motor brushes cutting ? >
Old 10-05-2003, 05:22 PM
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
Default motor brushes cutting ?
hi, do you guys cut your motor brushes ? if so, share with your best method for cutting and also what brushes would you suggest for racing ? thanks
Tag is offline
Old 10-05-2003, 07:09 PM
pro3racer's Avatar
i've wanted to know this, what is the purpose of cutting a brush(a new one). Or is this just for used brushes.
pro3racer is offline
Old 10-05-2003, 08:26 PM
sands's Avatar
do you have a dyno? Or can you borrow one?
I'm asking the same questions myself, but I just got a used fantom and have been experiemting today.
LEading edge cuts will increase efficiency but decrees power. Horizontal cuts will increase power, but at a slight cost in efficiency. Same with drilled brushes. Trinity high silvers are slightly better than 4499s, but wear faster.
Lighter springs seem to work better, but In' not sure if that will translate onto the track. Find out this weekend.
But from a couple of hours of playing around, having your brush hoods aligned is by far the best tuning you can do.
Sands
sands is offline
Old 10-05-2003, 11:17 PM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Do a search on the net for "Big Jims Motor Black Book" you'll find everything you could ever want to know about motors in that. Or buy the actual book on the Team Paradigm link on my signature.
Randy Caster is offline
