Old 03-09-2009, 08:59 AM   #811
cdee's Avatar
There was another racer running the smc in the 1/12 genX.
Booster I was using is the one from HobbyKing -
http://www.hobbycity.com/hobbycity/s...idProduct=7884
everything worked really nice, had full servo speed and transponder power for the full 8 minutes.
With the tekin RS, you have to wire in another mini switch off the + and - on the esc into the booster and than the booster into the reciever. Long story short you are suppling the reciever with 5v, and anything else down stream from there, ie servo and transponder. With the tekin you leave the speedo switch off and tuck it away somewhere. Also used the 189 software/profile.
I was a little sketptial at first about all this, and it sounds like a big hastle, but it is really not that bad, and worked really nicely.
I have some pics to post if anyone is interested, just dont make fun of my wiring "jungle"... lol
hope this helps.
cdee is offline   Reply With Quote
Old 03-09-2009, 06:50 PM   #812
Originally Posted by THEBIGBULL View Post
Will the single cell 4000 fit in the CRC "GENX"???????. What are you using for a booster and how do install it. I'm waiting for the Novak booster for my 4cell GTB.
It does fit in the Gen-x but you can't use the stock locations of the battery holder. I had to drill 2 new holes in the chassis.
No booster, Losi micro-t lipo as receiver pack with voltage regulator.
Regards,
Carter
darcydawg is offline   Reply With Quote
Old 03-09-2009, 09:11 PM   #813
I used Shoo Goo for the SMC cell and then I found a old servo wire and soldered the pos & neg (white wire not used) wires to the ESC pos & neg. Then plug it into the booster. I did not put a on off switch in. just plug it in when your ready to race..
-=light=-
Gorden
light is offline   Reply With Quote
Old 03-09-2009, 11:56 PM   #814
Thumbs up
Hey, Thanks for the help guys!!!!!!! Some pic's would be great. We run 3 (8 min.) qualifiers and an (8min) main in about 3 1/2 hours, is 1 pack enough??? with charging required. I am currently runnig a novak 10.5 but I will be going to a lower turn brushless motor. I am currently running 4cellNIMH. I have a GFX charger that I am going to send in for the "lipo" upgrade, but I would like to buy a smaller A/C charger to take to the track, whats a good choice. I will be charging lipo packs as well for Pro 10 and also touring car.
THEBIGBULL is offline   Reply With Quote
Old 03-10-2009, 05:50 AM   #815
If you're running 10.5 or lower in that kind of timeframe I would recommend getting two packs. This way you can charge at a reasonable current 4 to 5 amps is about all that you want to go if you want the pack to last a long time.
Fred_B is offline   Reply With Quote
Old 03-10-2009, 02:09 PM   #816
Yaksaddle's Avatar
Trader Rating: 33 (100%+)
Send a message via AIM to Yaksaddle
Anyone know where these are currently in stock? I have 2 on order at Stormers and the Novak Booster - I am trying to be patient, but I just got my S120 and realllllllly want to start dialing it in.
Danny - any word when these will be in stock?
Serpent S400 - LRP - SMC
Serpent S120 Novak - SMC 3.7v
Yaksaddle is offline   Reply With Quote
Old 03-10-2009, 02:18 PM   #817
jdearhart's Avatar
Trader Rating: 15 (100%+)
Try here:
http://www.lefthander-rc.com/catalog...oducts_id=1673
Very good guys to deal with!
jdearhart is offline   Reply With Quote
Old 03-10-2009, 02:37 PM   #818
Yaksaddle's Avatar
thanks for the link -
Looks like Novaks 1Cell lipo Step up module wont be released until the end of the month... Ugh!
Does SMC have a reccomendation to hold me over until Novak decides to grace the 12th scale market with their module? I'm running the GTB 4Cell with SS, and Novak 17.5bl -
Old 03-10-2009, 02:40 PM   #819
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Try the GTB 4 cell without a receiver or booster. I am able to run 8 minute 13.5 races with no problem like that.
Old 03-10-2009, 10:05 PM   #820
Around me this lipo thing is begining to loose some of it's steam. Guys are selling off and switching back to NMH batteries. With the newest batches of batteries I believe they are very stable and hold up well to abuse.
march to my own is offline   Reply With Quote
Old 03-11-2009, 01:23 AM   #821
ben73's Avatar
Trader Rating: 40 (100%+)
I have run single cell lipo for 2 race meetings now in modified and have had no issues.
lrp 2007 comp/spektrum/ace booster wired direct with extra switch. esc switch off
lrp x12 4.5
single cell 4200mah lipo.
personal transponder
our paved tracks here in aus are low traction but we are making 8 min without going soft at all.
ben73 is offline   Reply With Quote
Old 03-11-2009, 07:10 AM   #822
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Me too!.....
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 03-11-2009, 09:25 AM   #823
Phil Trotta's Avatar
i run the crc t bar cars with 3.7 lipo i have run this car over 10 minutes 13.5 motor at 360 in a test for donny lia....the novak has no need for boooster or receiver pack at 7 min some punch is lost no steerring problems.......................................... ...phil
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 03-11-2009, 01:31 PM   #824
Yaksaddle's Avatar
To those that are running this without a rx pack or booster - are you soldering in any in line power switch? Are you noticing any heat issues? ESC or Motor? What gearing are you using?
Old 03-11-2009, 03:09 PM   #825
Anybody that has run 1c lipo have a good starting rollout for a 17.5?
jrrc is offline   Reply With Quote
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
SMC 5700mAh 25C Single Cell Lipo Danny/SMC Electric On-Road 352 05-14-2009 04:03 AM
Trackside 1/12th scale racing Ike Wisconsin & Illinois Racing 41 03-31-2009 11:42 AM
ROAR 1/12 weight limit miller tyme Electric On-Road 171 01-09-2009 04:14 PM
Why choose LiPo? wingman2 Electric On-Road 16 12-17-2008 06:51 PM
1/12 lipo the mighty thor Electric On-Road 7 12-07-2008 03:01 PM
