Old 05-03-2009, 07:41 PM   #886
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Originally Posted by fred kellner View Post
Well if they new packs have bullet connectors how about 5000 Mah as well.
Like this?
They are listed as "Coming Soon" @ Nexus
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 05-03-2009, 08:38 PM   #887
Moderator
Clegg's Avatar
Charging of the packs....
So on the TQ website they say charge at 2C (8Ah), is this really OK with these packs?
1C (4Ah) takes for ever and actually caused me to not get a full charge on a pack for an entire day of racing since the heats were so close together. Just curious.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 05-03-2009, 08:39 PM   #888
Moderator
Clegg's Avatar
Originally Posted by brians11 View Post
Like this?
These are 7.4v packs... wrong thread.
Old 05-08-2009, 07:12 AM   #889
AMC
Smile 3.7v 1s Lipo Cut Off
Anyone know where we can source 3.7v 1s Lipo Cut Offs for the cars ?
AMC is offline   Reply With Quote
Old 05-08-2009, 09:17 AM   #890
chris moore's Avatar
Trader Rating: 88 (99%+)
Novaks new booster has a cutoff included, although the Novak unit is big and clunky looking. The latest software for the Tekin RS esc includes a cutoff also I beleive
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 05-08-2009, 01:20 PM   #891
LOW ET's Avatar
Trader Rating: 97 (100%+)
has anyone run the single cell lipo with mod brushless motors? how does it perform?
LOW ET is offline   Reply With Quote
Old 05-08-2009, 02:01 PM   #892
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Very ballistic ... car needs set-up changes for sure ...
that is if you are going to run them light.
I would even venture to say ... TOO GD FAST!
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 05-08-2009, 03:11 PM   #893
Grenade10's Avatar
Trader Rating: 37 (100%+)
Yes the RS with the new software had the 1 cell cut off, so nothing is needed.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 05-08-2009, 03:13 PM   #894
Grenade10's Avatar
We ran an exhibition class with 1cell, 10.5 at 700 grams and fast is the word. They drove very well, much less tire wear, but as was noted, needed a few changes. I've got a 6.5 that I wanted to play with but just have not had the time.
Old 05-08-2009, 05:35 PM   #895
PutAwayWet's Avatar
I have. Ballistic, light, fun, looking forward to more.
Todd Mason
Seattle RC Racers
The world ends when you're dead. Until then, you got more punishment in store.
Stand it like a man, and give some back. --Al Swearengen
PutAwayWet is offline   Reply With Quote
Old 05-12-2009, 06:45 PM   #896
kidsid99's Avatar
Trader Rating: 53 (100%+)
I need to know how you guys are running the single cell lipo. I have been reading and see where you are leaving the switch off to do so but how are you powering the speed control? I must have missed the proper way to wire it. Could someone please explain how this is done.
Thanks in advance
XRAY, RC America, Boca Bearings,
www.msra-racing.com
kidsid99 is offline   Reply With Quote
Old 05-12-2009, 07:30 PM   #897
Trader Rating: 16 (94%+)
Thanks in advance
Yep - leave the speedo powered off, and use a small LiPo receiver pack, 100-300mah will do, using approx 60-90mah per 8-min race. The other option is to use a Booster which will take the 3.7v from the 1s LiPo and boost it to a flat and consistent 6v.
Some guys are plugging the LiPo Receiver battery directly into the Receiver, but a fully charged LiPo is 8.4v which could be too high for some brands of equipment. Futaba Receivers for example, cannot take more than 6v safely, and some servo's also cannot take more than 6v. In this case, I recommend you use a LiPo Voltage Regulator. Muchmore, Losi, Novak, and others make them.
When using LiPo Regulator, you will plug the Regulator into the Receiver, and the LiPo Battery into the Regulator. As for the 1s LiPo, you will not change the manner that this is wired, still plus into the Positive and Negative on the speedo to power the motor.
kn7671 is offline   Reply With Quote
Old 05-13-2009, 04:21 AM   #898
He guys!
Tested some with 1S Lipo on friday.
Ran the following:
SMC 1S Lipo 4000maH
LRP X12 4,5 Turns
LRP SXX speedo
VXR RX Lipo, 120maH,7,4 Volt, reduced to 6V
First time out it sucked big time....I charged the pack they day before and it had no power at all. I recharged than and it was much better!
Had more than a minute left after 8 min, so I geared up 4 teeth.
Actually it was ok than....better than I expected.
It is not "ballistic" fast and sure slower than NmiH! It feels like running 10,5 with NimH.
Compared to NimH my lap times were like 4-5 tenth slower on a 15sec. track.
As I still had like 40sec left, I will try to run a 3,5 or 4,0 Turns.
Biggest threat in future is heat...with less voltage you will gear up, run a hotter motor and increase timing.
I am pretty sure in the future fast rising capacitys will be hard for speedos. Temperatures will be the main issue.
For now it will be ok....but we are at the start of Lipo.....
Greetz and take care!
Markus
Speedtech RC Germany-Home of MobGums tyres
--------12scale addicted---------
Mr. Blonde is offline   Reply With Quote
Old 05-13-2009, 06:40 AM   #899
theisgroup's Avatar
Robert at Ko is telling me to remove the positive on the speedo to the rx and running the speedo off the 3.7 lipo pack.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 05-13-2009, 07:06 AM   #900
One thing with the RX lipo pack....solder a resistor between the power wires...to reduce it to 6V.
Did that with mine, weight is 10 grams with small switch and its supersmall!!
Simply leave speedo (LRP) off and only switch on or plug in the RX pack.
Hmmmm strange....I only used like 40-50 maH in 8 minutes....with a Graupner DS3781 servo..pretty similar to JR 3650 I guess.
Markus
P.S.: Anyone tried any different cell than the SMC?? Heard some other companies are testing too.....
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
SMC 5700mAh 25C Single Cell Lipo Danny/SMC Electric On-Road 352 05-14-2009 04:03 AM
Trackside 1/12th scale racing Ike Wisconsin & Illinois Racing 41 03-31-2009 11:42 AM
ROAR 1/12 weight limit miller tyme Electric On-Road 171 01-09-2009 04:14 PM
Why choose LiPo? wingman2 Electric On-Road 16 12-17-2008 06:51 PM
1/12 lipo the mighty thor Electric On-Road 7 12-07-2008 03:01 PM
