Old 01-19-2002, 09:03 AM   #1
Default TC2 Problems help help
When my TC2 is at half throttle it starts skipping.If anybody has a remedy to this problem I would appreciate any help.
Later,
Craig
grinch77 is offline   Reply With Quote
Old 01-19-2002, 11:23 PM   #2
Send a message via AIM to ZER01
I would first diagnose the problem by trying another motor(make sure you have all three caps on the motor along with the schottky diode). If that wasn't the problem, I would try another set of crystals. If that wasn't the problem, I would try another radio system(borrow your friends). If that wasn't the problem then it has to be the esc(make sure the 4700 micro farad cap is installed onto the speedo and it hasn't been dead shorted beyond reality)! Good luck and Happy Racing!
ZER01 is offline   Reply With Quote
Old 01-19-2002, 11:25 PM   #3
Actually, I would try reprogramming the speedo first. Good Luck!
Old 01-19-2002, 11:28 PM   #4
I had that exact problem one time and it turned out that my throttle lever on my radio was causing the problem. It had gotten bent while I was transporting my gear to a race.
b4/t4 problems trdsupra88 Electric Off-Road 12 03-15-2008 10:52 PM
JR Z-1 Problems...need help! pumpkinfish Radio and Electronics 3 10-24-2007 05:31 PM
Problems.. Oasis Chat Lounge 9 01-16-2006 08:41 AM
tc3 one way problems dontfeelcold Australian Racing 7 12-31-2003 04:34 PM
Set Up Problems Griz Australian Racing 5 12-05-2003 12:44 AM
