Old 01-21-2009, 09:43 PM   #691
DriftDreamer06's Avatar
Originally Posted by brians11 View Post
Shoe Gooing the connector to the front side of the case really helped with everything as well...
What size is that lipo on the servo?
DriftDreamer06 is offline   Reply With Quote
Old 01-21-2009, 09:46 PM   #692
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
200 MaH
Old 01-22-2009, 07:00 AM   #693
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Originally Posted by andrewdoherty View Post
200 MaH
what he said
brians11 is offline   Reply With Quote
Old 01-22-2009, 10:20 AM   #694
cla5675's Avatar
Trader Rating: 49 (100%+)
I had put away my WGT car since last September because I was sick of the round cells. Well, last night I finally bought the SMC 3.7v pack and ran it in my WGT. The speed was good, but there were no other WGT cars at the track last night so I didn't have a peer to compare with. However, the WGT was much faster than my 17.5/rubber tire touring car down the 80' straight away. My motor was only coming off at 90 degrees so I've got some more room to gear up if need be. Punch out of the corners wasn't bad either....of course I was geared a little low. I was also running at 1086 grams...a little under minimum wieght. I didn't run a booster or RX pack. I wanted to see how well the car worked without 6v to the servo. As suspected, the servo felt sluggish and would not center coming out of a hard turn. Sometimes the servo even felt "locked" coming out of a turn and I would take a sharp left or right into a board. I think a booster will be all I need to get the servo issue worked out....I'll be buying Novak's booster as soon as possible!! All in all, I'm very happy with this pack and I truly believe we might be seeing the end of Nickel based cells....at least at my local tracks!!
By the way, here is my WGT setup....please bare in mind I'm a WGT rookie and I only race at the club level:
Speed Merchant Speed Spec II
BSR Double Pink Front
BSR Pink Rear
Novak Havoc ESC
Novak SS10.5 motor
Multiplex Polo Digi 4 servo (basically a digital Hitec HS-85MG)
HPI Mustang GTR body (I know it's a "flying brick" but it just looks cool)
...and of course a SMC 3.7v 4000 battery!!
cla5675 is offline   Reply With Quote
Old 01-22-2009, 10:59 AM   #695
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by SteveL View Post
Has anyone found a way to "neatly" wire one of these and still be able to easily get the battery in & out for charging? I've not seen one posted in the "Inspire us. Show me your BEST, CLEANEST electronics installation pics. " thread yet.
Sure they did .. Part time posted a few pics of his CRC and showed us all how its done .
As far ar beating a dead horse Jack... I'm only stating an opinion. Something that I felt necessary to address. I'm Chevy Chase and your not.
Its not an arguement. I don't care how long the horse has been lying there I guess I'm a necropheliac. I do tend to drift a bit but to make a point. If you don't get it , try again. If you don't like what I write , don't read it. Freedom of speach man. The squeaky wheel gets the grease. My $0.02 is worth the same as yours. Only thing is , I know what I want. Do you ?
John St.Amant is offline   Reply With Quote
Old 01-22-2009, 11:05 AM   #696
Wrapping power wires around your antenna isn't a good idea.
Old 01-22-2009, 11:17 AM   #697
Necropheliac? I said BEATING a dead horse, not BANGING one.
Jack Rimer is offline   Reply With Quote
Old 01-22-2009, 11:20 AM   #698
Trader Rating: 18 (100%+)
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 01-22-2009, 11:32 AM   #699
lol and the winner is...Jack
lmiracing is offline   Reply With Quote
Old 01-22-2009, 12:08 PM   #700
and i want to add just so i am clear. all of this back and forth bickering and nonsense is over wires coming out of a battery pack compared to some sort of connector built in?
seriously come on...
Old 01-22-2009, 12:09 PM   #701
I actually ran the antenna up over the wires, and I've never had a problem with them being close before... not me personally at least
Old 01-22-2009, 12:23 PM   #702
Well, they can't complain about ni-mh cells going bad with this pack, so there has to be something...
Old 01-22-2009, 01:05 PM   #703
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
[QUOTE=cla5675;5327627] All in all, I'm very happy with this pack and I truly believe we might be seeing the end of Nickel based cells....at least at my local tracks!!
Glad to hear your having success running it in WGT......... Happy Racing!!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 01-22-2009, 01:25 PM   #704
You can do whatever you want with your horse ok! .
Old 01-22-2009, 03:34 PM   #705
PutAwayWet's Avatar
So, I ran my 12R5 with a Novak 7.5 last night in club racing. Very fast. More power than I need for our track. I was pulling wheelies at times, though mostly I was feathering the throttle to keep it under control. The car is light, and there is a ton of power on tap, but the truth is I'm not sure it's really faster overall than 4 cell super stock. It wants to get airborne at times. My car is weighing in at 740g with a 160mah rx pack. Between runs I was putting about 2300 mah back in. The motor was coming off lukewarm at 8 minutes.
To say the least, there is ample opportunity for running a ballistic missile lipo version of 1/12th scale. I'm not convinced this is a "slow-the-class-down" proposition, even at 4000 mah capacity.
On a different note, I put a lipo in my T-Fource with a 19t. Balanced and butter overall, though the 19t definitely draws the amps. Geared at 65mm rollout it runs like a fast stock motor. Handling is superb, maybe better than my 12R5, though I want to try a brushless rig in it when I get a chance. This cell form factor is absolutely t-bar friendly, there is no need at all to wait for saddle packs. Picture attached.
SMC 4000/25C/3.7V single cell Hardcase pack.-lipo-t-fource-x.jpg
PutAwayWet is offline   Reply With Quote
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
SMC 5700mAh 25C Single Cell Lipo Danny/SMC Electric On-Road 352 05-14-2009 04:03 AM
Trackside 1/12th scale racing Ike Wisconsin & Illinois Racing 41 03-31-2009 11:42 AM
ROAR 1/12 weight limit miller tyme Electric On-Road 171 01-09-2009 04:14 PM
Why choose LiPo? wingman2 Electric On-Road 16 12-17-2008 06:51 PM
1/12 lipo the mighty thor Electric On-Road 7 12-07-2008 03:01 PM
