Old 05-13-2009, 07:51 AM   #901
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by Mr. Blonde View Post
One thing with the RX lipo pack....solder a resistor between the power wires...to reduce it to 6V.
Did that with mine, weight is 10 grams with small switch and its supersmall!!
Simply leave speedo (LRP) off and only switch on or plug in the RX pack.
Hmmmm strange....I only used like 40-50 maH in 8 minutes....with a Graupner DS3781 servo..pretty similar to JR 3650 I guess.
Markus
P.S.: Anyone tried any different cell than the SMC?? Heard some other companies are testing too.....
I don't like the resistor idea. I've used a small 7.4v 2 cell lipo and a voltage regulator. I don't have to charge it all night and never go below 6 volts!
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 05-13-2009, 07:56 AM   #902
No no.....it will only let 6 volts out....nothing else will change....
Speedtech RC Germany-Home of MobGums tyres
--------12scale addicted---------
Mr. Blonde is offline   Reply With Quote
Old 05-13-2009, 08:44 AM   #903
I know it will work but resistors are inefficient.
Old 05-13-2009, 09:09 AM   #904
Resistors are not a good idea. We used to use diodes back in the day because they have a more predictable voltage drop regardless of load. Even those were only a bandaid fix for the whole BEC problem.
By the time you spend the money setting up a proper receiver pack set-up you might as well bight the bullet and get either a NOVAK booster or one of the cheaper ones that are out there.
Fred_B is offline   Reply With Quote
Old 05-13-2009, 12:15 PM   #905
Well sorry guys....I meant diodes...could not find the right word *lol*
I thought my english was good *lol*
Old 05-13-2009, 12:32 PM   #906
Markus
How did you fit the lipo in your S120? Is there any word or news about a lipo specific chassis for the S120 and being available before the IIC? Can you post a picture of your car with the lipo set up? I would really like to run my S120 at the IIC but if there is not a specific chassis, I may have to run something else.
Crashby is offline   Reply With Quote
Old 05-13-2009, 12:52 PM   #907
I knew this question would come up
Ok, I ran the pack on one side...all the other stuff on the other....
It was no problem, balance was ok...I simply use doubleside tape
to fit the pack.
But....I got a proto S120L in da house...which I will test this weekend...
We actually will offer both S120 and S120L
So we are ready for both....NimH or Lipo...
Markus
Old 05-13-2009, 02:31 PM   #908
LOW ET's Avatar
Trader Rating: 97 (100%+)
for those running the lipo pack on one side and electronics on the other, how is the body fitment? i tried that type of setup on the 1/18 scalpel and you had to have the right type of body to get everything to fit under it.
LOW ET is offline   Reply With Quote
Old 05-13-2009, 04:05 PM   #909
to fit the pack.
Markus
Great news, Markus!!!
Pleae keep all of us S120 racers updated on when these lipo chassis will be available. I do need a couple for the IIC which is in early September. Using doulble stick tape is fine for one time testing but when you are forced to charge using a lipo sack, then it's not very practical. We need a chassis with four slots on both sides and wide enough to support taping the battery in place.
Will you be attending the IIC this year?
I just sent you a PM
Old 05-14-2009, 06:12 AM   #910
GWH74's Avatar
Default Single cell and brushed
Can this single cell be run with a 19T brushed motor?
Does anyone make a single cell lipo cut-off? There are loads of two cell have not see any single cell.
GWH74 is offline   Reply With Quote
Old 05-14-2009, 06:17 AM   #911
kidsid99's Avatar
Trader Rating: 53 (100%+)
The Novak Smart Boost #5474 boosts voltage to your receiver and also has a built in lipo cutoff for 3.3v ( I think that is what their site says).
XRAY, RC America, Boca Bearings,
www.msra-racing.com
kidsid99 is offline   Reply With Quote
Old 05-14-2009, 06:58 AM   #912
GWH74's Avatar
Thanks kidsid99. I have looked at these before but never realised that they also have lipo cut-off. It is a bit crude as it just pulses the voltage to the receiver, hence the ESC and servo, to let you know that the battery voltage is low.
Will the single cell work OK with brushed or are they too inefficient.
Old 05-14-2009, 10:07 AM   #913
PutAwayWet's Avatar
I've run a 1S/19t and, yeah, it was hard to make 8 minutes at any reasonable pace. A 27t would be better.
Good luck.
SMC 4000/25C/3.7V single cell Hardcase pack.-lipo-t-fource-x.jpg
Todd Mason
Seattle RC Racers
The world ends when you're dead. Until then, you got more punishment in store.
Stand it like a man, and give some back. --Al Swearengen
PutAwayWet is offline   Reply With Quote
Old 05-14-2009, 03:45 PM   #914
silverfrancis's Avatar
I was wondering if it was possible to put the voltage booster between the battery and esc. Is this even possible. I am thinking about buying the yeah racing esc and brainless brushless motor as it is cheap. However it says that it only supports 2-3 cell lipo. Is it still possible to run 1 cell lipo.
Thanks in advance
For Technology news visit: www.technific.com
silverfrancis is offline   Reply With Quote
Old 05-15-2009, 02:26 AM   #915
Good news guys.
I found a cheap brushless motor set up that has an adjustable voltage cut off as low as 2.6V. It is the Yeah racing esc that retails around $100, but the only downside is that it is not sensored. Oh well it comes with a program card and all the features are controlled from there.
Here is a link to check the stats for yourself: http://www.rcmart.com/catalog/rc-bru...cPath=293_1301
P.S. In no way am i suggesting to go there and buy it. They just have a comprehensive list of details about the motor and esc!
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
SMC 5700mAh 25C Single Cell Lipo Danny/SMC Electric On-Road 352 05-14-2009 04:03 AM
Trackside 1/12th scale racing Ike Wisconsin & Illinois Racing 41 03-31-2009 11:42 AM
ROAR 1/12 weight limit miller tyme Electric On-Road 171 01-09-2009 04:14 PM
Why choose LiPo? wingman2 Electric On-Road 16 12-17-2008 06:51 PM
1/12 lipo the mighty thor Electric On-Road 7 12-07-2008 03:01 PM
