyped the part number, He's looking for a gearbox AM01.
noproblems209 is offline
Old 02-17-2019, 03:15 PM
  #9633
vivo quevas's Avatar
Trader Rating: 19 (100%+)
i have floating. Front diff i want to go back to the non floating front diff.
No i was dyslexic AM01-1II
vivo quevas is offline
Old 02-18-2019, 04:20 AM
  #9634
!Mad Max!'s Avatar
Also in stock. Just check direct Awesomatix webshop for such parts.
http://shop.awesomatix.com/shop/index.php?productID=858
Old 02-22-2019, 03:27 PM
  #9635
The part price is fine but the shipping from Europe to the US is crazy.
Old 02-23-2019, 03:35 AM
  #9636
!Mad Max!'s Avatar
You also could ask the US Distriutor from Awesomatix if he may have this part for you, or can order/get it for you.
Awesomatix USA
Old 02-24-2019, 06:56 PM
  #9637
roadkill's Avatar
Trader Rating: 150 (100%+)
anybody have any trouble's with PO 3,s?I seem to have 1 or 2 that break in half or split open when I snap them on.
roadkill is offline
Old 02-24-2019, 08:07 PM
  #9638
Question what do you mean split the cap? The top popped off or it split on installation?
Broke in a wreck or what?
lve had 2 of the 3 problems so i may have a suggestion or 2.
Old 02-25-2019, 07:07 AM
  #9639
roadkill's Avatar
spilt in half (from top to bottom) on instulation.
roadkill is offline
Old 02-25-2019, 08:19 AM
  #9640
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
p03 breaking at installation time isn't highly uncommon. it requires a bit of finesse. recently we've heard of more and more people 'complaining' about this being an issue. at the moment even myself, someone who has built amtx cars since 2013 can break a p03 during assembly if I'm not careful.
i'd recommend building the AT21 + P03 by using non marring/smooth surfaces to "press" the two pieces together. i commonly have the AT21 on my pit table and then using my pit board to press the P03 onto the piece.
once these pieces are mated together --- also --- dont even think about trying to disassemble them.
hanulec is offline
Old 02-25-2019, 08:51 AM
  #9641
I like to put them in a cup of hot water, pull them out and use a q-tip to remove water from inside and then snap them down. It helps.
AlBundy is offline
Old 02-25-2019, 11:27 PM
  #9642
roadkill's Avatar
my way is a s follows. I put the at21 on the chassis, pace a po3 onto the stud,and press it down evenly with a piece of alom flat stock. for the most part it works good, but seems like every bag has one or two that split.i have a lot of old ones that seem to be thicker (more material used) just wounderin if the mold that make them could be worn out.
roadkill is offline
Old 03-03-2019, 09:11 AM
  #9643
With many of these cars being used in the VTA class these cars are ars getting old. With any older car their chassis plates need to be replaced does anyone know someone that makes new carbon fiber chassis's?
If they could design a new chassis that could use the new 8-9mm a-arms.
Just wishing out loud.
If you know a chassis maker pleas ask them to make a A700 replacement chassis.
Kodey65 likes this.
Old 03-03-2019, 11:29 AM
  #9644
Fredp1's Avatar
Try contacting Paul from BezerkRc..
He will make want you want
Just be careful with the position of the new arms. On the A800, they are perfectly positioned with not alot of room.
Fredp1 is offline
Old 03-03-2019, 02:07 PM
  #9645
the 700 with the mm2 will not allow this, l don't think the first version will either.
AlBundy is offline
