Old 03-05-2009, 11:24 AM   #796
If you still have throttle control when the front end locks up I would definately look at the servo. I think that most of us are running servo's from KO, Futaba, and JR in 12th and maybe some of the Airtronics stuff in 1/10th.
Fred_B is offline   Reply With Quote
Old 03-05-2009, 12:00 PM   #797
Originally Posted by cla5675 View Post
Hey, guys. I need a little help on getting the SMC 3.7v pack to work in my WGT car. I tried running without a rx pack and the servo would "lock" after about 2 minutes of run time. So, I tried a 2s lipo rx pack and the same thing would happen. Last night, I finally got a 6v regulator (Losi LOSB9608) for the lipo rx pack and the problem was worse. I tried leaving the GTB switch off and just using the switch on the regulator...didn't work. Then I tried both switches turned on and still no luck. I then threw some AA alkaline batteries together to make a 6v pack and it worked for one 5-minute heat then the locking feeling came back in the main......uuuugggghhhh (Charlie Brown style!!)!!! So, here I am pleading for assistance. Here is my set up:
Speed Merchant Speed Spec II
Novak GTB (tried it with switch off and switch on and had same results)
Airtronics FM micro receiver
700mah 2s lipo pack with Losi LOSB9608 regulator
Mulitplex Polo Digi 4 servo (baciscally a digital HS-85MG servo)
I'm going to swap out the servo to a larger servo with more torque. Anyone have any other suggestions? Thanks!!
Troy.
Novak posted something about this last month. You have to cycle the esc switch on and then back off to close a relay and then run just off the Lipo/regulator.
Eddie_E is offline   Reply With Quote
Old 03-05-2009, 12:08 PM   #798
cla5675's Avatar
Trader Rating: 49 (100%+)
I cycled the ESC switch after I turned on the regulator switch and the servo would still lock up. I'm pretty sure a servo change will probably cure the problem, but I appreciate your repsonse Eddie!!
cla5675 is offline   Reply With Quote
Old 03-08-2009, 10:00 AM   #799
Satish's Avatar
Any idea when this pack will be ROAR approved?
Satish is offline   Reply With Quote
Old 03-08-2009, 10:24 AM   #800
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
It already is
http://www.roarracing.com/approvals/lipobattery.php
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 03-08-2009, 10:49 AM   #801
Satish's Avatar
great thanks.
Another question, how many packs do you guys have? I plan on running 17.5, are 2 packs enough?
What amperage do you charge it at? I have an ICE charger and use it charge my TC 4000 Lipos, I assume I should be ok with these packs with this charger.
thanks,
s
Old 03-08-2009, 11:10 AM   #802
losithrasher's Avatar
ok, so its roar legal, but no updates on when we can use it in 1/12 stock?
ONE THINGS FOR SURE ABOUT THE STINGER, NOTHINGS FOR SURE!
losithrasher is offline   Reply With Quote
Old 03-08-2009, 11:11 AM   #803
beyondthepack's Avatar
Send a message via Yahoo to beyondthepack
My internet is slow, so i didn't go through the other pages and I'm sure this question has been asked to Danny, but with the release of the new X-Ray, AE alternate chassis, Hot Bodies Cyclone, CEFX, etc will there be a saddle pack for the t-plate chassis, and if so when?
AE B5R - SC10.2 - Outdoors
AE TC7.1 USGT - INFINITY IF14 - Indoors
LRP - REEDY - FUTABA - IDEAL HOBBIES - RC404
beyondthepack is offline   Reply With Quote
Old 03-08-2009, 12:48 PM   #804
Tubaboy's Avatar
He has no plans to support T-Bar cars with a separate case. *shrug* For now, most T-Bar people are mounting them on one side, and putting all the electronics on the other side.
Paul
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 03-08-2009, 01:57 PM   #805
KHoff7's Avatar
great thanks.
thanks,
s
One battery is all that is needed. The ice charger will charge the battery just fine.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 03-08-2009, 02:20 PM   #806
Jim S's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to Jim S
has anyone used this battery in there 10r5
Jim S is offline   Reply With Quote
Old 03-08-2009, 04:15 PM   #807
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Yep. The standard cell spacers need to be filed down a bit to get a perfect fit. The pack is a touch longer front to back than typical cells
Old 03-08-2009, 09:45 PM   #808
Satish's Avatar
thats awesome, now i can get rid of all my 4cell packs and smart tray... wohoo
thx,
Old 03-08-2009, 10:09 PM   #809
cdee's Avatar
12th Scale / 1s / 10.5.... for anyone interested... I gave this a spin today... tons of fun. I ran a 12R5 with SMC 4000 1s Lipo, Tekin Speedo, and battery booster / 88 pinion - 35 spur - 1.90" rear tires. Full eight minutes with no drop in power, motor came off at 125 deg F and battery took 2000mAh of charge after the run.
cdee is offline   Reply With Quote
Old 03-08-2009, 10:37 PM   #810
Thumbs up
Will the single cell 4000 fit in the CRC "GENX"???????. What are you using for a booster and how do install it. I'm waiting for the Novak booster for my 4cell GTB.
THEBIGBULL is offline   Reply With Quote
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
SMC 5700mAh 25C Single Cell Lipo Danny/SMC Electric On-Road 352 05-14-2009 04:03 AM
Trackside 1/12th scale racing Ike Wisconsin & Illinois Racing 41 03-31-2009 11:42 AM
ROAR 1/12 weight limit miller tyme Electric On-Road 171 01-09-2009 04:14 PM
Why choose LiPo? wingman2 Electric On-Road 16 12-17-2008 06:51 PM
1/12 lipo the mighty thor Electric On-Road 7 12-07-2008 03:01 PM
