Old 02-09-2009, 09:32 AM   #751
Conrad's Avatar
The nominal voltage for a single cell lipo is obviously 3.7v but what are the voltages after a full charge at the start of a run and the voltage of the cell after a 8 min run?
Just trying to work out if my esc (GM V3R, yeah i know bottom of the ladder esc but it make my mardave go like hell) would still be working at the end of the run. I know it runs fine about 4.1v (voltage of gp3300 cells after a run when put on discharger) but having just tried a 3 cell pack with 3.86v the esc and pt briefly lit then didnt work at all, the servo was fine though.
Conrad is offline   Reply With Quote
Old 02-09-2009, 09:41 AM   #752
jdearhart's Avatar
Trader Rating: 15 (100%+)
4.22 would be at the start, not sure after an 8 minute run though.
jdearhart is offline   Reply With Quote
Old 02-09-2009, 10:25 AM   #753
Moderator
Clegg's Avatar
Originally Posted by jrp View Post
What speedo are you running ? With the LRP Sphere, you need to run it off of the battery, then into the speedo (like it was a receiver pack), otherwise the speed control senses low voltage and cuts motors signals, thus the dumping feeling.
Novak GTB 4 cell SS. No dumping feeling at all through the race.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 02-09-2009, 02:40 PM   #754
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 02-09-2009, 03:04 PM   #755
PartTime's Avatar
Originally Posted by CCH1978 View Post
iI just ordered the 1 cell lipo...got a race on Sunday I will post results soon after!!!
So how did it go?
DK
PartTime is offline   Reply With Quote
Old 02-10-2009, 11:10 AM   #756
CCH1978's Avatar
Trader Rating: 27 (100%+)
Originally Posted by PartTime View Post
So how did it go?
DK
we race over at jonesboro arkansas and the just had a bad ice storm about two weeks ago so we just got word that they just got power again so we will be racing Sunday if everything works out....I will post results soon after.
MINI REVO Mamba Max Pro NEU POWERED
THE BEATINGS WILL CONTINUE UNTIL THE MORALE IMPROVES
BEAST MODE (ON) OFF
CCH1978 is offline   Reply With Quote
Old 02-14-2009, 10:45 AM   #757
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by Danny/SMC View Post
Once the speed control cutoffs get changed I think the flat feeling will go away. In testing done by Donny Lia he tells me that the pack will run fine for 6 minutes but after that it starts to feel like it's dumping but there is still plenty of capacity in the pack. I think under acceleration the voltage dips down below the speed cutoff so it backs off the power to motor to keep it for the reciever. So basically for 8 minute 12th scale to work properly it will require updated speed controls.
Both of the speedos I have can have the VCO disabled..
Tekin...KO...
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 02-14-2009, 02:22 PM   #758
I think what Danny is referring to ( please correct me if I'm wrong) is not the user settable lipo cutoff voltage. Most esc's have a separate preset voltage (set by the manufacturer) that must be maintained for the receiver/servo to function. When the volts drop below this point the esc limits the power to the motor to maintain rec/servo function. The lipo cutoff is there strictly to prevent over discharging.
Scott
You know you love the tape, Sturley...
snowyelan is offline   Reply With Quote
Old 02-14-2009, 03:23 PM   #759
Scott
No , you are correct! But as a serious racer I can realize when I need to take it off the track. I shut mine off. My son whom is six however... Oh it's on now!
Old 02-14-2009, 10:23 PM   #760
how do i setup up a sphere to run on a single cell lipo in 13.5 1/12th? esc settings, booster(would the tq cells one work) or reciver pack?
SPC Racer is offline   Reply With Quote
Old 02-15-2009, 06:24 AM   #761
PartTime's Avatar
I put the voltage cut off on nimh because its lower then 2cell lipo, not sure if it even works though.
Start with a 3.15-3.2 roll out and the speedo set with 2,6,3,0. I have used a 4cell rx pack of 150 mah and now a booster. The booster is cool cause I dont have to charge two packs for one car but the rx pack did work just as well. I wired a switch inbetween the speedo and booster and turn just the booster on.
DK
Old 02-16-2009, 06:20 AM   #762
swimbikerun's Avatar
Trader Rating: 100 (100%+)
I'm running a Novak GTB 4 Cell SS/Novak 17.5 BL and was wondering what people had for rollout? I started with 88.5mm and that seemed a bit low. Trying to get in the ballpark before fine tuning at the track. Thanks.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 02-16-2009, 07:22 AM   #763
The rollout for 17.5 really depends on the track. I'm finding that on some tracks the motor won't overheat even when it's overgeared. So, with 17.5 I've ended up around 90mm. Use laptimes to gear up or down from there and turn the timing all the way up on the motor for single cell 17.5 and light weight.
Fred_B is offline   Reply With Quote
Old 02-16-2009, 07:59 AM   #764
PartTime's Avatar
75x36 track I settled on 3.52 rollout. Tried 3.62 but it was a touch too much so went back. Timing was cranked on both motor/speedo. Ran ok. Wouldnt load the motor as much in the corners with the 3.5 roll out. Next will try dropping the timming on the motor and a 3.6 roll out.
DK
Old 02-16-2009, 02:50 PM   #765
Skiddins's Avatar
Questions??
How are people finding their laptimes compared with 4cell on the same circuits etc.
Preferably with different motors.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
SMC 5700mAh 25C Single Cell Lipo Danny/SMC Electric On-Road 352 05-14-2009 04:03 AM
Trackside 1/12th scale racing Ike Wisconsin & Illinois Racing 41 03-31-2009 11:42 AM
ROAR 1/12 weight limit miller tyme Electric On-Road 171 01-09-2009 04:14 PM
Why choose LiPo? wingman2 Electric On-Road 16 12-17-2008 06:51 PM
1/12 lipo the mighty thor Electric On-Road 7 12-07-2008 03:01 PM
